YTLP2406D
YTLP2406D
    YTL(亚特联)
    SMD,1.4x1.1mm
    RF滤波器、5G通讯
YTLP2406D 数据手册
YTLP2406D Wi-Fi Filter for LTE (2402.5~2481.5MHz) Description YTLP2406D is a Wi-Fi band filter, which is designed with Film Bulk Acoustic Resonator (FBAR) technology. The product can provide low insertion loss and steep skirt to enables coexistence of Wi-Fi and LTE signals within the same device or in close proximity to one another. The typical insertion loss in the pass band is less than 1.4dB. Typical rejection at the LTE Band 38 and LTE Band 7 and 41 is more than 42dB, at the LTE Band 40 is more than 41dB. For the chip package, the YTLP2406D uses advanced module packing techniques to achieve the industry standard 1.4x1.1x0.6mm footprint, include bumping and flip chip. Features Functional Block Diagram ● ● ● ● ● ● ● ● ● For Wi-Fi - LTE coexistence application Plastic Chip Scale Package(CSP) Miniature Size: 1.4mm x 1.1 mm x 0.6 mm Fast Roll-off from Wi-Fi to near LTE Bands High Rejection at LTE bands. Low Temperature Coefficient of Frequency Storage temperature range: -40 to +150 ℃ Excellent ESD protection ability: Class 1C Moisture Sensitivity : MSL3 Applications ● ● ● Wi-Fi bandpass filter enables the coexistence of (LTE/TD-LTE) & Wi-Fi ISM band applications such as Smart Meters Portable Hotspots and Mobile Routers Environmental ● ● Pin Connection No. Function 1 Input 4 Output 2,3,5 Ground 1/6 Full implement with RoHS compliant Lead Free (Pb free) YTLP2406D Wi-Fi Filter for LTE (2402.5~2481.5MHz) Electrical Specifications Parameter(Operable Temperature:-25 to +85℃) Min Typ Max Unit Insertion Loss(2402.5 ~ 2421.5 MHz) \ 1.3 2.2 dB Insertion Loss(2407.5 ~ 2476.5 MHz) \ 1.1 1.8 dB Insertion Loss(2462.5 ~ 2481.5 MHz) \ 1.4 2.4 dB Ripple(2402.5 ~ 2421.5 MHz) \ 0.6 1.0 dB Ripple(2407.5 ~ 2476.5 MHz) \ 0.6 1.0 dB Ripple(2462.5 ~ 2481.5 MHz) \ 0.8 1.2 dB VSWR(2402.5 ~ 2481.5 MHz) \ 1.2 1.8 \ Absolute Attenuation \ 800 ~ 2000 MHz 32 40 \ dB 2000 ~ 2170 MHz 22 37 \ dB 2300 ~ 2370 MHz 41 50 \ dB 2370 ~ 2375 MHz 46 52 \ dB 2375 ~ 2380 MHz 10 49 \ dB 2500 ~ 2505 MHz 22 58 \ dB 2505 ~ 2570 MHz 45 62 \ dB 2570 ~ 2620 MHz 40 47 \ dB 2620 ~ 2690 MHz 38 44 \ dB 4800 ~ 5805 MHz 37 42 \ dB RF Input Power(2)(2402.5 ~ 2481.5 MHz) 28 (1) Typ Data is the integrated value of the linear S-parameter over indicated band. (2) Input power applied for a minimum of 5,000 hrs at 55°C in the specified frequency band       2/6 dBm YTLP2406D Wi-Fi Filter for LTE (2402.5~2481.5MHz) Insertion Loss Typical Performance at Tc=25˚C Figure.1 Passband Insertion Loss Figure.4 Wideband Insertion Loss . -2 -1.0 Figure.6 Output Smith Chart S22 Package Outline Drawing 3/6 10 20 2. 0 0 2.0 1.0 0.5 5 -0 . -1.0 Figure.5 Input Smith Chart S11 5.0 5 0. S(2,2) 10 20 .0 -2 5.0 2.0 1.0 -0 .5 0.5 S(1,1) 0.5 2. 0 1.0 1.0 Figure.3 Narrowband Insertion Loss Figure.2 VSWR YTLP2406D Wi-Fi Filter for LTE (2402.5~2481.5MHz) 0.5 0.59±0.05 1.40±0.05 0.1±0.05 PIN1 Mark Notes: 1. Dimension: mm 2. Dimensions nominal unless otherwise noted 3. Contact area are gold plated 4. Pad(1) to (5) are same size 5. XX is ROFS inside code 5x0.325x0.25 5 0.575 1.10±0.05 2406 4 0.5 1 3 2 0.075±0.05 Pin Connection: 1 Input 4 Output 2.3.5 Ground Test Circuit 50ohm Input 5 4 2 3 50ohm Output 1 L1=5.1nH L2=5.1nH Notes: 1. Matching component values shown are ROFS evaluation board results, please adjust component values by the actual use environment. Top View PCB Footprint 3x0.15 Notes: 1. Black indicates metalized area. 2. This footprint represents a recommendation only, some modification may be necessary to suit end user assembly materials and processes. 3. For solder pad recommendation see mechanical information. 4. Dimensions shown are nominal in millimeters. 4x0.425 0.15 0.425 0.325 0.325 0.325 Packing 4/6 YTLP2406D Wi-Fi Filter for LTE (2402.5~2481.5MHz) 1. Tape Dimension 4.0±0.1 2.00±0.05 +0.1 1.5-0.0 +0.1 0.8-0.0 4.0±0.1 3°max Direction of Feed 1.6±0.1 8.0±0.2 2403 2403 2403 3.5±0.05 1.75±0.1 0.30±0.05 0.70±0.1 Cover Tape Unit: mm 1.3±0.1 2. Reel Dimension 4000Pcs/Reel 5/6 YTLP2406D Wi-Fi Filter for LTE (2402.5~2481.5MHz) Recommended IR Reflow Profile Order Information Part Number Qty Per Reel Container YTLP2406D 4000 7 inch Reel 6/6
YTLP2406D 价格&库存
很抱歉,暂时无法提供与“YTLP2406D”相匹配的价格&库存,您可以联系我们找货
YTLP2406D
    • 5+0.84728
    • 20+0.77252
    • 100+0.69776
    • 500+0.62300
    • 1000+0.58811
    • 2000+0.56319
    库存:20
