MT6131AT
MT6131AT
    MAGNTEK(麦歌恩)
    SOT-23
    磁性编码器 SOT-23 1.65~5V Mechanical
MT6131AT 数据手册
MT613X Omni-polar, Low Power, 360 Degree Switch IC 1 Product Description The MT613X family is produced with monolithic technology,which builds AMR sensor & ASIC on one chip. The IC internally includes a Wheatstone bridge with magnetic film, a current regulator for operating with supply voltage from 1.65V to 5.0V, a sleep/awake logic for low power consumption requirement, small signal amplifier and Schmitt trigger comparator with dynamic offset cancellation, and an output driver with push pull output. When combined with a magnet, it becomes a noncontact switch with low power consumption, high sensitivity and high reliability. All directions of horizontal magnetic field parallel to the electrode of the package can be detected by an arbitrary polarity. 4 Application The MT613X family provide SOT-23 for surface mount, RoHS compliant. 2 Features ■ ■ ■ ■ ■ ■ ■ ■ ■ Home appliances, Industrial Position Detection Proximity Switch Smart Meter Speed Detection Handheld Device Consumer Device 5. Pin Configuration and Functions VCC Out GND SOT-23 1 2 3 Description Power Output Push Pull or Open Drain SOT-23 Top-View GND 3 ■ ■ Monolithic Technology 360 Degree AMR (Anisotropic Magneto Resistance) Omni-polar Switch 1.65~5.0V Operating Vcc Range -40℃~125℃ Operating Temperature Package Option: SOT-23 Magnetic Sensitivity Option: BOP=±18Gs, BRP=±13Gs Push Pull & Open Drain Output Option: MT6131 & MT6132: Push Pull MT6133 & MT6135: Open Drain Operation Frequency Option: MT6131 & MT6133: 20Hz MT6132 & MT6135: 1KHz Low Power Consumption RoHS Compliant: (EU)2015/863 ■ ■ ■ ■ ■ ■ ■ 按钮 SOT-23, tape & reel (3000pcs/bag) OUT MT613XAT 2 Description Vcc Part No. 1 3 Product Overview of MT613X Figure.1 Pin Configuration TO-92& Functions Top-View magntek.com.cn | Magnetic Tech Makes Magic Change 1 Rev 1.1 Ground MT613X Omni-polar, Low Power, 360 Degree Switch IC Table of Contents 1 Product Description………….……………...…….……...…………………………………….…….………1 2 Features……………………………….……..……………………………………………………………….…….1 3 Product Overview of MT613X ..……………….…………………………………………………………1 4 Applications……………………………………………………………………………………………………….1 5 Pin Configuration and Functions…………………………………………………….………………….1 6 Definition of Switching Function……………………………………………………………………….3 7 Function Description…......…………………………………………………………………………………..3 8 Feature Description……………………………………………………………………………………………3 9 Functional Block Diagram…………………………………………………………………………………..4 10 Electrical and Magnetic Characteristics………………………………………………………………5 10.1 Absolute Maximum Ratings……………………………………………………………………………….5 10.2 Electrical Specifications………………………………….………………………………………………..5 10.3 Magnetic Characteristics……………………………………………………………………………………6 10.4 ESD Ratings………………………………………………………………………………………………………..6 10.5 Characteristic Performance………………………………………………………………….…………….6 10.6 Typical Output Waveform…………………………………………………………………………………..7 11 Typical Application Circuit………………………………………………………………………………….7 12 Power on Output Waveform………………………………………………………………………………8 13 Package Material Information……………………………………………………………………………9 13.1 SOT-23 Package Information……………………………...………………………………………………9 14 1 2 Copy Rights and Disclaimer……………………………………………………………………………..10 Originally Version 1.1 Version Reversion History magntek.com.cn | Magnetic Tech Makes Magic Change Update supply current Update the marking spec of SOT-23 2 Rev 1.1 MT613X Omni-polar, Low Power, 360 Degree Switch IC 6 Definition of Switching Function Figure.2 shows the device functionality and hysteresis Vcc North Figure.2 BOP N BRP N BRP S BOP S South Omni-polar Switching Function 7 Function Description BOP: Operating Point, Magnetic flux density applied on the branded side of the package which turns the output driver ON (VOUT=Low) BRP: Releasing Point, Magnetic flux density applied on the branded side of the package which turns the output driver OFF (VOUT=High) BHYST: Hysteresis Window, |BOP - BRP| 8 Feature Description The MT613X series is sensitive to the magnetic field that is parallel to the package (X & Y axis). To operate the MR switch, the magnetic field should be applied to the sensor parallel to the package. MT613X series detect the magnetic field in any parallel direction, but it does not respond to magnetic field in the vertical direction. GND 3 按钮 