MT8311A
MT8311A
    MAGNTEK(麦歌恩)
    TO-92-3
    单极高压霍尔效应开关IC
MT8311A 数据手册
MT831X Uni-polar, High Voltage Hall-Effect Switch IC 1 Product Description The MT831X family is produced by BCD technology with both high performance and high reliability. The Hall IC internally includes an on-chip Hall voltage generator, a voltage regulator for operation with supply voltage of 3.8V to 60V, temperature compensation circuitry, small-signal amplifier, Hall IC with dynamic offset cancellation system, Schmitt trigger and an open collector output. It also includes an clamp diode at output and reversed power supply protection enhances the robustness of Hall IC. The Hall IC designed to respond to a single poles. While the magnetic flux density(B) is larger than operating point (BOP), the output will be turned on (Low), the output is held until the magnetic flux density(B) is lower than releasing point (BRP), then turn off (High). The MT831X family provides a variety of packages to customers: SOT-23/SOT-23 (Thin Outline)/SOT-89B for surface mount and flat TO-92 for through-hole mount. All packages are RoHS compliant. 2 Features ■ AEC-Q100 Automotive Qualified MT831XAT & MT831XET ■ Uni-polar Switch ■ 3.8~60V Operating Vcc Range ■ -40℃~150℃ Operating Temperature ■ Package Option: Flat TO-92 / Flat TO-92 (Radial Lead) / SOT-23 / SOT-23 (Thin Outline) / SOT-89B ■ Magnetic Sensitivity Option: MT8311 (BOP=140Gs, BRP=105Gs) MT8312 (BOP=255Gs, BRP=210Gs) MT8313 (BOP=85Gs, BRP=50Gs) MT8315 (BOP=30Gs, BRP=20Gs) ■ Open-Drain Output ■ -20V Reversed Power Supply Protection ■ Output Limiting Current Protection ■ RoHS Compliant: (EU)2015/863 4 Applications ■ ■ ■ ■ ■ ■ 5. Pin Configuration and Functions VCC Out GND SOT-23 1 2 3 SOT-23 (Thin Outline) 1 2 3 Flat TO-92 (Radial Lead) 1 3 2 Flat TO-92 1 3 2 SOT-89B 1 3 2 Description Power Output Ground GND magntek.com.cn | Magnetic Tech Makes Magic Change 2 3 OUT 1 GND SOT-89B, tape & reel (1000pcs/bag) 按钮 1 MT831XBT 3 Vcc Vcc MT831XET SOT-23 (Thin Outline), tape & reel (3000pcs/bag) 按钮 SOT-23, tape & reel (3000pcs/bag) OUT 按钮 MT831XAT GND OUT Flat TO-92, radial lead, bulk packaging (1000pcs/bag) 2 22 MT831XA-T SOT-89B Top-View 3 3 Flat TO-92, bulk packaging (1000pcs/bag) Vcc MT831XA 11 Description Open-Drain SOT-23 Thin Outline Top-View SOT-23 Top-View 3 Product Overview of MT831X Part No. Automotive, Home appliances, Industrial Speed Detection Position Detection Magnetic Encoder Solid-State Switch Proximity Switch TO-92 Radial Lead Top-View TO-92 Top-View OUT 3 GND 2 Vcc 1 OUT GND Vcc Figure.1 1 Pin Configuration & Functions Rev 1.8 3 2 1 MT831X Uni-polar, High Voltage Hall-Effect Switch IC Table of Contents 1 Product Description………...…….……………….……...…………………………………….…….………1 2 Features……………………………….……..……………………………………………………………….…….1 3 Product Overview of MT831X ..…………………………………………………………………………1 4 Applications……………………………………………………………………………………………………….1 5 Pin Configuration and Functions…………………………………………………….………………….1 6 Definition of Switching Function……………………………………………………………………….3 7 Function Description……...…………………………………………………………………………………..3 8 Feature Description……………………………………………………………………………………………3 9 Functional Block Diagram…………………………………………………………………………………..4 10 Electrical and Magnetic Characteristics………………………………………………………………4 10.1 Absolute Maximum Ratings……………………………………………………………………………….4 10.2 ESD Ratings………………………………………………………………………………………………………..4 10.3 Electrical Specifications……………………………………………………………………………………..5 10.4 Magnetic Characteristics……………………………………………………………………………………5 10.5 Characteristic Performance………………………………………………………………….