SF51G THRU SF58G
Reverse Voltage - 50 to 600 Volts
Forward Current - 5.0 Ampere
SUPER FAST GLASS PASSIVATED RECTIFIER
Features
DO-201AD
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Idea for printed circuit board
1.0 (25.4)
MIN.
Super fast switching for high efficiency
Low reverse leakage
High forward surge current capability
0.220(5.6)
0.197(5.0)
DIA.
High temperature soldering guaranteed:
0.375(9.5)
0.285(7.2)
250℃/ 10 seconds at terminals
Mechanical Data
1.0 (25.4)
MIN.
Case : JEDEC DO-201AD Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.04 ounce, 1.10 grams
0.052(1.3)
0.048(1.2)
DIA.
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
V RMS
V DC
Maximum average forward rectified current
at TA=55℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current
TA=25℃
at rated DC blocking voltage
TA=100℃
Maximum reverse recovery time
SF53G
SF54G
SF55G
SF56G
SF58G
MDD
SF51G
MDD
SF52G
MDD
SF53G
MDD
SF54G
MDD
SF55G
MDD
SF56G
MDD
SF58G
50
100
70
100
150
105
150
200
140
200
300
210
300
400
280
400
600
420
600
35
50
UNITS
V
V
V
5.0
A
IFSM
150.0
A
0.95
1.25
10.0
50.0
IR
100.0
1.7
V
μA
35
trr
CJ
Typical junction capacitance (NOTE 2)
Operating junction and storage temperature range
SF52G
I(AV)
VF
(NOTE 1)
Typical thermal resistance (NOTE 3)
SF51G
ns
50.0
pF
RθJA
30.0
℃/W
TJ,T STG
-65 to +150
Note: 1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
DN:T20526A0
http://www.microdiode.com
Rev:2020A0
Page :1
SF51G THRU SF58G
FIG. 1- FORWARD CURRENT DERATING CURVE
5
4
3
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
2
1
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
150
125
100
75
50
175
25
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
SF51G-SF54G
SF55G-SF56G
SF58G
0.01
0.8
1.2
1.6
1.8
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
10
1,000
100
10
TJ=25 C
0.1
0.01
60
80
100
400
TJ=25 C
SF51G-SF54G
SF55G-SF58G
TRANSIENT THERMAL IMPEDANCE,
C/W
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
TJ=100 C
1
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
200
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
2
0.1
1.0
10
100
t,PULSE DURATION,sec.
REVERSE VOLTAGE,VOLTS
The curve above is for reference only.
Rev:2020A0
Page :2
SF51G THRU SF58G
Package Information
Taping Specifications
Item
Symbol
Specifications(mm)
Component Pitch
A
10.0±0.5
Inner Tape Pitch
B
52.4±1.5
Component alignment
Z
1.2 Max
Tape width
T
6.0±0.5
Exposed adhesive
E
0.8 Max
Body eccentricity
L1-L2
1.0 Max
Ammunition Package Specifications
Package
Inner Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
DO - 201AD
255*74*145
1000
410*275*340
10000
Bulk Package Specifications
Package
Inner Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
DO - 201AD
198*86*21
200
460*220*250
10000
Important Notice and Disclaimer
Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the latest product information and
specifications before final design,purchase or use.
Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its
products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application
assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with
products which are purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode
Electronics (Jiangsu).
Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support
devices or systems without express written approval of Microdiode Electronics (Jiangsu).
Rev:2020A0
Page :3
很抱歉,暂时无法提供与“SF56”相匹配的价格&库存,您可以联系我们找货