1 2 Vcc OUT Figure.3 Direction of magnetic field (N or S) Detection of magnetic field magntek.com.cn | Magnetic Tech Makes Magic Change 3 Rev 1.1 MT613X Omni-polar, Low Power, 360 Degree Switch IC 9 Functional Block Diagram Vcc Sleep/Awake Logic Regulator ESD Dynamic Offset Cancellation Out AMR AMP COMP Output Driver AMR GND Figure.4 Functional Block Diagram (MT6131 & MT6132) Vcc Sleep/Awake Logic Regulator ESD Dynamic Offset Cancellation Out AMR AMP COMP Output Driver AMR GND Figure.5 Functional Block Diagram (MT6133 & MT6135) magntek.com.cn | Magnetic Tech Makes Magic Change 4 Rev 1.1 MT613X Omni-polar, Low Power, 360 Degree Switch IC 10 Electrical and Magnetic Characteristics 10.1 Absolute Maximum Ratings Absolute maximum ratings are limited values to be applied individually, and beyond which the serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to absolute maximum rating conditions for an extended period of time may affect device reliability. Symbol Parameters Min Max Units VCC Supply Voltage - 7 V VRCC Reverse Battery Voltage -0.4 - V VOUT Output Voltage - 7 V IOUT Continuous Output Current - 20 mA TA Operating Ambient Temperature -40 125 ℃ TS Storage Temperature -50 150 ℃ TJ Junction Temperature - 165 ℃ B Magnetic Flux Density 1200 Gs 10.2 Electrical Specifications At TA=-40~125℃, VCC=1.65V~5.0V (unless otherwise specified) Symbol Parameters Test Condition Min Typ Max Unit VCC Supply Voltage Operating 1.65 3.60 5.00 V MT6131 & MT6133, VCC=3.6V, ∣B∣∣BOP∣ - - 0.4 V IOFF Output Leakage Current VOUT=5V, ∣B∣3.6V/us, B>BOP(MAX) - 80 120 us MT6131 & MT6133, VCC=3.6V 10 20 - Hz MT6132 & MT6135, VCC=3.6V 0.5K 1K - Hz VCC=3.6V - 16 - us MT6131 & MT6133, VCC=3.6V - 50 - ms MT6132 & MT6135, VCC=3.6V - 1 - ms MT6131 & MT6133, VCC=3.6V - 0.03 - % MT6132 & MT6135, VCC=3.6V - 1.50 - % - 301 - ℃/W FOP Operation Frequency TAW Awake Time TSL Sleep Time D.C. Duty Cycle RTH Thermal Resistance of SOT-23 magntek.com.cn | Magnetic Tech Makes Magic Change 5 Rev 1.1 MT613X Omni-polar, Low Power, 360 Degree Switch IC 10.3 Magnetic Characteristics At TA =25℃, VCC=1.65V~5.0V (unless otherwise specified) Part No. Symbol MT613X Series Min Typ Max Unit BOP - ±18 ±28 Gs BRP ±3 ±13 - Gs - 5 - Gs BHYST 10.4 ESD Ratings Symbol VESD Reference Values Unit Human-body model (HBM) AEC-Q100-002 4000 V Charged-device model (CDM) AEC-Q100-011 1000 V 10.5 Characteristic Performance 5 Supply Current (uA) 4.5 4 3.5 3 Vcc=1.65V 2.5 2 Vcc=3.6V 1.5 Vcc=5.0V 1 0.5 0 -40 125 30 Bop (90 Degree) Brp (90 Degree) Bop (180 Degree) Brp (180 Degree) 15 25 20 15 10 5 0 Bhyst (90 Degree) Bhyst (180 Degree) 12 9 6 3 0 -40 Figure.7 150 Supply Current vs. Temperature 35 Magnetic Field Intensity (Gs) 85 Magnetic Field Intensity (Gs) Figure.6 25 25 85 125 150 Magnetic Characteristics vs. Temperature -40 ℃ Figure.8 25 85 125 150 Magnetic Characteristics vs. Temperature (BOP & BRP) (At VCC=3.6V) (BHYST) (At VCC=3.6V) Magnetic Field @ 90 Degree & 180 Degree Magnetic Field @ 90 Degree & 180 Degree magntek.com.cn | Magnetic Tech Makes Magic Change 6 Rev 1.1 ℃ MT613X Omni-polar, Low Power, 360 Degree Switch IC 10.5 Characteristic Performance (continued) 330 315 300 285 34525 0 15 20 30 45 15 60 10 75 5 270 90 0 255 105 240 225 210 Figure.9 Bop Brp 120 195 180 165 135 150 360 Degree Magnetic Characteristics (At VCC=3.6V, TA=25 ℃) 10.6 Typical Output Waveform MT6131AT as example B Sampling Pulse Magnetic Flux BOP S BRP S T BRP N BOP N On Off Output V High Low T Note: Output is not immediately updated until the chip wakes up from sleep mode and samples the input Figure.10 Digital Output vs. Magnetic Flux Density & Sampling Pulse magntek.com.cn | Magnetic Tech Makes Magic Change 7 Rev 1.1 MT613X Omni-polar, Low Power, 360 Degree Switch IC 11 Typical Application Circuit C1=100nF C1=100nF Vcc OUT 3 GND RL = 100kΩ 1 按钮 Vcc GND 2 Out Vcc 1 按钮 Vcc OUT GND GND 2 Out C2=1nF Figure.11 3 C2=1nF Typical Application Circuit Figure.12 Typical Application Circuit Push Pull Output Open Drain Output MT6131 & MT 6132 MT6133 & MT 6135 12 Power on Output Waveform Output Magnetic Flux VCC VCC rise time < 1us, TPO is the time from the stable point of VCC to the valid point of output Figure.13 ∣B∣>∣BOP∣ ∣B∣
MT6131AT 价格&库存
很抱歉,暂时无法提供与“MT6131AT”相匹配的价格&库存,您可以联系我们找货
MT6131AT
  • 5+2.27880
  • 50+1.73880
  • 150+1.50120
  • 500+1.36080
  • 3000+1.23120
  • 6000+1.15560
库存:7635
