RNCF Series
Stackpole Electronics, Inc.
Precision Thin Film Chip Resistor
Resistive Product Solutions
Features:
Precision tolerances to ± 0.01%
TCR down to ± 2 ppm/ºC
Wide R-value range
Lower values may be available
Consult factory for tighter tolerances
Qualified to AEC-Q200
RoHS compliant and halogen-free
Electrical Specifications – Precision Thin Film Chip Resistor
Power Rating Maximum
Working
Type / Code (Watts) @
70ºC
Voltage (1)
RNCF0201
Maximum Resistance
Overload Temperature
Voltage
Coefficient
0.032 W
15 V
30 V
0.063 W
25 V
50 V
RNCF0402
0.1 W
0.1 W
50 V
75 V
100 V
150 V
RNCF0603
0.166 W
100 V
150 V
0.1 W
100 V
200 V
RNCF0805
0.125 W
150 V
300 V
0.25 W
150 V
300 V
0.125 W
150 V
300 V
RNCF1206
0.25 W
200 V
400 V
0.33 W
200 V
400 V
0.25 W
150 V
300 V
0.33 W
200 V
400 V
RNCF1210
±25 ppm/ºC
±50 ppm/ºC
±10 ppm/ºC
±15 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±10 ppm/ºC
±15 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±10 ppm/ºC
±15 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±10 ppm/ºC
±15 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±10 ppm/ºC
±15 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±10 ppm/ºC
±15 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±10 ppm/ºC
±15 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±10 ppm/ºC
±15 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
Rev Date: 02/06/2020
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
Ohmic Range (Ω) and Tolerance
0.01%
0.05%
0.1%
0.25%
0.5%
49.9 - 4.99 K
49.9 - 33.2 K
12.1 K - 20 K
4.02 - 4.64, 261 K - 511 K
49.9 - 12 K
49.9 - 100 K
49.9 - 12 K
4.7 - 255 K
24.9 - 100 K
4.75 - 332 K
4.7 - 511 K
24.9 - 100 K
4.75 - 9.76
1 - 9.76, 336 K - 1 M
1%
10 - 332 K
517 K - 1 M
505 K - 1 M
1.02 M - 2 M
24.9 - 200 K
4.7 - 511 K
4.75 - 1 M
24.9 - 200 K
4.7 - 9.88 K
505 K - 1 M
10 - 499 K
1.02 M - 1.5 M
1.02 M - 2.5 M
24.9 - 499 K
4.7 - 1 M
24.9 - 499 K
1 - 9.76
10 - 1 M
1.02 M - 2.5 M
24.9 - 499 K
4.7 - 1 M
24.9 - 499 K
1-1M
1
www.seielect.com
marketing@seielect.com
RNCF Series
Electrical Specifications – Precision Thin Film Chip Resistor (cont.)
Working
(1)
70ºC
Voltage
Maximum Resistance
Voltage
Coefficient
0.25 W
150 V
300 V
0.33 W
200 V
400 V
RNCF2010
0.5 W
150 V
300 V
RNCF2512
0.75 W
200 V
1W
200 V
400 V
400 V
±25 ppm/ºC
±50 ppm/ºC
±10 ppm/ºC
±15 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±10 ppm/ºC
±15 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±10 ppm/ºC
±15 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
±25 ppm/ºC
±50 ppm/ºC
0.01%
0.05%
0.1%
0.25%
0.5%
1%
1.02 M - 3 M
24.9 - 499 K
4.7 - 1 M
24.9 - 499 K
1-1M
2.05 K - 499 K
2.05 K - 1 M
2.05 K - 1 M
2.05 K - 3 M
24.9 - 2 K
4.7 - 2 K
4.7 - 2 K
1-2K
24.9 - 2 K
4.7 - 2 K
101 - 2 K
101 - 2 K
4.7 - 100
1 - 100
(1) Lesser of √P*R or maximum wor King voltage.
(2) For those value / tolerance / TCR combinations that have multiple power ratings available, the default will be the highest power rating for that
case size. If a lower power rating is desired, please contact factory.
