Approval sheet
WR18X(W), WR20X(W), WR25X(W)
±1%, ±5%
Thick Film Power Chip Resistors
Size 1218,2010,2512
*Contents in this sheet are subject to change without prior notice.
Page 1 of 7
WR18-20-25X(W)_V17
DEC - 2016
Approval sheet
FEATURE
1.
High power rating and compact size
2.
High reliability and stability
3.
Reduced size of final equipment
4.
RoHS compliant and Lead free products
APPLICATION
Power supply
PDA
Digital meter
Computer
Automotives
Battery charger
DC-DC power converter
DESCRIPTION
The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are
added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The
composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to
nominated value within tolerance which controlled by laser trimming of this resistive layer.
The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For
ease of soldering the outer layer of these end terminations is Tin (lead free) alloy.
Fig 1. Construction of 2512, 2010 Chip-R
Fig 2. Construction of a 1218 Chip-R
Page 2 of 7
WR18-20-25X(W)_V17
DEC - 2016
Approval sheet
QUICK REFERENCE DATA
Item
General Specification
Series No.
WR18X(W)
WR20X(W)
WR25X(W)
Size code
1218(3248)
2010 ( 5025 ),
2512(6432)
±5% (E24); ±1% (E24+E96)
Resistance Tolerance
Resistance Range
1Ω ~ 10MΩ, Jumper (0Ω)
± 100 ppm/°C
± 100 ppm/°C
± 100 ppm/°C
± 200 ppm/°C
± 200 ppm/°C
± 200 ppm/°C
1W
0.75 W
1W
Max. Operation Voltage (DC or RMS)
200V
200V
250V
Max. Overload Voltage (DC or RMS)
400V
400V
500V
TCR (ppm/°C) :
10Ω< Rn ≤ 10MΩ
1Ω≤ Rn ≤ 10Ω
Max. dissipation at Tamb=70°C
Operation temperature
-55 ~ +155’C
Storage temperature
5 ~ 40’C
Test conditions for jumper ( 0 ohm )
Type
WR18X(W)
WR20X(W)
WR25X(W)
1W
3/4 W
1W
Resistance
Max. 50mR
Max. 50mR
Max. 50mR
Rated Current
4.5 A
3.8 A
4.5 A
Peak Current
11 A
9A
11 A
Operating Temperature
-55C ~ 155C
-55C ~ 155C
-55C ~ 155C
Power Rating At 70C
Note :
1.
This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication
60115-8”
2.
Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by
RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower.
MECHANICAL DATA (unit : mm)
TYPE
WR18
WR20
WR25
L
3.05±0.15
5.00±0.20
6.40±0.20
W
4.60±0.20
2.50±0.20
3.20±0.20
T
0.55±0.10
0.55±0.10
0.60±0.10
Tt
0.45±0.25
0.65±0.25
0.65±0.25
Tb
0.50±0.25
0.60±0.25
0.90±0.25
Page 3 of 7
WR18-20-25X(W)_V17
DEC - 2016
Approval sheet
MARKING
Each resistor is marked with
value.
Example:
1R00
1001
0000
a four-digit code on the protective coating to designate the nominal resistance
1Ω
1000Ω
0Ω
FUNCTIONAL DESCRIPTION
Product characterization
Standard values of nominal resistance are taken from the E96 & E24 series for resistors with a tolerance of
±5% & ±1%. The values of the E24/E96 series are in accordance with “IEC publication 60063”.
Derating curve
The power that the resistor can dissipate depends on the operating temperature; see Fig.3
Figure 3. Maximum dissipation in percentage of rated power
as a function of the ambient temperature.
MOUNTING
Due to their rectangular shapes and small tolerances, Surface Mountable Resistors are suitable for handling by
automatic placement systems.
Chip placement can be on ceramic substrates and printed-circuit boards (PCBs).
Electrical connection to the circuit is by individual soldering condition.
The end terminations guarantee a reliable contact.
Page 4 of 7
WR18-20-25X(W)_V17
DEC - 2016
Approval sheet
SOLDERING CONDITION
The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260°C
for 10 seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other
discrete components on the reverse (mixed PCBs).
Surface Mount Resistors are tested for solderability at 235°C during 2 seconds. The test condition for no
leaching is 260°C for 30 seconds. Typical examples of soldering processes that provide reliable joints
without any damage are given in below.
CATALOGUE NUMBERS
3-5 sec
The resistors have a catalogue number starting with .
WR20
X
472_
J
T
L
Size code
Type code
Resistance code
Tolerance
Packaging code
Termination code
WR25 : 2512
X:
J : ±5%
T : 7” Reel taping
WR20 : 2010
±5%: 1Ω-10MΩ
5% E24 : 2 significant digits
followed by no. of zeros and
a blank
F : ±1%
(T:1218 10” Reel)
L = Sn base (lead
free)
WR18: 1218
±1%: 10Ω-1MΩ
4.7Ω
=4R7_
P : Jumper
Q : 10” Reel taping
W:
10Ω
=100_
1% : 1MΩ
Page 5 of 7
G : 13” Reel taping
1% E24+E96: 3 significant digits
102Ω
=1020
37.4KΩ
=3742
WR18-20-25X(W)_V17
DEC - 2016
Approval sheet
TEST AND REQUIREMENTS(JIS C 5201-1 : 1998)
Essentially all tests are carried out according to the schedule of IEC publication 115-8, category LCT/UCT/56 (rated
temperature range : Lower Category Temperature, Upper Category Temperature; damp heat, long term, 56 days). The
testing also meets the requirements specified by EIA, EIAJ and JIS.
The tests are carried out in accordance with IEC publication 68, "Recommended basic climatic and mechanical robustness
testing procedure for electronic components" and under standard atmospheric conditions according to IEC 60068-1,
subclause 5.3. Unless otherwise specified, the following value supplied :
Temperature: 15°C to 35°C.
Relative humidity: 45% to 75%.
Air pressure: 86kPa to 106 kPa (860 mbar to 1060 mbar).
All soldering tests are performed with midly activated flux.
TEST
PROCEDURE
DC resistance
DC resistance values measured at the test voltages specified below :
Clause 4.5
很抱歉,暂时无法提供与“WR25X10R0FTL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.42910
- 500+0.25830
- 1200+0.24420
- 国内价格
- 20+0.15614
- 200+0.14552
- 500+0.13490
- 1000+0.12428
- 3000+0.11897
- 6000+0.11153
