MT816X
Latch, Hall-Effect Magnetic Position Sensor
1 Product Description
The MT816X family is produced by BCD technology
with both high performance and high reliability. The
Hall IC internally includes an on-chip Hall voltage
generator, a voltage regulator for operation with
supply voltage of 2.8V to 24V, a small-signal amplifier,
Hall sensors with dynamic offset cancellation, a
schmitt trigger and an open-drain output with overcurrent
protection.
It
features
temperature
compensation technique to make the magnetic
switching points stable over a wide temperature
range. Other key features such as reverse supply
voltage protection, output over-current protection
and ESD level exceeding ±5.5KV (HBM) make the IC
extremely robust and fault tolerant, which is
important in demanding application environment
such as automotive. Its extremely low operating
supply voltage 2.8V also makes it possible to add
external resistance in series with the supply pin for
even greater protection against high voltage
transients from the power supply.
4 Applications
When the magnetic flux density (B) is greater than the
operating point (BOP), the output turns on (Low). The
output is held steady till the magnetic flux density (B)
is less than the releasing point (BRP), at which point it
turns off (High).
5. Pin Configuration and Functions
2 Features
Out
GND
SOT-23
1
2
3
SOT-23
1
2
3
Flat TO-92
1
3
2
Description
Power
Output
Ground
Thin Outline
Description
MT8161A
Flat TO-92, bulk packaging
(1000pcs/bag)
MT8161AT
SOT-23, tape & reel (3000pcs/bag)
MT8161ET
SOT-23 (thin outline), tape & reel
(3000pcs/bag)
magntek.com.cn | Magnetic Tech Makes Magic Change
SOT-23
Thin Outline
Top-View
SOT-23
Top-View
22
GND
33
OUT
GND
11
3
3
Vcc
22
OUT
11
Vcc
TO-92
Top-View
3 Product Overview of MT816X
Part No.
Open-Drain
按钮
BCD Technology
Latch Switch
2.8~24V Operating Vcc Range
-40℃~150℃ Operating Temperature
Package Option:
Flat TO-92
SOT-23
SOT-23 (Thin Outline)
Magnetic Sensitivity Option:
BOP=20Gs, BRP=-20Gs
Open-Drain Output
-27V Reversed Power Supply Protection
Output Limiting Current Protection
RoHS Compliant: (EU)2015/863
VCC
按钮
Home appliances
Industrial
Speed Detection
Brushless DC Motor Communication
Figure.1
1
OUT
3
GND
2
Vcc
1
Pin Configuration & Functions
Rev
1.2
MT816X
Table of Contents
1
Product Description………….……………….……...………………………...……………….…….………1
2
Feature……………………………….……..……………………………………………………………….…….1
3
Product Overview of MT816X ..…………………………………………………………………………1
4
Applications……………………………………………………………………………………………………….1
5
Pin Configuration and Functions…………………………………………………….………………….1
6
Definition of Switching Function……………………………………………………………………….3
7
Function Description……...…………………………………………………………………………………..3
8
Feature Description……………………………………………………………………………………………3
9
Functional Block Diagram…………………………………………………………………………………..4
10
Electrical and Magnetic Characteristics………………………………………………………………4
10.1 Absolute Maximum Ratings……………………………………………………………………………….4
10.2 Electrical Specifications………..……………………………………………………………………………..5
10.3 Magnetic Characteristics……………………………………………………………………………………5
10.4 ESD Ratings………………………………………………………………………………………………………..5
10.5 Characteristic Performance………………………………………………………………….…………….6
10.6 Typical Output Waveform…………………………………………………………………………………..7
11
Typical Application Circuit………………………………………………………………………………….7
12
Package Material Information……………………………………………………………………………8
12.1 SOT-23 Package Information……………………………...………………………………………………8
12.2 SOT-23 Thin Outline Package Information………………………………………………………….9
12.3 Flat TO-92 Package Information……………………………………………………………………….10
13
Copy Rights and Disclaimer……………………………………………………………………………..13
1
2
Originally Version
1.1 Version
3
1.2 Version
Reversion History
Update BOP & BRP
Update Copy Rights and Disclaimer
Update the marking spec of SOT-23 & SOT23 (Thin Outline)
2
Rev
1.2
MT816X
6 Definition of Switching Function
Figure.2 & Figure.3 shows the device functionality and hysteresis
Vcc
North
BRP
Figure.2
Vcc
South
BOP
Switching Function of Flat TO-92 & SOT-23
North
BOP
Figure.3
South
BRP
Switching Function of SOT-23
(Thin Outline)
7 Function Description
BOP: Operating Point, Magnetic flux density applied on the branded side of the package which turns the
output driver ON (VOUT=Low)
BRP: Releasing Point, Magnetic flux density applied on the branded side of the package which turns the
output driver OFF (VOUT=High)
BHYST: Hysteresis Window, |BOP - BRP|
Devices that have a lower magnetic threshold (VOUT=High) detect magnets at a farther distance. Higher
thresholds (VOUT=Low) generally require a closer distance or larger magnet.
