ESD0P2RF-02LS
ESD0P2RF-02LS
    YENJI(台湾元基)
    TVS二极管 VRWM=5V Ipp=4A 0201
ESD0P2RF-02LS 数据手册
ESD0P2RF-02LS TVS Protection Diode RoHS Device Halogen Free Features 0201/DFN0603-2L - Bi-directional ESD protection of one line. - IEC61000-4-2 Level 4 ESD protection. - Low capacitance: 0.2pF 0.015(0.37) 0.011(0.27) - Low reverse stand-off voltage: 5V - Low reverse clamping voltage. 0.026(0.67) 0.022(0.57) - Low leakage current. Mechanical data 0.013(0.340) - Case: 0201/DFN0603 package, molded plastic. 0.011(0.275) 0.002(0.05) - Polarity: Color band denotes cathode end. REF. - Mounting position: Any 0.017(0.435) 0.014(0.365) 0.001(0.03) REF. Circuit diagram 0.012(0.295) 0.009(0.225) 0.008(0.195) 0.005(0.125) 0.008(0.195) 0.005(0.125) Dimensions in inches and (millimeter) Maximum Ratings (at T =25°C unless otherwise noted) A Parameter Conditions Symbol Air model Value Unit ±20 IEC 61000-4-2 Contact model (1) JESD22-A114-B ESD voltage Per human body model ESD voltage Machine model ±18 kV ±18 ±0.4 Peak pulse power (2) PP 80 W (2) PP 4 A TL 260 °C TJ 150 °C TSTG -55~+150 °C P Peak pulse current Lead solder temperature VESD I Maximum(10 second duration) Operation temperature range Storage temperature range Notes: (1) Device stressed with ten non-repetitive ESD pulses. (2) Non-repetitive current pulse 8/20µs exponential decay waveform according to IEC61000-4-5 1 ESD0P2RF-02LS TVS Protection Diode Electrical Characteristics (at T =25°C unless otherwise noted) A Parameter Symbol Conditions Typ Min (1) Working peak reverse voltage VRWM Reverse leakage current VRWM = 5V Breakdown voltage IT = 1mA V(BR) Clamping voltage IPP = 4 A (2) Junction capacitance VR = 0V, f = 1MHz IR VC 5.5 CJ 0.2 Max Unit 5 V 1 µA 10 V 20 V 0.6 pF Notes: (1) Other voltage available upon request. (2) Non-repetitive current pulse 8/20µs exponential decay waveform according to IEC61000-4-5 RATING AND CHARACTERISTIC CURVES (ESD0P2RF-02LS) Fig.1 - 8/20us Peak Pulse Current Waveform Acc. IEC 61000-4-5 120% Percentage of Ipp 1.0 Test Waveform parameters tf=8us td=20us Peak Valur Ipp Junction Capacitance, CJ (pF) Ta=25°C 100% Fig.2 - Capacitance Characteristics e-t 80% 60% 40% td= t Ipp/2 20% 0.8 0.6 0.4 0.2 0 0% 0 5 10 15 20 25 0 30 Fig.3 - Clamping Voltage Vs. Peak Pulse Current 24 TA=25°C TP=8/20us 20 16 12 8 4 1 2 1 2 3 Reverse Voltage, VR ( V ) Time, (us) Clamping Voltage, VC (V) TA=25°C f=1MHz 3 4 Peak Pulse Current, IPP (A) 2 4 5 ESD0P2RF-02LS TVS Protection Diode Reel Taping Specification d P0 P1 T E F W B A C P 12 o 0 D2 D1 D W1 Trailer Device ....... ....... End ....... ....... Leader ....... ....... ....... ....... 160mm (min) Start 400mm (min) Direction of Feed 0201 (DFN0603) 0201 (DFN0603) SYMBOL A B C d D D1 D2 (mm) 0.39 + 0.03/-0.02 0.72 ± 0.03 0.36 ± 0.03 1.50 + 0.10 178.00 ± 1.00 54.40 ± 0.40 13.00 ± 0.20 (inch) 0.015 + 0.001/0.001 0.028 ± 0.001 0.014 ± 0.001 0.059 + 0.004 7.008 ± 0.039 2.142 ± 0.016 0.512 ± 0.008 SYMBOL E F P P0 P1 T W W1 (mm) 1.75 ± 0.10 3.50 ± 0.05 2.00 ± 0.05 4.00 ± 0.05 2.00 ± 0.05 0.23 ± 0.05 8.00 ± 0.10 12.30 ± 0.10 (inch) 0.069 ± 0.004 0.138 ± 0.002 0.079 ± 0.004 0.157 ± 0.004 0.079 ± 0.004 0.009 ± 0.002 0.315 ± 0.008 0.484 ± 0.004 3 ESD0P2RF-02LS TVS Protection Diode Suggested PAD Layout 0201(DFN0603) SIZE (mm) (inch) A 0.16 0.006 B 0.24 0.009 C 0.34 0.013 D 0.40 0.016 E D A C B E 0.64 0.025 Standard Packaging Case Type 0201(DFN0603) Qty Per Reel Reel Size (Pcs) (inch) 15,000 7 4
ESD0P2RF-02LS 价格&库存
很抱歉,暂时无法提供与“ESD0P2RF-02LS”相匹配的价格&库存,您可以联系我们找货
