1.70±0.15
Circuit 1
01
Specifications :
Voltage rating: 250V AC / DC
Current rating: 3A AC / DC
Withstanding voltage: 800V AC/minute
Temperature range: -25°C~+85°C
Insulation resistance:≥1000MΩ
Contact resistance: ≤10mΩ
After environmental testing:≤20mΩ
02
B±0.30
11
03
5.20
04
07
08
6.00±0.30
4.60
0.64±0.10
3.30±0.25
3.90±0.25
09
0.90±0.10
0.90±0.10
With Kink
With Reverse Kink
10
0.90±0.10
2.50±0.10 05
A±0.25
06
2.50±0.10
90
Ø 0.
±0.1
X2581 W V X- XX X-N0 SN XX
1
PART N0
Nylon 66 UL 94V-0
Material
Brass
Tin-Plated
3
4
5
6
7
8
9
1
Series No.
2
Category:W-Wafer
3
Welding Board Angle:V-180° ; R-90°
4
Welding Way: Blank-DIP ; S-SMT
5
Row No.-Pin No.: XX-Single Row ; 2*XX-Double Row
6
Plug the Pin & Special No. : Blank-With Kink
Poles
A-Without Kink ; B-With Reverse Kink
7
Material: N0 -PA66 94V-0
8
Plating Category: G**-Gold Plated Contact
V**- All Gold-Plated
01-Gold Flash 02-2u" 03-3u"
05-5u" 10-10u" 15-15u"
SN-Bright Tin Plating (70u")
SN1-Bright Tin Plating (120u" Min).
0-No Plating Material
SW- Fog Tin Plating
HS-Hight temperature Tin
9
Color : Blank-Natural Color
Recommand PCB Layout
X2581WV-XXX-N0SN
2
X2581H
Material(Pin) Finish(Pin) Mates With XKB Housing
02
03
04
05
06
07
08
09
10
11
12
13
14
15
Without Kink
Dimensions (mm)
A
2.50
5.00
7.50
10.00
12.50
15.00
17.50
20.00
22.50
25.00
27.50
30.00
32.50
35.00
B
7.50
10.00
12.50
15.00
17.50
20.00
22.50
25.00
27.50
30.00
32.50
35.00
37.50
40.00
X2581WV-XXX-N0SN
2.50 mm Crimp Style connectors
XKB INDUSTRIAL PRECISION CO.,LIMITED
很抱歉,暂时无法提供与“X2581WV-02-N0SN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.04800
- 100+0.04520
- 1000+0.04320
- 国内价格
- 50+0.09742
- 500+0.07766
- 2000+0.06048
- 4000+0.05390
- 24000+0.04828
- 50000+0.04515
