ITEM
P/N
Page
COMMON MODE ESD FILTER
ICMEF112P900MFR
1
Data Sheet
- ITEM
- PART NO
ICMEF112P900MFR
- CONDITION : 1.
2.
3.
4.
ITEM
P/N
Page
ICMEF112P900MFR
2
1. Generals
This specification covers the engineering requirements for the ICMEF112P900MFR
(Common Mode ESD Filter)
2 Features
2.
Effective for suppressing common mode noise and almost no effect for high speed differential
data line
One common mode filters and two ESD suppression devices integrated
Ultra low profile (1
(1.27ⅹ1.00ⅹ0.60mm)
27ⅹ1 00ⅹ0 60mm)
Ceramic multilayer type SMD component
Non-polarized product
It is a product conforming to RoHS directive.
3. Applications
LVDS lines in notebook computers
y PC, Audio p
player,
y DSC
USB2.0, IEEE1394, DVI, HDMI lines in PDP, LCD TV, DVD Player,
MDDI, MIPI in mobile phone
4. Product specifications
4 1 PART NUMBER CODE
4.
ICMEF
①
11
②
2P
③
900
④
M
⑤
F
⑥
R
⑦
① Series name of ICT’s Common Mode ESD Filter
② Dimensions, 1.27mm (L) ⅹ 1.0mm (W)
③ Number of lines
lines, 2P
2P= 2 lines
④ Common Mode Impedance (at 100MHz), 900= 90Ω
⑤ Tolerance of common mode impedance, M= ±25%
⑥ Type of electrode plating: F= Lead Free
⑦ Packing Type, R= Reel
ITEM
P/N
Page
ICMEF112P900MFR
3
Capacitance
Insulation
Resistance
(Max)
Rated
Voltage
Rated
Current
4. 2 Specification
p
of electrical characteristics
Characteristics
Common Mode
Impedance
Resistance
CTF
Leakage
Current
CTF
y
symbol
ZCM
RDC
IL
C
IRCR
VR
IR
Units
Ω
Ω
pF
MΩ
Volt
mA
Test
Condition
@100MHz
25℃±2℃
5V
0.5Vrms
@1MHz
10V
Value
90(±25%)
Max 4.0
Max 1.0
Max 1.7
Min 10
Z11
5
Max100
-Transmission characteristics
(S-parameter)
- Impedance Curves
1000
25℃±2℃ 25℃±2℃
S21
LOG - LOG
LOG
10 dB/REF 0 dB
Differential Mode S21
100
-10
S21(dB)
IMPEDA
ANCE (Ω)
-5
10
-15
-20
-25
1
1M
10M
100M
FREQUENCY (H
(Hz))
1G
-30
1M
10M
100M
FREQUENCY(Hz)
1G
ITEM
P/N
Page
ICMEF112P900MFR
4
4 3 Operating Temperature
4.
DESCRIPTION
REQUIREMENTS
-40℃ ∼ + 85℃
5. Equivalent Circuit & Recommended Foot print & Stencil mask
PIN NUMBER
DESCRIPTION
①~④
DATA LINE
⑤, ⑥
GROUND
①
Unit : mm
Stencil Mask T : 0.10mm
②
⑤
⑥
③
④
[ Equivalent circuit ]
[ Foot print ]
[ Stencil Mask ]
6. Mechanical Property
6. 1 Appearance and Dimension
0.1
Unit : mm
ITEM
P/N
Page
ICMEF112P900MFR
5
6. 2 Structure of Product
Ni plated
Sn plated
External Electrode (Ag)
Inner Electrode (Ag)
6. 3 List of Raw Material
NO
Material
Supplier
1
Ferrite powder
Restricted
2
LTCC glass powder
Restricted
3
Ag(Inner) paste
Restricted
4
Ag(Terminal) paste
Restricted
5
Ni plating solution
Restricted
6
Sn plating solution
Restricted
ITEM
P/N
Page
ICMEF112P900MFR
6
7 TEST METHOD OF ELECTRICAL PROPERTY
7.
