NIDEC CORPORATION
Robot Cleaner Motor Product Introduction
DTC (Dalian Technical & Support Center)
2020/09/18
Robot Cleaner – Blower Unit
Blower
(Standard product)
20N183L010 A
20N704R310
20N704R500
20N704S310
22N709Q140
Appearance feature
With fixing device
With fixing device
Without fixing
device
Without fixing
device
Without fixing
device
Voltage[V]
12
14.4
14.4
14.4
14.4
Input power[W]
31.7
23
64.8
Rated speed [rpm]
15000
17200
17200
15100
22500
Rated current [A]
1.7
2.2
2.2
1.6
4.5
Maximum static
pressure [Pa]
1800
2600
2600
3000
4000
Maximum air volume
[m3/min]
0.63
0.78
0.78
0.63
0.99
Noise[dB (A) ]
67
70
70
68
75
1/16
20N183L010 A
P1: Input power P2: Output Power η: Effectiveness R: Rotating speed h: Static pressure
Item
Rated voltage
(V)
Rated speed
(rpm)
Rated current
(A)
Rated power
(W)
Maximum
static pressure
(kPa)
Maximum air
volume
(m3/min)
SPL noise
(dB (A) )
Parameter
12
15000
1.7
0.63
67
2/16
20N704R310
(20N704R500)
Item
Rated voltage
(V)
Rated speed
(rpm)
Rated current
(A)
Rated power
(W)
Maximum static
pressure
(kPa)
Maximum air
volume
(m3/min)
SPL noise
(dB (A) )
Parameter
14.4
17200
2.2
32
2.6
0.78
70
3/16
20N704S310
Item
Rated voltage
(V)
Rated speed
(rpm)
Rated current
(A)
Rated power
(W)
Maximum static
pressure
(kPa)
Maximum air
volume
(m3/min)
SPL noise
(dB (A) )
Parameter
14.4
15100
1.6
23
3
0.63
68
4/16
22N709Q140
Item
Rated voltage
(V)
Rated speed
(rpm)
Rated current
(A)
Rated power
(W)
Maximum static
pressure
(kPa)
Maximum air
volume
(m3/min)
SPL noise
(dB (A) )
Parameter
14.4
22500
4.5
64.8
4
0.99
75
5/16
Robot Cleaner – Motor for Blower
20N704K500 B
20N704P110 A
22N709P230 D
35N048P010
Rotor outer diameter
[mm]
Φ25
Φ25
Φ27
Φ44.3
Motor height [mm]
13.4
13.4
18.6
26.8
Voltage [V]
12
13
14.4
18
No-load speed
[rpm]
16500
23000
29000
28800
No-load current
[A]
0.4
0.5
0.6
0.8
Function
PWM/FG
PWM/FG
PWM/FG/SS
PWM/FG
Blower
(Standard product)
6/16
20N704K500 B
Item
Rated voltage
(V)
No-load speed
(rpm)
No-load current
(A)
Rated speed
(rpm)
Rated current
(A)
Maximum power
(W)
SPL noise
(dB (A) )
Parameter
12
16500
0.4
13500
1.4
15.9
40
7/16
20N704P110 A
Item
Rated voltage
(V)
No-load speed
(rpm)
No-load current
(A)
Rated speed
(rpm)
Rated current
(A)
Maximum power
(W)
SPL noise
(dB (A) )
Parameter
13
23000
0.6
16700
1.75
21.2
50
8/16
22N709P230 D
Item
Rated voltage
(V)
No-load speed
(rpm)
No-load current
(A)
Rated speed
(rpm)
Rated current
(A)
Maximum power
(W)
SPL noise
(dB (A) )
Parameter
14.4
29000
0.6
24800
2.8
58.4
65
9/16
35N048P010
Item
Rated voltage
(V)
No-load speed
(rpm)
No-load current
(A)
Rated speed
(rpm)
Rated current
(A)
Maximum power
(W)
SPL noise
(dB (A) )
Parameter
18
28800
0.8
25900
7.1
274
60
10/16
Robot Cleaner - Motor for Wheel
20N704RC70
In development
Item
Rated voltage
(V)
No-load speed
(rpm)
No-load current
(A)
Rated speed
(rpm)
Rated current
(A)
Maximum power
(W)
SPL noise
(dB (A) )
Parameter
14.4
16800
0.4
13200
1.4
13.8
45
11/16
20N275M020
Item
Rated voltage
(V)
No-load speed
(rpm)
No-load current
(A)
Rated speed
(rpm)
Rated current
(A)
Maximum power
(W)
SPL noise
(dB (A) )
Parameter
18
18000
0.3
14500
1.1
21.8
40
12/16
Robot Cleaner - Motor for Brush
22N704RC80
In development
Item
Rated voltage
(V)
No-load speed
(rpm)
No-load current
(A)
Rated speed
(rpm)
Rated current
(A)
Maximum power
(W)
SPL noise
(dB (A) )
Parameter
14.4
18000
0.4
14300
1.6
26
45
13/16
Robot Cleaner – Motor for LDS
24N (LDS)
In development
Item
Rated voltage
(V)
No-load speed
(rpm)
No-load current
(A)
Rated speed
(rpm)
Rated current
(A)
Maximum power
(W)
SPL noise
(dB (A) )
Parameter
5
9500
0.1
7400
0.5
4
30
14/16
Robot Cleaner – Motor for LDS & Side brush
24N704S040
In development
Item
Rated voltage
(V)
No-load speed
(rpm)
No-load current
(A)
Rated speed
(rpm)
Rated current
(A)
Maximum power
(W)
SPL noise
(dB (A) )
Parameter
14.4
9350
0.15
7680
0.6
7.3
30
15/16
Robot Cleaner - Motor for Mop drive
20N709R050/R050 N
Item
Rated voltage
(V)
No-load speed
(rpm)
No-load current
(A)
Rated speed
(rpm)
Rated current
(A)
Maximum power
(W)
SPL noise
(dB (A) )
Parameter
12
12600
0.3
10000
0.8
6.3
40
16/16
很抱歉,暂时无法提供与“20N(Blower)”相匹配的价格&库存,您可以联系我们找货
