RMCF1210JT33R0
RMCF1210JT33R0
    SEI
    贴片电阻 1210 33Ω ±5% 1/2W ±200ppm/℃
RMCF1210JT33R0 数据手册
RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Features: • • • • • • RMCF – standard power ratings RMCP – high power ratings Nickel barrier terminations standard Power derating from 100% at 70 ºC to zero at +155 ºC AEC-Q200 Compliant (except RMCP0201) RoHS compliant and halogen free Electrical Specifications - RMCF Type / Code Power Rating @ 70ºC (Watts) Maximum Working Voltage (1) Maximum Overload Voltage Max. Jumper Current (Amp) RMCF01005 0.03 W 15 V 30 V 0.5 A RMCF0201 0.05 W 25 V 50 V 0.5 A RMCF0402 0.063 W 50 V 100 V 1A RMCF0603 0.1 W 75 V 150 V 1A RMCF0805 0.125 W 150 V 300 V 2A RMCF1206 0.25 W 200 V 400 V 2A RMCF1210 0.33 W (3) 200 V 400 V 3A RMCF2010 0.75 W 200 V 400 V 3A RMCF2512 1W 200 V 400 V 3A Resistance Temperature Coefficient Ohmic Range (Ω) and Tolerance (2) ± 300 ppm/ºC ± 200 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 500 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC 10 - 97.6 100 - 1 M 1 - 9.76 10 - 10 M 1% 5% 1 - 9.76 (4) 10 - 1 M 1.02 M - 10 M 1.1 M - 20 M 0.1 - 0.499 0.5 - 0.976 1 - 9.76 1 - 20 M 10 - 1 M 1.02 M - 10 M 0.1 - 9.76 0.1 - 20 M 10 - 1 M 1.02 M - 10 M 0.1 - 9.76 0.1 - 20 M 10 - 1 M 1.02 M - 10 M 0.1 - 0.976 1 - 9.76 10 - 20 M 10 - 10 M 0.1 - 0.976 1 - 9.76 10 - 10 M 10 - 10 M 0.1 - 0.976 1 - 9.76 10 - 10 M 10 - 10 M - Notes: (1) Lesser of √ P * R or maximum working voltage (2) Contact factory for extended ohmic values (3) Power rating is 0.5 W for ohmic values 1 K Ω and below (4) Contact factory for lower ohmic values Rev Date: 01/10/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Electrical Specifications - RMCP Type / Code Power Rating @ 70ºC (Watts) Maximum Working (1) Voltage Maximum Overload Voltage Max. Jumper Current (Amp) RMCP0201 0.063 25 50 1 RMCP0402 0.125 50 100 1.5 RMCP0603 0.25 75 150 2 RMCP0805 0.33 150 300 2.5 RMCP1206 0.33 200 400 3.5 RMCP1210 0.5 200 400 5 RMCP2010 1 200 400 6 RMCP2512 2 250 500 7 Resistance Temperature Coefficient Ohmic Range (Ω) and Tolerance (2) 1%, 5% 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M -200/+400 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC Notes: (1) Lesser of √ P * R or maximum working voltage (2) Contact factory for extended ohmic values Mechanical Specifications Type / Code Average Unit Weight (mg) RMCF01005 0.07 RMCF0201 RMCP0201 RMCF0402 RMCP0402 RMCF0603 RMCP0603 RMCF0805 RMCP0805 RMCF1206 RMCP1206 RMCF1210 RMCP1210 RMCF2010 RMCP2010 RMCF2512 RMCP2512 0.16 0.57 0.62 1.88 2.04 5.00 4.37 8.86 8.95 15.55 15.96 23.56 24.24 40.02 39.45 L Body Length 0.016 ± 0.0008 0.40 ± 0.02 0.024 ± 0.0012 0.60 ± 0.03 0.039 ± 0.004 1.00 ± 0.10 0.061 ± 0.006 1.55 ± 0.15 0.079 ± 0.008 2.00 ± 0.20 0.126 ± 0.010 3.20 ± 0.25 0.126 ± 0.010 3.20 ± 0.25 0.197 ± 0.008 5.00 ± 0.20 0.248 ± 0.008 6.30 ± 0.20 Rev Date: 01/10/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. W Body Width 0.008 ± 0.0008 0.20 ± 0.02 0.012 ± 0.0012 0.30 ± 0.03 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.006 0.80 ± 0.15 0.049 ± 0.004 1.25 ± 0.10 0.063 ± 0.006 1.60 ± 0.15 0.098 ± 0.010 2.50 ± 0.25 0.098 ± 0.008 2.50 ± 0.20 0.126 ± 0.010 3.20 ± 0.25 2 H Body Height 0.005 ± 0.0008 0.13 ± 0.02 0.009 ± 0.0012 0.23 ± 0.03 0.012 ± 0.002 0.30 ± 0.05 0.018 ± 0.004 0.45 ± 0.10 0.020 ± 0.006 0.50 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 a Top Termination 0.004 ± 0.0012 0.10 ± 0.03 0.006 ± 0.002 0.15 ± 0.05 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.014 ± 0.010 0.35 ± 0.25 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.012 0.50 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 b Bottom Termination 0.004 ± 0.0012 0.10 ± 0.03 0.006 ± 0.002 0.15 ± 0.05 0.010 ± 0.006 0.25 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.014 ± 0.010 0.35 ± 0.25 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.012 0.50 ± 0.30 0.024 ± 0.014 0.60 ± 0.35 0.024 ± 0.014 0.60 ± 0.35 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Performance Characteristics Test Test Specifications Test Conditions (JIS-C 5202) Short Time Overload Dielectric Withstanding Voltage Resistance to Soldering Heat Solderability ± (2% + 0.1 Ω) No flashover or breakdown ± 1% 95% coverage, minimum Temperature Cycle ± (1% + 0.05 Ω) Jumper (< 0.05 Ω) 2.5 X rated voltage for 5 seconds 100 VAC, 1 minute 260 ºC ± 5 ºC, for 10 seconds ± 0.5 seconds (Solder Bath) 235ºC ± 5ºC, for 2 seconds ±0.5 seconds (Colophonium flux) -65 ºC: 30 minutes 25 ºC: 2 to 3 minutes 155 ºC: 30 minutes 25 ºC: 2 to 3 minutes (5 Cycles) 40 ºC ± 2 ºC, 90% RH, Rated Load 90 minutes On, 30 minutes Off for 1000 hours -0 hour / +48hours ± (3% + 0.1 Ω) Jumper (
RMCF1210JT33R0 价格&库存
很抱歉,暂时无法提供与“RMCF1210JT33R0”相匹配的价格&库存,您可以联系我们找货
RMCF1210JT33R0
    RMCF1210JT33R0
    • 10+0.49157
    • 100+0.44578
    • 500+0.39998
    • 1000+0.35418
    • 2000+0.32365
    • 4000+0.31449
    库存:29
    RMCF1210JT33R0
    • 4000+0.143424000+0.01848
    • 8000+0.131258000+0.01691
    • 12000+0.1253412000+0.01615
    • 20000+0.1189420000+0.01533
    • 28000+0.1152828000+0.01485
    • 40000+0.1118140000+0.01441
    库存:29009
    RMCF1210JT33R0
    • 1+1.154321+0.14872
    • 10+0.5301410+0.06830
    • 25+0.4100025+0.05283
    • 50+0.3411750+0.04396
    • 100+0.28730100+0.03702
    • 250+0.23335250+0.03007
    • 500+0.20259500+0.02610
    • 1000+0.178101000+0.02295
    库存:29009
