MT910X
Ratiometric Linear Hall-Effect IC, Analog Output
1 Product Description
The MT910X device is a linear Hall effect IC that
responds proportionally to magnetic flux density. The
device can be used for accurate position sensing in a
wide range of applications.
The device operates from 3.0V to 5.5V power
supplies. When no magnetic field is present, the
analog output drives ½ of VCC. The output changes
linearly with the applied magnetic flux density, and
four sensitivity options enable maximal output
voltage swing based on the required sensing range.
North and south magnetic poles produce unique
voltages.
The MT910X family provides a variety of packages to
customers. SOT-23 (Thin Outline) for surface mount
and flat TO-92 for through-hole mount. All packages
are RoHS compliant.
2 Features
BCD Technology
Factory-programmed
Ratiometric Rail to Rail Analog Output
Low-Noise Output
3.0~5.5V Operating Vcc Range
-40℃~150℃ Operating Temperature
Package Option:
Flat TO-92
■ Magnetic Sensitivity Option:
1.50mV/Gs MT9101 Series @Vcc = 5V
2.50mV/Gs MT9102 Series @Vcc = 5V
3.40mV/Gs MT9103 Series @Vcc = 5V
5.00mV/Gs MT9105 Series @Vcc = 5V
1.00mV/Gs MT9101 Series @Vcc = 3.3V
1.60mV/Gs MT9102 Series @Vcc = 3.3V
2.15mV/Gs MT9103 Series @Vcc = 3.3V
3.15mV/Gs MT9105 Series @Vcc = 3.3V
■ RoHS Compliant: (EU)2015/863
4 Applications
Home appliances
Industrial
Speed Detection
Position Detection
Magnetic Encoder
Ferrous Metal Sensing
Vibration Sensing
Weight Sensing
5. Pin Configuration and Functions
VCC
Out
GND
SOT-23
1
2
3
Flat TO-92
1
3
2
Description
Power
Output
Ground
(Thin Outline)
SOT-23
Thin Outline
Top-View
GND
3
3
按钮
Description
MT910XA
Flat TO-92, bulk packaging
(1000pcs/bag)
MT910XET
SOT-23 (Thin Outline), tape & reel
(3000pcs/bag)
Magntek.com.cn | Magnetic Tech Makes Magic Change
OUT
Vcc
3 Product Overview of MT910X
Part No.
22
11
TO-92
Top-View
Figure.1
1
OUT
3
GND
2
Vcc
1
Pin Configuration & Functions
Rev
1.4
MT910X
Table of Contents
1
Product Description………….…………………………...…………………………………….…….………1
2
Features…………………………….……..……………………………………….……………………….…….1
3
Product Overview of MT910X ..………….………………………………………………………………1
4
Applications……………………………………………………………………………………………………….1
5
Pin Configuration and Functions…………………………………………………….………………….1
6
Transfer Characteristics……………...……………………………………………………………………….3
7
Function Description……...…………………………………………………………………………………..3
8
Feature Description……………………………………………………………………………………………3
9
Functional Block Diagram…………………………………………………………………………………..4
10
Electrical and Magnetic Characteristics………………………………………………………………4
10.1 Absolute Maximum Ratings……………………………………………………………………………….4
10.2 ESD Ratings………………………………………………………………………………………………………..4
10.3 Electrical Specifications………..…………………………………………………………………………..5
10.4 Magnetic Characteristics……………………………………………………………………………………5
10.5 Characteristic Performance………………………………………………………………….…………….6
11
Typical Application Circuit………………………………………………………………………………….8
12
Package Material Information……………………………………………………………………………9
12.1 SOT-23 (Thin Outline) Package Information………………………………………………………9
12.2 Flat TO-92 Package Information……………………………………………………………...………10
13
Copy Rights and Disclaimer……………………………………………………………………………..11
1
2
3
4
5
Originally Version
Version 1.1
Version 1.2
Version 1.3
Version 1.4
Reversion History
Update characteristic performance & Noise
Update parameters @ 3.3V Vcc
Update the marking spec of SOT-23 (Thin Outline)
Update the drawing information of flat TO-92
2
Rev
1.4
MT910X
6 Transfer Characteristics
Finure.2 shows four sensitivity options enable maximal output voltage swing based on the required
sensing range
VCC = 5VDC
VCC = 3.3VDC
4.7
3.0
VOUT (V)
MT9101 1.5mV/Gs
MT9101 1.0mV/Gs
MT9102 2.5mV/Gs
2.5
MT9102 1.6mV/Gs
MT9103 3.4mV/Gs
1.625
MT9103 2.15mV/Gs
MT9105 5.0mV/Gs
MT9105 3.15mV/Gs
0.3
0.3
-1466
(N)
-880 -650 -440
Figure.2
Magnetic Range (Gauss)
1466
(S)
-1350
(N)
Transfer Characteristics (VCC=5V)
-850 -630 -430
Figure.3
1350
(S)
Transfer Characteristics (VCC=3.3V)
7 Function Description
The device produces a linear response when the output voltage is within the specified voltage range.
