X49SD73728MSD2SC-1
X49SD73728MSD2SC-1
    YXC(扬兴科技)
    HC49S
    无源晶振 7.3728MHz ±20ppm 20pF -20℃~+70℃
X49SD73728MSD2SC-1 数据手册
HC-49US Features xternal dimensions: 11.5 x 4.5 x 3.68mm. E Frequency range: 3.579545MHz ~ 64MHz. . Surface mount type crystal units. . A great number of standard frequencies. 12 YX .0 C XX X . High frequency pullability and low equivalent series resistance. . Highly mass production capability. . Applications: PC, STB, LCDM and Cable Modem. Electrical Specifications Item / Type HC-49US Nominal Frequency Range 3.579545 ~ 64 MHz Vibration Mode AT Fundamental Load Capacitance 12 pF, 20 pF, or specify Frequency Tolerance (at 25 ℃) ±1 0 ppm, ± 20 ppm, or specify Frequency Versus Temperature Characteristics ± 20 ppm, or specify Operating Temperature - 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify Storage Temperature - 40 ~ + 85 ℃ , or specify Shunt Capacitance 7 pF Max. Level Of Drive 1 ~ 500 μW (100 μW typical) Frequency Aging (at 25 ℃) ± 3 ppm / year Max. Equivalent Series Resistance(ESR) 3rd Overtone Fundamental 3.579545 Ω Ω Ω Ω Ω Ω Ω Ω Dimensions 4.5 YXC 12.0XXX 3.5 Units: mm 1/2 HC-49US ★ PART NUMBER GUIDE 部件号示例 Frequency Stability Pin Overall (ppm) Quartz Crystal Resonator Dimensions Frequency Load Capacitance (Hz) (Pf) X 12M 49SD H C -4 9 U S=11.5 × 4 .5 DI P SEAM TYPE e.g. X4 9 SD12MSD2SC S D 2 Frequency tolerance B ±10PPM D ±20PPM Load Capacitance (Pf) X 7.4pF G 12.5pF L 9pF 10pF M 12pF O P 15pF Material Operating Temp. Range S C Operating temperature C -20~ +70 ℃ -40~ +85 ℃ I -40~ +125℃ A -40~ +105℃ F ★ WAVE SOLDERING PROFILE 波峰焊特性 Temperature (℃) 260℃ max 220℃ 180℃ ③ ① ② Times (S) Pb free reflow A ① Preheat 160~180℃ ② Primary heat 220℃ 60sec. max ③ Peak 10sec. max. 260℃ 2/2 120sec. max
X49SD73728MSD2SC-1 价格&库存
很抱歉,暂时无法提供与“X49SD73728MSD2SC-1”相匹配的价格&库存,您可以联系我们找货
X49SD73728MSD2SC-1
  • 5+0.55774
  • 40+0.44147
  • 50+0.43485
  • 80+0.42823
  • 200+0.36243
库存:870
X49SD73728MSD2SC-1
  • 5+0.67533
  • 50+0.54314
  • 200+0.45339
  • 400+0.40382
  • 2400+0.36418
  • 5000+0.34431
库存:5923
X49SD73728MSD2SC-1
  • 1+0.36855
  • 200+0.32025
库存:332