…………….6 10.6 Typical Output Waveform…………………………………………………………………………………..7 11 Typical Application Circuit………………………………………………………………………………….7 12 Package Material Information……………………………………………………………………………8 12.1 SOT-23 Package Information……………………………...………………………………………………8 12.2 SOT-23 (Thin Outline) Package Information……...……………………………………………….9 12.3 Flat TO-92 Package Information……………………………………………………………………….10 12.4 Flat TO-92 (Radial Lead) Package Information…………………………………………………11 12.5 SOT-89B Package Information……...…………………………………………………………………12 13 Copy Rights and Disclaimer……………………………………………………………………………..13 1 2 Originally Version 1.1 Version 3 4 5 6 1.2 Version 1.3 Version 1.4 Version 1.5 Version 7 8 9 1.6 Version 1.7 Version 1.8 Version Reversion History magntek.com.cn | Magnetic Tech Makes Magic Change Update MT8312 & MT8313 Series Update SOT-23 (Thin Outline) Package Update Flat TO-92 (Radial Lead) Package Update AEC-Q100 Automotive on MT831XAT Update RoHS compliant to (EU)2015/863 Update AEC-Q100 Logo Update Copy Rights and Disclaimer Update AEC-Q100 Automotive on MT831XET Update MT8315 Series Update the marking spec of SOT-23 & SOT23 (Thin Outline) 2 Rev 1.8 MT831X Uni-polar, High Voltage Hall-Effect Switch IC 6 Definition of Switching Function Figure.2 & Figure.3 shows the device functionality and hysteresis Vcc Vcc North Figure.2 BOP South BRP North Switching Function Uni-polar (North) BOP South Switching Function Uni-polar (South) Figure.3 SOT-23 BRP SOT-23 (Thin Outline) / Flat TO-92 / SOT-89B 7 Function Description BOP: Operating Point, Magnetic flux density applied on the branded side of the package which turns the output driver ON (VOUT=Low) BRP: Releasing Point, Magnetic flux density applied on the branded side of the package which turns the output driver OFF (VOUT=High) BHYST: Hysteresis Window, |BOP - BRP| Devices that have a lower magnetic threshold (VOUT=High) detect magnets at a farther distance. Higher thresholds (VOUT=Low) generally require a closer distance or larger magnet. 8 Feature Description S N N N N S S S SOT-23 Flat TO-92 SOT-23 SOT-89B Figure.4 (Thin Outline) Motion The MT831X device is sensitive to the magnetic field component that is perpendicular to the top of the package S N N N N S S S SOT-23 Flat TO-92 SOT-23 SOT-89B (Thin Outline) PCB PCB VOUT = Low VOUT= High Flux Direction Polarity magntek.com.cn | Magnetic Tech Makes Magic Change 3 Rev 1.8 MT831X Uni-polar, High Voltage Hall-Effect Switch IC 9 Functional Block Diagram Vcc Reference Dynamic Offset Cancelation Regulator Limiting Current Protection Out ESD ESD Hall Plate ITA COMP Output Driver GND Figure.5 Functional Block Diagram 10 Electrical and Magnetic Characteristics 10.1 Absolute Maximum Ratings Absolute maximum ratings are limited values to be applied individually, and beyond which the serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to absolute maximum rating conditions for an extended period of time may affect device reliability. Symbol Parameters Min Max Units VCC Supply Voltage - 65 V VRCC Reverse Battery Voltage -20 - V VOUT Output Voltage - 65 V IOUT Continuous Output Current - 40 mA TA Operating Ambient Temperature -40 150 ℃ TS Storage Temperature -50 150 ℃ TJ Junction Temperature - 165 ℃ B Magnetic Flux Density No Limit Gs 10.2 ESD Ratings Symbol VESD Reference Values Unit Human-body model (HBM) AEC-Q100-002 Class II Grade Charged-device model (CDM) AEC-Q100-011 Class C6 Grade magntek.com.cn | Magnetic Tech Makes Magic Change 4 Rev 1.8 MT831X Uni-polar, High Voltage Hall-Effect Switch IC 10.3 Electrical Specifications At TA=-40~150 ℃, Vcc=3.8V~60V (unless otherwise