MT890X
Dual Hall Effect Latch with Speed & Direction Output
1 Product Description
The MT890X family is a Hall-effect dual latch produced
by BCD technology with both high performance and
high reliability. The Hall IC internally includes an onchip Hall voltage generator, a voltage regulator for
operation with supply voltage of 2.7V to 24V,
temperature compensation circuitry, small-signal
amplifier, Hall IC with dynamic offset cancellation
system, Schmitt trigger and two open drain output, all
in a single package.
Two Hall plates are integrated on the same chip, and
using the high precision of the wafer fabrication
process to ensure a fixed spacing of 1.45mm between
the sensing elements. The first Hall plate provide the
speed signal output. The combination of both the Hall
plate signals is then internally processed to directly
deliver a direction signal output.
4 Applications
■ Windows Lifter with Anti-Pinch Feature
■ Rotation Speed & Direction Detection
■ Linear Speed & Direction Detection
The MT890X family provides SOT-23-6L for surface
mount to customers & flat TO-94 for through-hole
mount. All packages are RoHS compliant.
2 Features
Two Integrated Hall Plates for Direction Detection
2.7~24V Operating VDD Range
-40℃~150℃ Operating Temperature
Package Option:
SOT-23-6L
Flat TO-94
Magnetic Sensitivity Option:
MT8901 (BOP=25Gs, BRP=-25Gs)
Speed & Direction Open-Drain Output
Dual Speed Open-Drain Output
Self-diagnosis
-30V Reversed Power Supply Protection
Output Over Current Protection
RoHS Compliant: (EU)2015/863
3 Product Overview of MT890X
SOT-23-6L, tape & reel (3000pcs/bag)
MT890XAT-SD
Description
SP1
1
Speed Signal Out1
NC
2
Unconnected
SP2 or DIR
3
Speed Signal Out2 or
Direction Signal Out
VDD
4
Power Supply
GND
5
Ground
GND
6
Ground
Flat TO-94
No.
Description
VDD
1
Power Supply
SP2 or DIR
2
SP1
3
Speed Signal Out1
GND
4
Ground
4
MT890XAT-SS
No.
5
Description
SOT-23-6L
6
Part No.
5 Pin Configuration and Functions
H1
VDD
GND
H1
H2
按钮
SP1
GND
3
SP2 or DIR
SP2 or DIR
2
Figure.1
Vcc
NC
1
Note:
SS: SP1 + SP2
SD: SP1 + DIR
1
2
3
4
Pin Configuration & Functions
SOT-23-6L & Flat TO-94 Top-View
magntek.com.cn | Magnetic Tech Makes Magic Change
H2
1.45mm
SP1
MT890XA-SD
GND
MT890XA-SS
Flat TO-94, bulk packaging
(1000pcs/bag)
(1000pcs/bag)
1.45
mm
1
Rev
1.3
MT890X
Table of Contents
1
Product Description………...…….……………….……...…………………………………….…….………1
2
Features……………………………….……..……………………………………………………………….…….1
3
Product Overview of MT890X ..…………………………………………………………………………1
4
Applications……………………………………………………………………………………………………….1
5
Pin Configuration and Functions…………………………………………………….………………….1
6
Functional Block Diagram…………………………………………………………………………………..3
7
Electrical and Magnetic Characteristics………………………………………………………………3
7.1 Absolute Maximum Ratings………………………………………………………………………………….3
7.2 Electrical Specifications………….……………………………………………………………………………..4
7.3 ESD Rating……………………………………………………………………………………………………………4
7.4 Magnetic Characteristics ……………………………………………………………………………………..5
7.4.1 MT8901 Series …………..………………………………………………………………………………5
7.5 Characteristic Performance………………………………………………………………………………..5
8
Output Behavior vs. Magnetic Pole (SP1+ SP2 Mode)…..…………..……………………….6
8.1 Typical Output Waveform (SP1+ SP2 Mode)……………….……………………………………....6
9
Output Behavior vs. Magnetic Pole (SP1 + DIR Mode)………………….……………………7
9.1 Typical Output Waveform (SP1 + DIR Mode)…………………………………………………….....7
10
Typical Application Circuit……………………………………………..…….…………………………..8
11
Self-diagnosis…………………..………………………………………………………………………………9
12
Package Material Information…………………………………………………………………………11
11.1 SOT-23-6L Package Information…………………….…………………………………………………11
11.2 Flat TO-94 Package Information……………………………………………………………………..12
13
Copy Rights and Disclaimer……………………………………………………………………………..13
1
2
3
Original Version
Version 1.1
Version 1.2
4
Version 1.3
Reversion History
Update marking spec
Update MT890XA Series
Update the description of self-diagnosis
Add characteristic performance
2
Rev
1.3
MT890X
6 Functional Block Diagram
VDD
Regulator
Limiting
Current
Protection
Hall Plate 1
AMP
COMP
Hall Plate 2
AMP
COMP
SP1
Open Drain
Output
Direction
Detection
Open Drain
Output
SP2 or DIR
Reference
GND
Figure.2
7 Electrical and Magnetic Characteristics
Absolute maximum ratings are limited values to be applied individually, and beyond which the
serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to
absolute maximum rating conditions for an extended period of time may affect device reliability.
