ICSRC6508SFR
ICSRC6508SFR
    ICT
    夹子/挂钩 6.5x0.8mm EMI 6.50 x 0.80mm
ICSRC6508SFR 数据手册
0,8 0,4 0,15 신신 제제 C 인인인 인인 인제 +0.1 -0.05 SHIELD CASE THICKNESS 0.2±0.02 => 0.2 +0.02 -0 4 ±0.1 APPROVED 2009.10.05 P.K.KO 2012.02.15 P.K.KO P.K.KOH 2012.03.30 TAPING 사양도 (SCALE 3/1) 2 ±0.05 DATE O 1,55 +0.1 0 0,3 16 7,5 ±0.1 1,4 3,25 1,75 ±0.1 0,7 1,85 0,5 6,5 1 1,21 A B NOTES 4 ±0.1 1. MATERIAL : SUS301 2. MATERIAL THICKNESS :0.15t 3. FINISHED : Sn(100%) PLATING ON BOTH SIDE ( Ni 0.5㎛ Sn1.27㎛ ) 4. PACKING MATERIALS. - REEL : HIPS 0.3t - COVER TAPE : PS _ Q'TY/REEL : 10,000ea 5. AVAILABLE SHIELD CASE THICKNESS : 0.2 +0.02 -0 6. CONTACT RESISTANE 300mmΩ MAX 7. INTENTION FORCE/RETENTION FORCE SPEC 0,8 0,78 0,15 +0.02 -0.05 REV REVISION HISTORY DESCRIPTION +0.1 -0.05 0,72 SCALE : 15/1 SPEC 1,5 INTENTION FORCE RETENTION FORCE MAX 1.0Kg MIN 0.3Kg 8.STENCIL THICKNESS : 0.12T 6,7 1 1,1 0,8 0,9 1,1 6,4 RECOMMENDED PCB LAYOUT RECOMMENDED STENCIL LAY-OUT 0.1T 9. Maintain 90˚±3 while engage & disengage shield can & shield clip to prevent deformation & to maintain retention force of shield clip UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE ANGLES ± 0. 3° 0 ~ 1 ± 0.05 1 ~ 5 ± 0.1 5 ~ 10 ± 0.15 TITLE SIZE DWG NO SHILED CLIP A3 ICSRC6508SFR FILE NAME: ICSRC6508SFR.dft SCALE: WEIGHT: SHEET 1 OF 1 REV C
ICSRC6508SFR 价格&库存
很抱歉,暂时无法提供与“ICSRC6508SFR”相匹配的价格&库存,您可以联系我们找货
ICSRC6508SFR
    • 20+0.12880
    • 200+0.12130
    • 10000+0.10250
    • 20000+0.09880
    库存:22417
    ICSRC6508SFR
    • 20+0.12801
    • 200+0.12001
    • 600+0.11201
    • 3000+0.10401
    库存:81366
    ICSRC6508SFR
      库存:22417