Electrical Specifications – Ultra-Precision Thin Film Chip Resistor
Working
(1)
70ºC
Voltage
RNCF0402
0.1 W
50 V
Maximum Resistance
Voltage
Coefficient
100 V
RNCF0603
0.1 W
75 V
150 V
RNCF0805
0.125 W
150 V
300 V
RNCF1206
0.25 W
200 V
400 V
RNCF1210
0.33 W
200 V
400 V
0.25 W
150 V
300 V
0.33 W
200 V
400 V
RNCF2010
RNCF2512
0.5 W
150 V
300 V
0.01%
±2 ppm/ºC
±5 ppm/ºC
±2 ppm/ºC
±5 ppm/ºC
±2 ppm/ºC
±5 ppm/ºC
±2 ppm/ºC
±5 ppm/ºC
±2 ppm/ºC
±5 ppm/ºC
±2 ppm/ºC
±2 ppm/ºC
±5 ppm/ºC
±2 ppm/ºC
±5 ppm/ºC
0.05%
49.9 - 4.99 K
0.1%
0.25%
0.5%
1%
49.9 - 20 K
24.9 - 15 K
24.9 - 60.4 K
24.9 - 30 K
24.9 - 150 K
24.9 - 49.9 K
24.9 - 300 K
24.9 - 49.9 K
24.9 - 300 K
51 K - 100 K
24.9 - 49.9 K
24.9 - 300 K
24.9 - 100 K
24.9 - 300 K
2
www.seielect.com
RNCF Series
Mechanical Specifications
Type / Code
Weight (g)
(1000 pc.)
RNCF0201
0.14
RNCF0402
0.54
RNCF0603
1.83
RNCF0805
4.71
RNCF1206
9.02
RNCF1210
10
RNCF2010
23.61
RNCF2512
38.6
L
Body Length
0.023 ± 0.002
0.58 ± 0.05
0.039 ± 0.002
1.00 ± 0.05
0.061 ± 0.004
1.55 ± 0.10
0.079 ± 0.006
2.00 ± 0.15
0.120 ± 0.006
3.05 ± 0.15
0.122 ± 0.006
3.10 ± 0.15
0.193 ± 0.006
4.90 ± 0.15
0.248 ± 0.006
6.30 ± 0.15
W
Body Width
0.011 ± 0.002
0.29 ± 0.05
0.020 ± 0.002
0.50 ± 0.05
0.031 ± 0.004
0.80 ± 0.10
0.049 ± 0.006
1.25 ± 0.15
0.061 ± 0.006
1.55 ± 0.15
0.094 ± 0.006
2.40 ± 0.15
0.094 ± 0.006
2.40 ± 0.15
0.122 ± 0.006
3.10 ± 0.15
H
Body Height
0.009 ± 0.002
0.23 ± 0.05
0.012 ± 0.002
0.30 ± 0.05
0.018 ± 0.004
0.45 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
a
Top Termination
0.005 ± 0.002
0.12 ± 0.05
0.008 ± 0.004
0.20 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.012 ± 0.008
0.30 ± 0.20
0.017 ± 0.008
0.42 ± 0.20
0.016 ± 0.008
0.40 ± 0.20
0.024 ± 0.012
0.60 ± 0.30
0.024 ± 0.012
0.60 ± 0.30
b
Bottom Termination
0.006 ± 0.002
0.15 ± 0.05
0.008 ± 0.004
0.20 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.016 ± 0.008
0.40 ± 0.20
0.014 ± 0.010
0.35 ± 0.25
0.022 ± 0.010
0.55 ± 0.25
0.020 ± 0.010
0.50 ± 0.25
0.020 ± 0.010
0.50 ± 0.25
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Performance Characteristics
Test
Test Method
Temperature coefficient of
Resistance (T.C.R.)
MIL-STD-202 Method 304
Short Time Overload
JIS-C-5201-1 4.13
Insulation Resistance
MIL-STD-202 Method 302
Endurance
MIL-STD-202 Method 108A
Damp Heat with Load
MIL-STD-202 Method 103B
Bending Strength
JIS-C-5201-1 4.33
Solderability
Resistance to Soldering Heat
Dielectric Withstand Voltage
MIL-STD-202 Method 208H
MIL-STD-202 Method 210E
MIL-STD-202 Method 301
Test Specification
Tol. ≤ 0.05%
Tol. > 0.05%
Test Condition
As specified.