specified) Symbol Parameters Test Condition Min Typ Max Unit VCC Supply Voltage Operating 3.8 - 60 V ICC Supply Current BBOP, VOUT=Vcc - 50 - mA VDSON Output Saturation Voltage IOUT=15mA, B>BOP - - 0.4 V IOFF Output Leakage Current VOUT=24V, ∣B∣5V/uS B>BOP(MAX) - - 10 us FC Chopping Frequency - 800 - KHz FS Sampling Frequency - 200 - KHz Thermal Resistance of SOT-23 - 301 - ℃/W Thermal Resistance of SOT-23 (Thin Outline) - 301 - ℃/W Thermal Resistance of TO-92 - 230 - ℃/W Thermal Resistance of SOT-89B - 230 - ℃/W RTH 10.4 Magnetic Characteristics At VCC=3.8V~60V (unless otherwise specified) Part No. MT8311 Series MT8312 Series MT8313 Series MT8315 Series Symbol Min Typ Max Unit BOP, TA =25℃ 110 140 170 Gs BRP, TA =25℃ 75 105 135 Gs BHYST, TA =25℃ 20 35 50 Gs BOP, TA =25℃ 210 255 300 Gs BRP, TA =25℃ 165 210 255 Gs BHYST, TA =25℃ 30 45 60 Gs BOP, TA =25℃ 60 85 110 Gs BRP, TA =25℃ 25 50 75 Gs BHYST, TA =25℃ 20 35 50 Gs BOP, TA =25℃ 20 30 40 Gs BRP, TA =25℃ 10 20 30 Gs BHYST, TA =25℃ 3 10 17 Gs magntek.com.cn | Magnetic Tech Makes Magic Change 5 Rev 1.8 MT831X Uni-polar, High Voltage Hall-Effect Switch IC 10.5 Characteristic Performance Supply Current (mA) At VCC=5V 6 5 4 3 2 1 0 -40 25 85 125 150 Temperature ℃ Figure.6 Supply Current vs. Temperature MT8311 MT8312 165 MT8313 300 150 250 90 75 60 45 Bop 30 150 100 Bop 50 Brp 15 200 0 25 85 125 150 60 50 40 30 Bop 25 85 125 150 20 15 10 25 85 125 -40 150 85 125 150 Magnetic Characteristics vs. Temperature (BOP & BRP) MT8312 MT8313 MT8315 50 50 50 50 40 30 20 10 40 30 20 10 0 125 Temperature ℃ 150 40 30 20 10 0 85 Magnetic Field Intensity (Gs) 60 Magnetic Field Intensity (Gs) 60 Magnetic Field Intensity (Gs) 60 Figure.8 25 Temperature ℃ Temperature ℃ 60 25 Brp 0 -40 Temperature ℃ MT8311 -40 Bop 5 Brp 10 0 -40 Temperature ℃ Figure.7 70 20 Brp 0 -40 Magnetic Field Intensity (Gs) 105 25 80 Magnetic Field Intensity (Gs) 120 Magnetic Field Intensity (Gs) Magnetic Field Intensity (Gs) 30 90 135 Magnetic Field Intensity (Gs) MT8315 100 25 85 125 150 20 0 -40 Temperature ℃ 30 10 0 -40 40 25 85 125 150 -40 25 Temperature ℃ Magnetic Characteristics vs. Temperature (BHYST) magntek.com.cn | Magnetic Tech Makes Magic Change 6 85 125 Temperature ℃ Rev 1.8 150 MT831X Uni-polar, High Voltage Hall-Effect Switch IC 10.6 Typical Output Waveform MT8311A as example B BOP BRP T V High Low Figure.9 T Digital Output vs. Magnetic Flux Density 11 Typical Application Circuit MT8311AT as example Note: Recommended value for RL is 1KOhms to 10KOhms C1=100nF Vcc 1 RL 按钮 Vcc OUT 3 GND GND 2 Out C2=1nF Figure.10 Typical Application Circuit magntek.com.cn | Magnetic Tech Makes Magic Change 7 Rev 1.8 MT831X Uni-polar, High Voltage Hall-Effect Switch IC 12 Package Material Information (For Reference Only – Not for Tooling Use) 12.1 SOT-23 Package Information 3 XXXX 按钮 Product ID 按钮 2 1 OUT Vcc Figure.11 DateCode: Y: Year W: Week YW GND XXXX YW SOT-23 Chip Marking Spec Sensing Center Figure.12 SOT-23 Package Drawing Symbol Dimensions in Millimeters Dimensions in Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950 TYP 0.037 TYP e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0︒ 8︒ 0︒ 8︒ x 1.460 TYP 0.057 TYP y 0.800 TYP 0.032 TYP z 0.600 TYP 0.024 TYP magntek.com.cn | Magnetic Tech Makes Magic Change 8 Rev 1.8 MT831X Uni-polar, High Voltage Hall-Effect Switch IC 12.2 SOT-23 (Thin Outline) Package Information GND XXXX YW 3 Product ID 22 11 OUT Vcc Figure.13 YW 3 XXXX 按钮 DateCode: Y: Year W: Week SOT-23 (Thin Outline) Chip Marking Spec Sensing Center Figure.14 SOT-23 (Thin Outline) Package Drawing Symbol Dimensions in