MTR611CT
MTR611CT
    MAGNTEK(麦歌恩)
    SOP-8
    磁角位置传感器
MTR611CT 数据手册
MTR611 Magnetic Angle Position Sensor Features and Benefits ■ Based on AMR Sensing Technology ■ Contactless Angle Measurement ■ Wide Voltage Range up to 12V ■ Wide Operation Temperature Range from -40℃ ~125℃ ■ RoHS Compliant 2011/65/EU Applications ■ High Accuracy Angular Position Sensing ■ Rotary Speed and Direction Detection ■ Contactless Angle Detection ■ Motor Control ■ Robotics Control Pin Definition General Description The MTR611 is a magnetic field sensor IC based on advanced Anisotropic Magneto Resistor (AMR) technology. It creates an analog output voltage that varies with the direction of the magnetic flux passing over the sensor surface. It contains dual whetstones bridges operating in saturation mode and generating quadrature (sine and cosine) signals to perform angular measurement up to 180 degrees. It can operate under a wide supply voltage range and a wide temperature range. Combined with appropriate signal conditioning circuit, MTR611 is ideal for use in position sensing, rotary speed and direction detection systems. Num. magntek.de | Magnetic Tech Makes Magic Change 1 Name Description 1 B- Negative output of Bridge B 2 A- Negative output of Bridge A 3 NC Not Connected 4 Vs Bridge Supply Voltage 5 B+ Positive Output Bridge B 6 A+ Positive Output Bridge A 7 NC Not Connected 8 Gnd Ground Rev 1.2 2019.03 MTR611 Magnetic Angle Position Sensor Figure 1 and 2 shows the basic operation of the sensor. When an external magnetic field rotates clockwise, output A and B produce cosine and sine waveforms respectively, as also shown in the expressions below. V α V α 45 60 V 2 V 2 cos 2α sin 2α 80 60 Output voltage(mV) 40 20 0 0 15 30 75 90 105 120 135 150 165 180 ‐20 ‐40 ‐60 ‐80 angle (deg) Figure 1: Typical Transfer Curve of MTR611 at room Temperature and the Magnet is Rotating in the Clockwise Direction from a Top-down View. (Bridge A Output=Red curve; Bridge B Output=Black Curve) Figure 2: Magnetic Field Rotation Direction and the Definition of Zero Degree Position magntek.de | Magnetic Tech Makes Magic Change 2 Rev 1.2 2019.03 MTR611 Magnetic Angle Position Sensor Figure 3: Typical Arrangement of MTR611 and Magnet Block Diagram Vs B+ B- Vs A+ A- Figure 4: Block Diagram magntek.de | Magnetic Tech Makes Magic Change 3 Rev 1.2 2019.03 MTR611 Magnetic Angle Position Sensor Absolute Maximum Rating Absolute maximum ratings are limiting values to be applied individually, and beyond which the serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to absolute maximum rating conditions for an extended period of time may affect device reliability. Absolute maximum ratings: all voltages listed are referenced to GND. Symbol Paramters Min. Max. Unit Vs Supply Voltage -12 12 V Pd Power Dissipation 200 mW TA Operation Temperature -40 125 ℃ B Magnetic Flux 200 10000 Guass ESD (HBM) Electro-Static Discharge ±1000 V Electrical and Magnetic Characteristics At Vs=5.0V and TA=25℃ (Unless other specified) Symbol Parameter Conditions/Notes Vs Supply Voltage - ROUT Bridge Resistance Is Supply Current S Sensitivity Vamp Output Amplitude (peak to peak) Vos Offset Voltage K Synchronism OE Orthogonality Error TCA TCR Vampd Vosd S=Vamp*π/180 (VampA/VampB)*100 Min. Typ. Max. 5.0 12.0 V 0.8 1.0 1.2 KΩ - 5.0 - mA 1.66 2.00 2.36 mV/° 95 115 135 mV -2.0 - 2.0 mV/V 97 - 103 % -1.0 - 1.0 ° Temperature Coefficient for Output Amplitude Temperature Coefficient for Bridge Resistance Output Amplitude Temperature Drift Offset Voltage Temperature Drift Unit -3300 ppm/℃ 2800 ppm/℃ TA=-40℃~125℃ -45 33 % TA=-40℃~125℃ -300 300 uV/V magntek.de | Magnetic Tech Makes Magic Change 4 Rev 1.2 2019.03 MTR611 Magnetic Angle Position Sensor Application Circuit U1 VCC 5.0V Vs U2 .01uf Bridge A AA+ 249k 10.0k + 10.0k AMP AN0 U2A Microcontroller 249k Vref MTR611 .01uf Bridge B BB+ Gnd 249k 10.0k + 10.0k AMP AN1 U2B 249k Vref Figure 5: MTR611 Followed by Differential-to-Single-End Amplification Circuit Figure 6: MTR611 with Optional Offset Trimming Circuits magntek.de | Magnetic Tech Makes Magic Change 5 Rev 1.2 2019.03 MTR611 Magnetic Angle Position Sensor Package Information (SOP-8) Symbol Dimensions in Millimeters Dimensions in Inches Min. Max. Min. Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.007 0.010 D 4.700 5.100 0.185 0.201 E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 e 1.270(BSC) 0.050(BSC) L 0.400 0.800 0.016 0.031 θ 0˚ 8˚ 0˚ 8˚ magntek.de | Magnetic Tech Makes Magic Change 6 Rev 1.2 2019.03
MTR611CT
物料型号:MTR611
器件简介:MTR611是一款基于先进各向异性磁阻(AMR)技术的磁场传感器IC。它通过感应磁场的变化产生模拟输出电压,可进行高达180度的角度测量。
引脚分配: - 1: B- (Bridge B的负输出) - 2: A- (Bridge A的负输出) - 3: NC (未连接) - 4: Vs (桥接供电电压) - 5: B+ (Bridge B的正输出) - 6: A+ (Bridge A的正输出) - 7: NC (未连接) - 8: Gnd (地)
参数特性: - 供电电压范围:-12V至12V - 工作温度范围:-40℃至125℃ - 符合RoHS指令2011/65/EU - 电源电流:5mA - 灵敏度:1.66至2.36 mV/度 - 输出幅度(峰-峰值):95至135 mV - 偏置电压:-2.0至2.0 mV/V
功能详解: - 传感器在外部磁场旋转时,输出A和B分别产生余弦和正弦波形,用于角度测量。 - 典型应用包括高精度角度位置传感、旋转速度和方向检测、无接触角度检测、电机控制和机器人控制。
应用信息: - MTR611适用于需要高精度角度位置传感的场合,如电机控制和机器人控制。
封装信息: - SOP-8封装,感应中心位于几何中心。
MTR611CT 价格&库存
很抱歉,暂时无法提供与“MTR611CT”相匹配的价格&库存,您可以联系我们找货