+25 / -55 / +25 / +125 / +25 °C
Δ R ± 0.05%
Δ R ± 0.2%
Δ R ± 0.2% for high power rating
> 9999 M Ω
Δ R ± 0.05%
Δ R ± 0.2%
Δ R ± 0.5% for high power rating
0201 ≤ 7 k Ω: Δ R ± 0.2%
0201 > 7 k Ω: Δ R ± 0.5%
Δ R ± 0.05%
Δ R ± 0.3%
RCWV * 2.5 or Max. overload voltage
whichever is lower for 5 seconds
Apply 100 VDC for 1 minute
Δ R ± 0.05%
Δ R ± 0.1%
70 ± 2 °C, RCWV for 1000 hours with
1.5 hours "ON" and 0.5 hour "OFF"
40 ± 2 °C, 90 ~ 95% R.H. RCWV for 1000 hours
with 1.5 hours "ON" and 0.5 hour "OFF"
Bending amplitude for 10 seconds.
2010 and 2512 sizes: 2 mm
Other sizes: 3 mm
245 ± 5 °C for 3 seconds
260 ± 5 °C for 10 seconds
Max. overload voltage for 1 minute
95% min. coverage
Δ R ± 0.05%
Δ R ± 0.1%
by type
Δ R ± 0.05%
Δ R ± 0.2%
Low Temperature Operation
JIS-C-5201-1 4.36
1 hour, - 65 °C, followed by 45 minutes of RCWV
High Temperature Exposure
Δ R ± 0.5%
+155 °C for 1000 hours
RCWV (Rated Continuous Working Voltage) = √ (P * R) or Max. Operating Voltage, whichever is lower.
Storage Temperature: 60 ~ 82 ºF. Humidity < 80% R.H.
3
www.seielect.com
RNCF Series
Power Derating Curve:
Percent Rated Power (%)
100
-55 ºC
70 ºC
80
60
40
155 ºC
60
80
100
120
140
160
180
Ambient Temperature (ºC)
Soldering Condition:
(1) Time of IR reflow soldering at maximum temperature point 260 °C: 10 seconds
(2) Time of wave soldering at maximum temperature point 260 °C: 10 seconds
(3) Time of soldering iron at maximum temperature point 410 °C: 5 seconds
Reel Specifications
Type / Code
RNCF0201
RNCF0402
RNCF0603
RNCF0805
A
7.008
178.00
7.008
178.00
7.008
178.00
7.008
178.00
B
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
2.362
60.00
2.362
60.00
2.362
60.00
2.362
60.00
C
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
0.531
13.50
0.531
13.50
0.531
13.50
0.531
13.50
4
W
0.028
0.70
0.028
0.70
0.028
0.70
0.028
0.70
0.374
9.50
0.374
9.50
0.374
9.50
0.374
9.50
T
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
0.453
11.50
0.453
11.50
0.453
11.50
0.453
11.50
Unit
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
RNCF Series
Reel Specifications (cont.)
Type / Code
A
7.008
178.00
7.008
178.00
7.008
178.00
7.008
178.00
RNCF1206
RNCF1210
RNCF2010
RNCF2512
B
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
2.362
60.00
2.362
60.00
2.362
60.00
2.362
60.00
C
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
0.531
13.50
0.531
13.50
0.531
13.50
0.531
13.50
W
0.028
0.70
0.028
0.70
0.028
0.70
0.028
0.70
0.374
9.50
0.374
9.50
0.531
13.50
0.531
13.50
T
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
0.453
11.50
0.453
11.50
0.610
15.50
0.610
15.50
Unit
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
inches
mm
inches
mm
inches
mm
inches
mm
Packaging Specifications – Paper Tape
Type / Code
RNCF0201
RNCF0402
RNCF0603
RNCF0805
RNCF1206
RNCF1210
A
RNCF0402
RNCF0603
RNCF0805
RNCF1206
RNCF1210
W
E
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
P0
0.028
0.70
0.046
1.16
0.075
1.90
0.093
2.37
0.140
3.55
0.134
3.40
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
P1
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
P2
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.079
2.00
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.061
1.55
0.061
1.55
0.061
1.55
0.061
1.55
0.061
1.55
0.063
1.60
Type / Code
RNCF0201
B
0.016
0.40