Millimeters Dimensions in Inches Min Max Min Max A 0.900 1.150 0.035 0.045 A1 0.000 0.100 0.000 0.004 A2 0.900 1.050 0.035 0.041 b 0.300 0.500 0.012 0.020 c 0.080 0.150 0.003 0.006 D 2.800 3.000 0.110 0.118 E 1.200 1.400 0.047 0.055 E1 2.250 2.550 0.089 0.100 e e1 0.950 TYP 1.800 L 0.037 TYP 2.000 0.071 0.550 REF 0.079 0.022 REF L1 0.300 0.500 0.012 0.020 θ 0︒ 8︒ 0︒ 8︒ x 1.460 TYP 0.057 TYP y 0.650 TYP 0.026 TYP z 0.500 TYP 0.020 TYP magntek.com.cn | Magnetic Tech Makes Magic Change 9 Rev 1.8 MT831X Uni-polar, High Voltage Hall-Effect Switch IC 12.3 Flat TO-92 Package Information XXXX XXXX YWW Product ID YWW DateCode: week (01~55) DateCode: year (0~9) 3 OUT 2 GND 1 Vcc Figure.15 Flat TO-92 Chip Marking Spec Sensing Center Figure.16 Flat TO-92 Package Drawing Symbol Dimensions in Millimeters Dimensions in Inches Min Max Min Max A 1.420 1.620 0.056 0.064 A1 0.660 0.860 0.026 0.034 b 0.350 0.480 0.013 0.019 b1 0.400 0.510 0.016 0.020 c 0.330 0.510 0.013 0.020 D 3.900 4.100 0.154 0.161 D1 2.280 2.680 0.090 0.106 E 3.050 3.250 0.120 0.128 e 1.270 TYP 0.050 TYP e1 2.440 2.640 0.096 0.104 L 14.350 14.750 0.565 0.581 θ 45︒ TYP 45︒ TYP x 2.025 TYP 0.080 TYP y 1.545 TYP 0.061 TYP z 0.500 TYP 0.020 TYP magntek.com.cn | Magnetic Tech Makes Magic Change 10 Rev 1.8 MT831X Uni-polar, High Voltage Hall-Effect Switch IC 12.4 Flat TO-92 Package Information (Radial Lead) XXXX XXXX YWW Product ID YWW DateCode: week (01~55) DateCode: year (0~9) 3 OUT 2 GND 1 Vcc Figure.17 Flat TO-92 (Radial Lead) Chip Marking Spec Sensing Center Figure.18 Flat TO-92 (Radial Lead) Package Drawing Symbol Dimensions in Millimeters Dimensions in Inches Min Max Min Max A 1.420 1.620 0.056 0.064 A1 0.660 0.860 0.026 0.034 b 0.350 0.480 0.013 0.019 b1 0.400 0.510 0.016 0.020 c 0.330 0.510 0.013 0.020 D 3.900 4.100 0.154 0.161 D1 2.280 2.680 0.090 0.106 E 3.050 3.250 0.120 0.128 e 2.540 TYP 0.100 TYP e1 5.000 TYP 0.197 TYP L1 2.000 TYP 0.079 TYP L 13.88 TYP 0.546 TYP θ 45︒ TYP 45︒ TYP x 2.025 TYP 0.080 TYP y 1.545 TYP 0.061 TYP z 0.500 TYP 0.020 TYP magntek.com.cn | Magnetic Tech Makes Magic Change 11 Rev 1.8 MT831X Uni-polar, High Voltage Hall-Effect Switch IC 12.5 SOT-89B Package Information XXXX XXXX YWW Product ID 3 2 1 按钮 YWW OUT GND Vcc DateCode: week (01~55) DateCode: year (0~9) Figure.19 SOT-89B Chip Marking Spec Sensing Center Figure.20 SOT-89B Package Drawing Symbol Dimensions in Millimeters Dimensions in Inches Min Max Min Max A2 1.220 1.420 0.048 0.056 A1 0.000 0.100 0.000 0.004 b 0.300 0.500 0.012 0.020 c 0.052 0.252 0.002 0.010 D 4.400 4.600 0.173 0.181 b1 1.600 1.800 0.063 0.071 E 2.400 2.600 0.094 0.102 HE 4.000 4.400 0.157 0.173 e 1.400 1.600 0.055 0.063 L 0.350 0.550 0.014 0.022 x 2.250 TYP 0.089 TYP y 1.250 TYP 0.049 TYP z 0.300 TYP 0.012 TYP magntek.com.cn | Magnetic Tech Makes Magic Change 12 Rev 1.8 MT831X Uni-polar, High Voltage Hall-Effect Switch IC 13 Copy Rights and Disclaimer 1. This document may not be reproduced or duplicated, in any form, in whole or in part without prior written consent of MagnTek . Copyrights © 2019, MagnTek Incorporated. 2. MagnTek reserves the right to make changes to the information published in this document at anytime without notice. 3. MagnTek’s products are limited for use in normal commercial applications. MagnTek’s products are not to be used in any device or system, including but not limited to medical life support equipment and system. For the latest version of this document, please visit our website: www.magntek.com.cn magntek.com.cn | Magnetic Tech Makes Magic Change 13 Rev 1.8
MT8311A 价格&库存
很抱歉,暂时无法提供与“MT8311A”相匹配的价格&库存,您可以联系我们找货
