MC1206B102K202CT
MC1206B102K202CT
    MULTICOMP
    贴片电容(MLCC) 1206 1nF ±10% 2KV X7R
MC1206B102K202CT 数据手册
Middle and High Voltage Multilayer Ceramic Capacitors 200V to 3kV (NP0, X7R & Y5V Dielectrics) Description: The middle and high voltage series MLCC is designed by a special internal electrode pattern, which can reduce voltage concentrations by distributing voltage gradients throughout the entire capacitor. This special design also affords increased capacitance values in a given case size and voltage rating. Chips size 1206 and larger to use on reflow soldering process only. Capacitors with X7R dielectrics are not intended for AC line filtering applications. Capacitors may require protective surface coating to prevent external arcing. Features: Applications: •  High voltage in a given case size. •  High stability and reliability. •  •  •  •  How To Order: MC  nubbers in high frequency power converters. S High voltage coupling/DC blocking. DC-DC converters. Back-lighting inverters 1808 N 100 J 202 C T Size Dielectric Capacitance Tolerance Rated Voltage Termination Packaging style N=NP0 (C0G) B=X7R F=Y5V Two significant digits followed by no. of zeros. And R is in place of decimal point. B = ±0.1pF C = ±0.25pF D = ±0.5pF F = ±1% G = ±2% J = ±5% K = ±10% M = ±20% Z = -20/+80% Inch (mm) 0603 (1608) 0805 (2012) 1206 (3216) 1210 (3225) 1808 (4520) Multicomp 1812 (4532) eg.: 0R5 = 0.5pF 1R0 = 1.0pF 100 = 10x100 = 10pF Two significant C = Cu/Ni/Sn T=7” reeled digits followed by (for NP0, X7R, G=13” reeled no. of zeros. Y5V dielectric) And R is in place of decimal point. 201 = 200V DC 251 = 250V DC 501 = 500V DC 631 = 630V DC 102 = 1,000V DC 202 = 2,000V DC 252 = 2,500V DC 302 = 3,000V DC * Partial NP0 items are with Ag/Ni/Sn terminations, please ref to below product range of NP0 dielectric for detail. External Dimensions: Size Inch (mm) L (mm) W (mm) T (mm)/Symbol Remark 1.6±0.1 0.8±0.1 0.8±0.07 S 0603(1608) 1.6 +0.15/-0.1 0.8 +0.15/-0.1 0.8 +0.15/-0.1 X 0.6±0.1 A 0805 (2012) 2±0.15 1.25±0.1 0.8 ±0.1 B 1.25±0.1 D # 0.80±0.1 B - 0.95±0.1 C - 1.25±0.1 D # 1.6±0.2 G # The outline of MLCC 1206 (3216) 3.20±0.15 3.20±0.2 1.6±0.15 1.6±0.2 MB (mm) 0.4±0.15 0.5 ±0.2 0.6 ±0.2 (0.5±0.25)* Newark.com/multicomp-pro Farnell.com/multicomp-pro Element14.com/multicomp-pro Page 05/09/19 V1.1 Middle and High Voltage Multilayer Ceramic Capacitors 200V to 3kV (NP0, X7R & Y5V Dielectrics) Size Inch (mm) L (mm) W (mm) 3.2±0.3 2.5±0.2 T (mm)/Symbol 0.95±0.1 1210 (3225) 3.2±0.4 1808 (4520) 1812 (4532) 4.5+0.5/0.3 2.5±0.3 2.03±0.25 4.5+0.5/0.3 3.2±0.3 3.2±0.4 Remark C # 1.25±0.1 D # 1.6±0.2 G # 2 ±0.2 K # 2.5±0.3 M # 1.25±0.1 D # 2±0.2 K # 1.25±0.1 D # 1.6±0.2 G # 2±0.20 K # 2.5±0.3 M # 2.80±0.3 U # MB (mm) 0.75±0.25 0.5±0.25 0.5±0.25 # Reflow soldering only is recommended. * For 1206_1,000V ~3,000V products. General Electrical Data: Dielectric Size Capacitance* Capacitance tolerance*** NP0 0603, 0805, 1206, 1210, 1808, 1812 Insulation resistance at Ur** 0.01μF to 0.68μF Cap≤5pF: C (±0.25pF) 5pF
MC1206B102K202CT 价格&库存
很抱歉,暂时无法提供与“MC1206B102K202CT”相匹配的价格&库存,您可以联系我们找货
