Thick Film Chip Resistors
Type: ERJ XG, 1G, 2G, 3G, 6G,
8G, 14, 12, 12Z, 1T
Features
● Small
size and lightweight
reliability
Metal glaze thick film resistive element and three layers of electrodes
● Compatible with placement machines
Taping packaging available
● Suitable for both reflow and flow soldering
● Reference Standards
IEC 60115-8, JIS C 5201-8, EIAJ RC-2134B
● AEC-Q200 qualified (Exemption ERJXG)
● RoHS compliant
● High
■ As for Packaging Methods, Land Pattern, Soldering Conditions and Safety Precautions,
Please see Data Files
Explanation of Part Numbers
● ERJXGN,
1GN, 2GE, 3GE, 6GE, 8GE, 14, 12, 12Z, 1T Type, ±5 %
1
2
3
4
5
6
7
8
9
10
11
12
E
R
J
3
G
E
Y
J
1
V
Product Code
Thick Film
Chip Resistors
Size, Power Rating
Code Inch Power R.
XGN 01005 0.031 W
0.05 W
1GN 0201
0.1 W
2GE 0402
0.1 W
3GE 0603
6GE 0805 0.125 W
0.25 W
8GE 1206
0.5 W
14 1210
0.75 W
12 1812
0.75 W
12Z 2010
1W
1T 2512
Code
Resistance Tolerance
Marking
Marking
Code
J
Tolerance
±5 %
Jumper
Code
Packaging Methods
Packaging
Part No.
Y
Pressed Carrier Taping
W8P2, 20,000 pcs.
U
Embossed Carrier Taping
W4P1, 40,000 pcs.
Resistance Value
C
2 mm pitch, 15,000 pcs. ERJ1GN
The first two digits are significant figures of resistance and
the third one denotes number of zeros following.
Decimal Point is expressed by R as 4.7 = 4R7.
Jumper is expressed by R00.
X
Punched Carrier Taping
2 mm pitch, 10,000 pcs.
Y
2 mm pitch, 20,000 pcs.
V
4 mm pitch, 5,000 pcs.
Y
✽Nil
Value Marking on
black side
No marking
✽ When omitted, the rest of the P/N factors shall be moved up respectively.
(Only XGN, 1GN, 2GE type)
U
ERJXGN
ERJ2GE
ERJ3GE
ERJ6GE
ERJ8GE
ERJ14
ERJ12
ERJ12Z
ERJ1T
4 mm pitch, 4,000 pcs.
Design and specifications are each subject to change without notice. Ask factory for the current technical specifications before purchase and/or use.
Should a safety concern arise regarding this product, please be sure to contact us immediately.
07 Aug. 2018
Construction
Dimensions in mm (not to scale)
L
a
W
Protective coating
Electrode (Inner)
Alumina substrate
t
b
Dimensions (mm)
Part No.
Electrode
(Between)
Thick film
resistive element
Electrode (Outer)
Mass (Weight)
(g/1000 pcs.)
L
W
a
b
t
ERJXG
0.40±0.02
0.20±0.02
0.10±0.03
0.10±0.03
0.13±0.02
0.04
ERJ1G
0.60
±0.03
±0.03
0.30
0.10
±0.05
0.15
±0.05
0.23
±0.03
0.15
ERJ2G
1.00±0.05
0.50±0.05
0.20±0.10
0.25±0.05
0.35±0.05
0.8
ERJ3G
1.60
±0.15
+0.15
–0.05
±0.20
±0.15
±0.10
ERJ6G
2.00
±0.20
0.40
0.60
4
ERJ8G
3.20+0.05
–0.20
1.60+0.05
0.50±0.20
–0.15
0.50±0.20
0.60±0.10
10
ERJ14
3.20±0.20
2.50±0.20
0.50±0.20
0.50±0.20
0.60±0.10
16
ERJ12
4.50
±0.20
±0.20
±0.20
±0.20
0.60±0.10
27
ERJ12Z
5.00
±0.20
±0.20
±0.10
ERJ1T
6.40±0.20
0.80
±0.10
1.25
3.20
±0.20
0.30
±0.20
0.40
0.50
±0.20
0.30
±0.20
0.50
0.45
2
±0.10
2.50
0.60
0.60
0.60
27
3.20±0.20
0.65±0.20
0.60±0.20
0.60±0.10
45
Ratings
[For Resistor]
Part No.
(inch size)
Power Rating (3) Limiting Element Maximum Overload Resistance
Voltage (1)
Voltage (2)
at 70 °C
Tolerance
(W)
(V)
(V)
Resistance
Range
(Ω)
T.C.R.
(×10–6/°C)
Category
AEC-Q200
Temperature Range
Grade
(°C)
ERJXG
(01005)
0.031
15
30
±5
1 to 1M (E24)
ERJ1G
很抱歉,暂时无法提供与“ERJ-3GEY0R00V”相匹配的价格&库存,您可以联系我们找货
