LV331M035G105ETR
LV331M035G105ETR
    CAPXON(台湾丰宾)
    SMD,D10xL10.5mm
    贴片铝电解电容 SMD,D10xL10.5mm 330µF ±20% 35V 2000Hrs@85℃
LV331M035G105ETR 数据手册
  Aluminum Electrolytic Capacitor    LV series  Part number  Capacitance  Voltage  Surge Voltage  Capacitance  Tolerance (@120Hz, +20°C) Ripple current (max, @120Hz,+85°C)  Dissipation factor (tanδ @120Hz, +20°C)  Leakage Current (max, @ +20°C)*  Size  Operating temperature  Endurance  LV331M035G105ETR 330 35 40 ±20 460 14 115.5 10x10.5 ‐40 to 85 2000 µF VDC VDC % mA % µA mm °C h *L.C. 6.3~100V: I≦0.01CV or 3µA(C = CAP., V = W.V.) whichever is greater( After 2 minutes) 160~450V: I≦0.04CV+100µA ,after 1 minute with rated working voltage applied.   Test conditions  Duration time  Applied voltage  After test requirements (+20°C):  Capacitance  change  Dissipation factor change  Leakage current  comment                               Endurance  Shelf Life  2000h @ 85°C  1000h @ 85°C  Rated DC working voltage,IR  None      ≤ ±25% of initial measured value  ≤ 200% of the initial specified value  ≤ the initial specified value    Pre‐treatment for measurements shall  be conducted after application of DC  working voltage for 30 min.      L max  D  L  A  B  C  W  P±0.2  10  10.5  10.3  10.3  11  0.7~1.1  4.5  Series  1_2  Cap  3_4_5  Tol.  6  Voltage  7_8_9  LV  331  M  035        =330µF    …  =±20%      =35V      Case D  10  Case L  11_12_13 Type  14_15_16  Cust.  17_18_19_20  G  105  ETR    =10mm      =10.5mm      =tape and reel      no request      Specification and description for the component(s) are subject to change without notice. For packaging, handling, precautions and warning information, please visit our website: www.capxongroup.com CapXon       V.ED‐20171110
LV331M035G105ETR 价格&库存
很抱歉,暂时无法提供与“LV331M035G105ETR”相匹配的价格&库存,您可以联系我们找货
LV331M035G105ETR
  • 5+1.55150
  • 100+1.16030
  • 200+0.89960
  • 500+0.65190
  • 1000+0.61930
  • 5000+0.57370
库存:9
LV331M035G105ETR
    • 1+1.56440
    • 25+1.34850
    • 100+1.16260
    • 200+1.00230
    • 1000+0.86400
    • 2000+0.79490
    库存:270
    LV331M035G105ETR
    • 5+0.79632
    • 20+0.72522
    • 100+0.65412
    • 500+0.58302
    • 1000+0.54984
    • 2000+0.52614
