DV Series
Chip type
Features
ZV
◆ Chip type ,Low impedance
◆ Chip type with load life of 2000 hours at +105℃
◆ Designed for surface mounting on high density PC board
◆ Applicable to automatic mounting machine using carrier tape
◆ Complied to the RoHS directive
◆ For detail specifications, please refer to Engineering Bulletin NO. E173
DV
Low Impedance
SMD
DV Series
Specifications
Item
Operating Temperature Range
Rated Voltage Range
Capacitance Range
Capacitance Tolerance
Leakage Current (+20℃,max.)
Performance Characteristics
-55~ +105℃
6.3~50 VDC
1 to 1500μF
±20%(120Hz,+20℃)
I≦0.01 CV or 3 (μA)After 2 minutes whichever is greater measured with rated working voltage applied.
Dissipation Factor
(tanδ,at 20℃,120Hz)
Working voltage(VDC)
D.F. (%) max.
6.3
24
10
19
16
16
25
14
35
14
50
12
6.3
2
8
10
2
6
16
2
4
25
2
4
35
2
3
50
2
3
Impedance ratio max
Low Temperature Characteristics
(at 120Hz)
Load Life
Shelf Life
Z-25℃ Z+20℃
Z-55℃ Z+20℃
Test conditions
Duration time
Ambient temperature
Applied voltage
:2000 Hrs
:+105℃
:Rated DC working voltage
After test requirement at +20℃ :
Capacitance change
:Within ±30% of initial value
Dissipation factor
:Less than 300% of specified value
Leakage current
:Less than specified value
Test conditions
Duration time
:1000 Hrs
Ambient temperature
:+105℃
Applied voltage
:None
After test requirement at +20℃ : Same limits as Load life.
Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes.
The following specifications shall be satisfied when the capacitors are restored to20℃ after exposing them
at 250℃ for 30 seconds.
Resistance to soldering heat
Leakage current
Capacitance change
Within ±10% of initial value
tanδ
Multiplier for Ripple Current vs. Frequency
CAP(μF) Frequency(Hz) 60(50) 120
0.47 0.59
CAP≦10
0.52 0.65
10<CAP≦100
400
0.76
0.80
1K
0.85
0.89
10K 50K-100K
0.97
1.0
0.97
1.0
Diagram of Dimensions:(unit:mm)
φD
4
5
6.3
6.3
8
8
10
71
L
A
B
C
5.5 4.3 4.3 4.9
5.5 5.3 5.3 5.9
5.5 6.6 6.6 7.2
7.7 6.6 6.6 7.2
6.5 8.3 8.3 9.0
10.5 8.3 8.3 9.0
10.5 10.3 10.3 11.0
W
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.7~1.1
0.7~1.1
P
1.0
1.4
2.2
2.2
2.3
3.1
4.5
DV Series
Case Size
φDxL(mm)
WV
6.3
(8)
(SV)
Cap
(µF)
Size
10
(13)
Ripple Impedance
Size
16
(20)
Ripple Impedance
Size
25
(32)
Ripple Impedance
1.0
2.2
3.3
4.7
6.8
Size
35
(44)
Ripple Impedance
4X5.5
70
2.8
Size
50
(63)
Ripple Impedance
Size
Ripple Impedance
4X5.5
4X5.5
4X5.5
4X5.5
5X5.5
5X5.5
6.3X5.5
6.3X5.5
55
55
55
55
75
95
130
140
4.5
4.5
4.5
4.5
3.8
2.8
2.2
1.6
4X5.5
4X5.5
4X5.5
4X5.5
5X5.5
5X5.5
5X5.5
6.3X5.5
6.3X5.5
6.3X5.5
8X6.5
6.3X5.5
8X6.5
6.3X7.7
80
85
88
90
125
140
155
170
210
230
260
240
250
250
2.8
2.3
2.2
2.0
1.4
1.2
1.1
1.05
0.6
0.54
0.51
0.53
0.49
0.49
6.3X5.5
150
1.3
6.3X7.7
6.3X7.7
8X6.5
6.3X7.7
8X6.5
8X10.5
180
190
200
230
240
300
1.2
0.71
0.7
0.7
0.69
0.52
6.3X7.7
265
0.4
8X10.5
320
0.5
6.3X7.7
8X10.5
300
420
0.38
0.28
8X10.5
350
0.46
10
4X5.5
80
2.2
4X5.5
85
2.1
15
4X5.5
4X5.5
5X5.5
5X5.5
85
90
140
170
2.0
1.98
1.2
0.74
6.3X5.5
185
0.6
5X5.5
6.3X5.5
6.3X5.5
6.3X5.5
8X6.5
195
210
220
230
240
1.05
0.58
0.56
0.54
0.50
5X5.5
5X5.5
6.3X5.5
6.3X5.5
5X5.5
6.3X5.5
6.3X5.5
6.3X7.7
6.3X5.5
6.3X5.5
8X6.5
6.3X7.7
8X6.5
125
145
160
200
160
220
220
230
230
240
260
290
300
1.9
1.2
1.15
0.62
1.05
0.58
0.56
0.54
0.54
0.48
0.45
0.38
0.36
8X10.5
480
0.25
8X10.5
510
0.24
10X10.5
600
0.25
8X10.5
530
0.22
8X10.5
570
0.21
10X10.5
650
0.23
10X10.5
650
0.15
22
27
4X5.5
4X5.5
4X5.5
33
5X5.5
4X5.5
47
5X5.5
56
5X5.5
5X5.5
68
6.3X5.5
5X5.5
100
6.3X5.5
6.3X5.5
150
8X6.5
6.3X5.5
220
6.3X7.7
6.3X7.7
330
8X6.5
470 8X10.5
680 8X10.5
8X10.5
1000
10X10.5
1200 10X10.5
1500 10X10.5
75
2.2
4X5.5
80
2.2
79
82
130
86
150
150
160
220
170
230
235
250
240
260
275
290
450
500
530
570
600
650
1.98
1.9
1.3
1.88
1.1
1.10
0.9
0.55
0.8
0.53
0.51
0.48
0.48
0.45
0.36
0.34
0.28
0.25
0.20
0.17
0.16
0.13
5X5.5
4X5.5
5X5.5
5X5.5
6.3X5.5
6.3X5.5
125
90
150
165
180
210
1.9
1.85
1.2
1.1
0.59
0.57
6.3X5.5
220
0.55
6.3X5.5
240
0.53
6.3X5.5
255
0.52
6.3X5.5
8X6.5
6.3X7.7
8X6.5
250
260
270
285
0.49
0.47
0.44
0.40
6.3X7.7
8X6.5
6.3X7.7
8X6.5
265
270
275
285
0.45
0.44
0.43
0.41
8X10.5
500
0.25
8X10.5
550
0.25
8X10.5
570
0.2
8X10.5
10X10.5
550
680
0.25
0.2
8X10.5
10X10.5
590
720
0.22
0.16
10X10.5
650
0.15
10X10.5
740
0.15
Ripple Current ( mA, rms ) at 105℃ 100KHz
Max Impedance (Ω) at 20℃ 100 KHz
72
很抱歉,暂时无法提供与“DV101M6R3E055ETR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.74170
- 100+0.44250
- 500+0.30980
- 1000+0.22130
- 2000+0.21020
- 10000+0.19470