Outside this range, sensitivity is reduced and nonlinear
8 Feature Description
The MT910X device is sensitive to the magnetic field component that is perpendicular to the top of the
package
When the magnetic field moving from the left side of the IC to the middle which showed in the left of the
Figure.3, the VOUT changing from 0.3 to 2.5V linearity when VCC=5V
When the magnetic field located at the middle of the IC which showed in the middle of the Figure.3, the
VOUT is 2.5V (1/2 of the VCC=5V)
When the magnetic field moving from the middle side of the IC to the right which showed in the right of
the Figure.3, the VOUT changing from 2.5 to 4.7V linearity when VCC=5V
Figure.4
Feature Description
3
Rev
1.4
MT910X
9 Functional Block Diagram
Vcc
BG
VREF
Regulator
IREF
OSC
Phase
Power
Clamp
Out
Drv
TC-R
Spinning
current
Hall Plates
AMP
GND
Figure.5
10 Electrical and Magnetic Characteristics
Absolute maximum ratings are limited values to be applied individually, and beyond which the
serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to
absolute maximum rating conditions for an extended period of time may affect device reliability.
Symbol
Parameters
Min
Max
Units
VCC
Supply Voltage
30
V
VRCC
Reverse Battery Voltage
-0.2
V
VOUT
Output Voltage
30
V
IOUT
Continuous Output Current
-5
5
mA
TA
Operating Ambient Temperature
-40
150
TS
Storage Temperature
-40
160
TJ
Junction Temperature
165
10.2 ESD Ratings
Symbol
VESD
Reference
Values
Unit
Human-body model (HBM)
AEC-Q100-002
±3000
V
Charged-device model (CDM)
AEC-Q100-011
±1000
V
4
Rev
1.4
MT910X
At TA=-40~150 ℃, Vcc=3.0V~5.5V (unless otherwise specified)
Symbol
Parameters
VCC
Supply Voltage
ICC
Supply Current
TPO
Min
Typ
Max
Unit
3.0
5.5
V
VCC=5V; B=0
6.7
8.6
mA
VCC=3.3V; B=0
6.0
7.0
mA
Power on Time
dVCC/dt≥5V/us
30
us
ISINK
Sink Current
B=0; VOUT=VCC
-1.5
mA
ISOURCE
Source Current
B=0; VOUT=0
1.5
mA
BW
Bandwidth
KHz
FC
Chopper Frequency
780
KHz
B=0; TA=25℃
1.9
2.6
mG/root(Hz)
MT9101; TA=25℃
1.46
mVRMS
MT9102; TA=25℃
2.44
mVRMS
MT9103; TA=25℃
3.32
mVRMS
MT9105; TA=25℃
4.88
mVRMS
2
4
Ohm
4.7
Kohm
10
nF
Thermal Resistance of SOT-23 (Thin outline)
301
℃/W
Thermal Resistance of Flat TO-92
230
℃/W
NF
Noise
Test Condition
ROUT
Output Resistance
IOUT
很抱歉,暂时无法提供与“MT9105ET”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.69750
- 30+0.67500
- 100+0.63000
- 500+0.58500
- 1000+0.56250
- 国内价格
- 1+1.78319
- 10+1.40217
- 30+1.23887
- 100+1.03518
- 500+0.94446
- 1000+0.90731
- 国内价格
- 50+0.48539
- 500+0.47358