- PIN INDEX
Pin6
Pin1
Pin3
Pin2
Pin4
Pin5
ITEM
DESCRIPTION
SOURCE
EQUIPMENT
Rdc
Pin 1-3, 2-4
10mA DC Source
Source Meter
CM
Impedance
p
Pin 1-2(Short) to Pin 3-4(Short)
500mV
LCR Meter
((3GHz))
IL
Pin 5 or 6 to Pin 1, 2, 3, 4
5V DC Source
Source Meter
ITEM
P/N
Page
ICMEF112P900MFR
7
8 REFLOW CONDITION
8.
8. 1 RECOMMENDED SOLDERING PROFILE (Lead-free condition)
D ell: max
Dwell:
ma 260℃-10sec
260℃ 10sec
185℃
160℃
Δ T≤
220℃
130
250℃
ΔT ≤130℃
30~50 sec
30~50 sec
Soldering Soldering
Pre-heating
h i
110 ±10 sec
Gradual Cooling
25℃
60 sec
Time (sec)
8 2 RECOMMENDED
8.
CO
LEAD-FREE SOLDER
SO
PASTE
S
- Supplier : Tamura Donghwa
- Main composition : Sn-Ag-Cu
- Ratio of composition : 96.5%-3.0%-0.5%
8. 3 RECOMMENDED HAND SOLDER
- Max Temperature: Max 380 ℃(Max 5sec)
ITEM
P/N
Page
ICMEF112P900MFR
8
9 PACKING SPECIFICATION
9.
9. 1 TAPING FIGURE
9. 2 CARRIER TAPE DIMENSIONS
Unit : mm
SYMBOL
DIMENSION
11
A
B
1 15
1.15
15
1.5
±0.05
±0.05
W
8.0
+0.30
-0.10
F
E
P1
P2
P0
D
t
35
3.5
1 75
1.75
40
4.0
40
4.0
1 55
1.55
0 75
0.75
±0.05
±0.05
±0.10
±0.05
±0.10
±0.03
±0.05
ITEM
P/N
Page
ICMEF112P900MFR
9
9. 3 REEL DIMENSIONS
(1) Reel Materials: Polystyrene
(2) Label
(3) Taping
- Standard Packing Quantity per Reel (φ178)
- Paper Tape: 4,000pcs
Unit : mm
CODE
A
DIMENSION
φ178±2
B
C
Min. φ50 φ13±0.5
D
E
W
t
R
φ21±0.8
2.0±0.5
10±1.5
0.8±0.2
1.0
9. 4 LABEL CODE
ICMEF112P900MFR
J01218LA W 001
QTY 4,000 PCS
- P/N : Part Number
- L/N : Lot Number
- C/N : Customer Number
- SPEC : Size, Line numbers & CM Impedance
- DATE : Date code
- Q’TY : Quantity
ITEM
P/N
Page
ICMEF112P900MFR
10
9. 5 REEL PACKING
Part Number / Company Name
- Product box material : Card board
- 5 Reels in each SPQ Box
- PQ Box contains
i 10 SPQ Boxes (50 Reels
l )
Packing box + Product weight
Product
CMF
CMEF
Size
S-box + 5reel
M-box + 5S-box
L-box + 10S-box
L x W x H(mm)
185 x 70 x 185
370 x 190 x 200
380 x 370 x 200
Size
weight(g)
/1 unit
Total(g)
Chip(g)
Total(g)
Chip(g)
Total(g)
Chip(g)
0806
0.00124
643
62
3215
310
6147
620
1210
0 00480
0.00480
750
96
3758
480
7503
960
2012
0.00750
804
150
4028
750
8043
1500
0806
0.00128
646
65
3230
325
6177
650
1210
0.00490
752
98
3768
490
7523
980
2012
0.00760
806
152
4038
760
8063
1520
很抱歉,暂时无法提供与“ICMEF112P900MFR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39086
- 100+0.31839
- 300+0.28210
- 1000+0.25488
- 4000+0.20132
- 8000+0.19041
- 国内价格
- 10+0.35828
- 100+0.29185
- 800+0.23364
- 1600+0.23014
- 4000+0.18454