Symbol
Parameters
Min
Max
Units
VDD
Supply Voltage
30
V
VRDD
Reverse Battery Voltage
-30
V
VOUT
Output Voltage
-0.7
30
V
IOUT
Continuous Output Current
40
mA
TA
Operating Ambient Temperature
-40
150
TS
Storage Temperature
-50
160
TJ
Junction Temperature
165
B
Magnetic Flux Density
No Limit
3
Gs
Rev
1.3
MT890X
At TA=-40~150 ℃, VDD=2.7V~24V (unless otherwise specified)
Symbol
Parameters
Test Condition
Min
Typ
Max
Unit
VDD
Supply Voltage
Operating
2.7
24
V
IDD
Supply Current
FS=100kHz
4.5
7.5
mA
IOCP
Short Circuit Protection Current
B>BOP,
VOUT=VDD
30
mA
VDSON
Output Saturation Voltage
IOUT=10mA,
B>BOP
0.4
V
IOFF
Output Leakage Current
VOUT=24V,
∣B∣5V/uS
B>BOP(MAX)
us
FS
Sampling Frequency
100
KHz
TD
Delay Time
1.2
us
Thermal Resistance of SOT-23-6L
301
℃/W
RTH
Refer to Figure.5
Thermal Resistance of Flat TO-94
230
℃/W
Notes:
(1) TPO here is defined when self-diagnosis is disabled. If self-diagnosis is enabled, please refer
to the tedge3 in Part 11 (Self-diagnosis)
7.3 ESD Ratings
Symbol
VESD
Reference
Values
Unit
Human-body model (HBM)
AEC-Q100-002
Class H3
Grade
Charged-device model (CDM)
AEC-Q100-011
Class C3
Grade
4
Rev
1.3
MT890X
At VDD=2.7V~24V (unless otherwise specified)
7.4.1 MT8901 Series
Parameter
Symbol
Min
Typ
Max
Unit
Operating Point
BOP, TA =25℃
10
25
40
Gs
Release Point
BRP, TA =25℃
-40
-25
-10
Gs
Hysteresis Window
BHYST, TA =25℃
80
Gs
Magnetic Matching
BOP1-BOP2 or BRP1-BRP2,
TA=25℃
-10
10
Gs
Magnetic Offset
BOP1+BRP1 or BOP2+BRP2,
TA=25℃
-10
10
Gs
Temperature Coefficient
Hall Sensor Spacing
-1000
ppm/℃
1.45
mm
Supply Current (mA)
6
5.5
5
VDD=5V
4.5
VDD=2.7V
4
VDD=12V
3.5
VDD=24V
3
-40
Magnetic Field Intensity
(Gs)
Figure.3
25
85
125
150
Supply Current vs. Temperature & VDD
30
Bop @ VDD=2.7V
Brp @ VDD=2.7V
Bop @ VDD=5V
10
Brp @ VDD=5V
-40
85
125
Bop @ VDD=12V
150
Brp @ VDD=12V
-20
Bop @ VDD=24V
-30
Brp @ VDD=24V
Figure.4
(Gs)
Magnetic Characteristics vs. Temperature & VDD (BOP & BRP)
60
55
50
Bhyst @ VDD=2.7V
45
Bhyst @ VDD=5V
40
Bhyst @ VDD=12V
35
Bhyst @ VDD=24V
30
-40
Figure.5
85
125
150
Magnetic Characteristics vs. Temperature & VDD (BHYST)
5
Rev
1.3
MT890X
8 Output Behavior vs. Magnetic Pole (SP1 + SP2 Mode)
Part No.
Parameter
Test
Conditions
SP Output
State
SOT-23
Series
South Pole
B>BOP
Low
North Pole
BBOP
Low
South Pole
B
很抱歉,暂时无法提供与“MT8901AT-SD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.96560
- 10+1.81440
- 30+1.78416
- 100+1.69344
