SMD-5032_2P 8M 20PF 30PPM
    YJX(雅晶鑫)
    SMD5032_2P
    无源晶振 8MHz 20pF - ±20ppm -40℃~+85℃ SMD5032_2P
SMD-5032_2P 8M 20PF 30PPM 数据手册
深 圳 市 雅 晶 鑫 有 限 公 司 Shenzhen Yajingxin Electron Co.,Ltd SPECIFICATION FOR APPROVAL 0.00 CUSTOMER NOMINAL FREQUENCY 8~50MHZ HOLDER TYPE SMD-5032-2PIN SPEC. NO. ( P/N ) CUSTOMER P/N ISSUE DATE APPROVED Aug.3,2016 PREPARED APPROVED BY CUSTOMER: Please return one copy with approval toHLC H0-R-4-014 QA AVL Status TYPE HF SEAM SEALED X'TAL ELECTRICAL SPECIFICATIONS HLC Parts Number : Item Symbol Specifications Min Type 8~50 Max Notes Units Nominal frequency FO Mode of Oscillation OT Load Capacitance LC 20 pF Frequency Tolerance FT ± 20 ppm at 25℃ ± 3℃ ± 30 ppm with working temperature Reference to 25℃ Frequency Stability MHz Fundamental Working temperature range TR -40~85 ℃ Drive Level DL 100 µW Series Resonant Resistance RR CI/RR Shunt Capacitance C0 Aging Storage temperature range Unit Weight C0 Ω 7 pF ±3 ppm/yr. -55 ~ 125 ℃ g Shenzhen Yajingxin Electron Co.,Ltd H0-R-4-014 Max. Shenzhen Yajingxin Electron Co.,Ltd MARKING 中性 CODE N O P 20 pF 22 pF 24 pF Shenzhen Yajingxin Electron Co.,Ltd H0-R-4-014 TYPE HF SEAM SEALED X'TAL RELIABILITY SPECIFICATIONS NO. TEST ITEM TEST METHODS 1 DROP TEST Device are dropped from a height of 150 cm onto 2 mm thickness stainless plate executing 3 times of random drops. 2 MECHANICAL SHOCK Device are shocked to half sine wave (1000 G) three mutually perpendicular axes each 3 times. 3 VIBRATION Frequency range Amplitude Sweep Time Test Time 4 SOLDERABILITY MIL - STD - 20E Method 208C Temperature 245℃±5℃ Material H63A (Silver 2 ~ 3 %) Immersion depth 0.5 mm minimum Immersion time 3 ± 0.5 seconds Flux Rosin resin methyl alcohol solvent ( 1 : 4 ) 5 RESISTANCE TO SOLDERING HEAT MIL - SLD -202, Method 210, Condition I or J 10 sec immersion into 260 ± 5℃ solder pot, above 180℃ is 90 ~ 120 sec. 6 LOW TEMP. STORAGE Leave at - 55 ℃ ± 2℃ for 1000 ± 12 hours 7 HIGH TEMP. STORAGE Leave at 125 ℃ ± 2℃ for 1000 ± 12 hours 8 THERMAL SHOCK Total 100 cycles of the following temperature cycle 10 ~ 2000 Hz 1.5 mm 20 minute 2 hours 1 cycle 125 ℃ ± 3 ℃ 25 ℃ 30 min - 55 ℃ ± 3 ℃ 30 min 10 min Shenzhen Yajingxin Electron Co.,Ltd H0-R-4-014 TYPE HF SEAM SEALED X'TAL DIMENSIONS Shenzhen Yajingxin Electron Co.,Ltd H0-R-4-014 TYPE HF SEAM SEALED X'TAL SUGGESTED IR REFLOW PROFILE Total Time:200 Sec.Max Solder melting point :185℃ PACKING 1. 230mm minimum leafer which consist of carrier and/or tape followed by a minimum of 160mm of empty carrier tape sealed with cover tape. 2. 160mm minimum trailer of empty carrier tape sealed with cover tape. Shenzhen Yajingxin Electron Co.,Ltd H0-R-4-014 TYPE HF SEAM SEALED X'TAL PACKING Begin Close Start LABEL 1000pcs-Product Tape End inner packing carton blue qualified label storeroom label storeroom label storeroom label deliver packing carton (L29*W24*H30) Green qualified label Shenzhen Yajingxin Electron Co.,Ltd H0-R-4-014
SMD-5032_2P 8M 20PF 30PPM 价格&库存
很抱歉,暂时无法提供与“SMD-5032_2P 8M 20PF 30PPM”相匹配的价格&库存,您可以联系我们找货
  • 1+1.05001
  • 30+1.01251
  • 100+0.93751
  • 500+0.86250
  • 1000+0.82500
库存:9904
