YTLP2416E
YTLP2416E
    YTL(亚特联)
    SMD,1.1x0.9mm
    RF滤波器、5G通讯
YTLP2416E 数据手册
YTLP2416E Wi-Fi Filter for LTE (2402.5~2481.5MHz) Description YTLP2416E is a Wi-Fi band filter, which is designed with Film Bulk Acoustic Resonator (FBAR) technology. The product can provide low insertion loss and steep skirt to enables coexistence of Wi-Fi and LTE signals within the same device or in close proximity to one another. The typical insertion loss in the pass band is less than 1.4dB. Typical rejection at the LTE Band 38 and LTE Band 7 and 41 is more than 42dB, at the LTE Band 40 is more than 41dB. For the chip package, the YTLP2416E uses advanced module packing techniques to achieve the industry standard 1.1x0.9x0.6mm footprint, include bumping and flip chip. Features Functional Block Diagram ● ● ● ● ● ● ● ● ● For Wi-Fi - LTE coexistence application Plastic Chip Scale Package(CSP) Miniature Size: 1.1mm x 0.9 mm x 0.6 mm Fast Roll-off from Wi-Fi to near LTE Bands High Rejection at LTE bands. Low Temperature Coefficient of Frequency Storage temperature range: -40 to +150 ℃ Excellent ESD protection ability: Class 1C Moisture Sensitivity : MSL3 Applications ● ● ● Wi-Fi bandpass filter enables the coexistence of (LTE/TD-LTE) & Wi-Fi ISM band applications such as Smart Meters Portable Hotspots and Mobile Routers Environmental ● ● Pin Connection No. Function 1 Input 4 Output 2,3,5 Ground 1/6 Full implement with RoHS compliant Lead Free (Pb free) YTLP2416E Wi-Fi Filter for LTE (2402.5~2481.5MHz) Electrical Specifications Parameter(Operable Temperature:-25 to +85℃) Min Typ(1) Max Unit Insertion Loss(2402.5 ~ 2421.5 MHz) \ 1.3 1.9 dB Insertion Loss(2407.5 ~ 2476.5 MHz) \ 1.1 1.7 dB Insertion Loss(2462.5 ~ 2481.5 MHz) \ 1.4 2.2 dB Ripple(2402.5 ~ 2421.5 MHz) \ 0.6 1.0 dB Ripple(2407.5 ~ 2476.5 MHz) \ 0.6 1.0 dB Ripple(2462.5 ~ 2481.5 MHz) \ 0.8 1.2 dB VSWR(2402.5 ~ 2481.5 MHz) \ 1.2 1.7 \ Absolute Attenuation \ 800 ~ 2000 MHz 32 37 \ dB 2000 ~ 2170 MHz 22 35 \ dB 2300 ~ 2370 MHz 45 53 \ dB 2370 ~ 2375 MHz 45 50 \ dB 2375 ~ 2380 MHz 22 41 \ dB 2500 ~ 2505 MHz 50 61 \ dB 2505 ~ 2570 MHz 46 60 \ dB 2570 ~ 2620 MHz 39 45 \ dB 2620 ~ 2690 MHz 38 42 \ dB 4800 ~ 5805 MHz 40 43 \ dB \ \ 28 dBm RF Input Power(2)(2402.5 ~ 2481.5 MHz) (1) Typ Data is the integrated value of the linear S-parameter over indicated band. (2) Input power applied for a minimum of 5,000 hrs at 55°C in the specified frequency band       2/6 YTLP2416E Wi-Fi Filter for LTE (2402.5~2481.5MHz) Typical Performance at Tc=25˚C Figure.1 Passband Insertion Loss Figure.2 VSWR Figure.3 Narrowband Insertion Loss Figure.4 Wideband Insertion Loss Figure.5 Input Smith Chart S11 Figure.6 Output Smith Chart S22 3/6 YTLP2416E Wi-Fi Filter for LTE (2402.5~2481.5MHz) Package Outline Drawing 0.395 0.59±0.06 1.10±0.05 0.395 5x0.25x0.20 0.055 0.500 0.90±0.05 07 0.075 PIN1 Mark Notes: 1. Dimension: mm 2. Dimensions nominal unless otherwise noted 3. Contact area are gold plated 4. Pad(1) to (5) are same size 5. XX is ROFS inside code Pin Connection: 1 Input 4 Output 2.3.5 Ground Test Circuit 50ohm Input 5 4 2 3 1 L1=4.7nH 50ohm Output L2=4.7nH Top View Notes: 1. Matching component values shown are ROFS evaluation board results, please adjust component values by the actual use environment. PCB Footprint Notes: 1. Black indicates metalized area. 2. This footprint represents a recommendation only, some modification may be necessary to suit end user assembly materials and processes. 3. For solder pad recommendation see mechanical information. 4. Dimensions shown are nominal in millimeters. 4/6 YTLP2416E Wi-Fi Filter for LTE (2402.5~2481.5MHz) Packing 1. Tape Dimension 2. Reel Dimension 5000Pcs/Reel 5/6 YTLP2416E Wi-Fi Filter for LTE (2402.5~2481.5MHz) Recommended IR Reflow Profile Order Information Part Number Qty Per Reel Container YTLP2416E 5000 7 inch Reel 6/6
YTLP2416E 价格&库存
很抱歉,暂时无法提供与“YTLP2416E”相匹配的价格&库存,您可以联系我们找货
YTLP2416E
    • 5+0.95342
    • 20+0.93593
    • 100+0.90094
    库存:20