0.028
0.70
0.043
1.10
0.063
1.60
0.079
2.00
0.108
2.75
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
5
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
F
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.020
± 0.50
± 0.002
± 0.05
± 0.002
± 0.05
D0
0.001
0.03
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
Unit
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
T
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Unit
0.017
0.42
0.016
0.40
0.024
0.60
0.030
0.75
0.030
0.75
0.030
0.75
0.001
0.02
0.001
0.03
0.001
0.03
0.002
0.05
0.002
0.05
0.002
0.05
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
RNCF Series
Peel Force of Top Cover Tape
The peel speed shall be about 300 mm / min ± 5%
The peel force of top cover tape shall be between 8 gf to 60 gf
Packaging Specifications – Embossed Plastic Tape
Type / Code
RNCF2010
RNCF2512
A
0.112
2.85
0.134
3.40
Type / Code
RNCF2010
RNCF2512
B
0.004
0.10
0.004
0.10
0.215
5.45
0.262
6.65
0.002
0.05
0.002
0.05
0.157
4.00
0.157
4.00
P0
0.157
4.00
0.157
4.00
W
0.004
0.10
0.004
0.10
0.472
12.00
0.472
12.00
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
P1
E
0.004
0.10
0.004
0.10
0.069
1.75
0.069
1.75
0.002
0.05
0.002
0.05
0.059
1.50
0.059
1.50
P2
F
0.004
0.10
0.004
0.10
0.217
5.50
0.217
5.50
0.004
0.10
0.004
0.10
0.039
1.00
0.039
1.00
D0
Unit
0.002
0.05
0.002
0.05
inches
mm
inches
mm
0.008
0.20
0.008
0.20
inches
mm
inches
mm
T
Unit
The peel force of top cover tape shall be between 20 gf to 80 gf
6
www.seielect.com
RNCF Series
Recommended Pad Layout
Type / Code
RNCF0201
RNCF0402
RNCF0603
RNCF0805
RNCF1206
RNCF1210
RNCF2010
RNCF2512
A
B
0.010
0.25
0.020
0.50
0.031
0.80
0.039
1.00
0.079
2.00
0.079
2.00
0.142
3.60
0.193
4.90
0.012
0.30
0.020
0.50
0.039
1.00
0.039
1.00
0.045
1.15
0.045
1.15
0.055
1.40
0.063
1.60
C
0.016
0.40
0.024
0.60
0.035
0.90
0.053
1.35
0.067
1.70
0.098
2.50
0.098
2.50
0.122
3.10
Unit
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
RNCF
Precision Thin Film
Surface Mount Chip Resistor
SMD
YES
100% Matte Sn over Ni
May-04
04/18
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
7
www.seielect.com
RNCF Series
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
R
N
C
F
D
T
E
4
K
7
5
Product Series
Code
Description
Precision Thin
RNCF
Film Chip
Resistors
Size
Code
0201
0402
0603
0805
1206
1210
2010
2512
Tolerance
(1)
Tol
Code
Value
T
0.01%
A
0.05%
E192,
B
0.1%
E96, E24
C
0.25%
D
0.5%
F
1%
E96, E24
Packaging
Description
Size
0201, 0402
7" Reel
0603, 0805
Paper Tape
1206, 1210
7" Reel
2010, 2512
Plastic Tape
Code
T
K
7" Reel
All Sizes
Quantity
10000
5000
4000
1000
TCR
Code ppm
W
2
Y
5
T
10
S
15
E
25
C
50
D
100
Resistance Value (2)
Four characters
with the multiplier
used as the
decimal holder.
24.9 ohm = 24R9
10 Kohm = 10K0
1 Mohm = 1M00
(1) E192 values are not marked, and may be subject to 20 K pieces MOQ
(2) Values below 10 ohm and above 1 Mohm may be subject to 20 K pieces MOQ
8
www.seielect.com
很抱歉,暂时无法提供与“RNCF0603BTE6K49”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.360641+0.16431
- 10+1.0230810+0.12355
- 50+0.8066250+0.09741
- 100+0.72135100+0.08711
- 500+0.54710500+0.06607
- 1000+0.482811000+0.05831
- 国内价格
- 5+1.51583
- 20+1.37372
- 100+1.23161
- 500+1.08950
- 1000+1.02318
- 2000+0.97581
- 国内价格 香港价格
- 5000+0.319775000+0.03862