8 Feature Description
S
N
N
N
S
S
SOT-23
Flat TO-92
Figure.4
Motion
The MT816X device is sensitive to the magnetic field component that is perpendicular to the top of
the package
SOT-23
Thin Outline
S
N
N
N
S
S
SOT-23
Flat TO-92
SOT-23
PCB
PCB
VOUT = Low
VOUT= High
Thin Outline
Flux Direction Polarity
3
Rev
1.2
MT816X
9 Functional Block Diagram
Vcc
Reference
Dynamic
Offset
Cancelation
Regulator
Limiting
Current
Protection
Out
ESD
ESD
Hall Plate
ITA
COMP
Output Driver
GND
Figure.5
10 Electrical and Magnetic Characteristics
Absolute maximum ratings are limited values to be applied individually, and beyond which the
serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to
absolute maximum rating conditions for an extended period of time may affect device reliability.
Symbol
Parameters
Min
Max
Units
VCC
Supply Voltage
27
V
VRCC
Reverse Battery Voltage
-27
V
VOUT
Output Voltage
27
V
IOUT
Continuous Output Current
50
mA
TA
Operating Ambient Temperature
-40
150
TS
Storage Temperature
-50
150
TJ
Junction Temperature
165
B
Magnetic Flux Density
No Limit
4
Gs
Rev
1.2
MT816X
At TA=-40~150 ℃, VCC=2.8V~24V (unless otherwise specified)
Symbol
Parameters
Test Condition
Min
Typ
Max
Unit
VCC
Supply Voltage
Operating
2.8
24
V
ICC
Supply Current
BBOP,
VOUT=VCC
50
mA
VDSON
Output Saturation Voltage
IOUT=20mA,
B>BOP
0.4
V
IOFF
Output Leakage Current
VOUT=24V
10
uA
TR
Output Rise Time
RL=1KOhm,
CL=20pF
1.0
us
TF
Output Fall Time
RL=1KOhm,
CL=20pF
1.0
us
TPO
Power on Time
dVcc/dt>5V/uS
B>BOP(MAX)
10
us
FC
Chopping Frequency
800
KHz
FS
Sampling Frequency
400
KHz
Thermal Resistance of SOT-23
301
℃/W
Thermal Resistance of SOT-23 (Thin Outline)
301
℃/W
Thermal Resistance of TO-92
230
℃/W
RTH
At VCC=2.8V~24V (unless otherwise specified)
Part No.
Symbol
MT8161 Series
Min
Typ
Max
Unit
BOP, TA =25℃
10
Gs
BRP, TA =25℃
-30
-20
-10
Gs
BHYST, TA =25℃
60
Gs
10.4 ESD Ratings
Symbol
VESD
Reference
Values
Unit
Human-body model (HBM)
AEC-Q100-002
±5500
V
Charged-device model (CDM)
AEC-Q100-011
±1000
V
5
Rev
1.2
MT816X
Supply Current (mA)
At VCC=5V
4
3.5
3
2.5
2
1.5
1
0.5
Figure.6
-20
55
Temperature ℃
85
125
150
85
125
150
85
125
150
Supply Current vs. Temperature
Magnetic Field Intensity (Gs)
30
Bop
10
-40
-20
Brp
55
-20
-30
Figure.7
Temperature ℃
Magnetic Characteristics vs. Temperature (BOP & BRP)
80
70
60
50
40
30
Figure.8
-20
55
Temperature ℃
Magnetic Characteristics vs. Temperature (BHYST)
6
Rev
1.2
MT816X
MT8161A as example
B
BOP
BRP
T
V
High
Low
Figure.9
T
Digital Output vs. Magnetic Flux Density
11 Typical Application Circuit
MT8161AT as example
Note: Recommended value for RL is 1KOhms to 10KOhms
C1=100nF
Vcc
1
RL
按钮
Vcc
OUT
3
GND
GND
2
Out
C2=1nF
Figure.10
7
Rev
1.2
MT816X
12 Package Material Information (For Reference Only – Not for Tooling Use)
GND
XXXX YW
按钮
Product ID
按钮
2
1
OUT
Vcc
Figure.11
YW
3
XXXX
DateCode:
Y: Year W: Week
SOT-23 Chip Marking Spec
Sensing
Center
Figure.12
SOT-23 Package Drawing
Symbol
Dimensions in Millimeters
Dimensions in Inches
Min
Max
Min
Max
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.500
0.012
0.020
c
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
e
0.950 TYP
0.037 TYP
e1
1.800
2.000
0.071
0.079
L
0.300
0.600
0.012
0.024
θ
0︒
8︒
0︒
8︒
x
1.460 TYP
0.057 TYP
y
0.800 TYP
0.032 TYP
z
0.600 TYP
0.024 TYP
8
Rev
1.2
MT816X
12.2 SOT-23 (Thin Outline) Package Information
GND
XXXX YW
3
Product ID
22
11
OUT
Vcc
Figure.13
YW
3
XXXX
按钮
DateCode:
Y: Year W: Week
SOT-23 (Thin Outline) Chip Marking Spec
Sensing
Center
Figure.14
SOT-23 (Thin Outline) Package Drawing
Symbol
Min
Max
Min
Max
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
e
e1
0.950 TYP
1.800
L
0.037 TYP
2.000
0.071
0.550 REF
0.079
0.022 REF
L1
0.300
0.500
0.012
0.020
θ
0︒
8︒
0︒
8︒
x
1.460 TYP
0.057 TYP
y
0.650 TYP
0.026 TYP
z
0.500 TYP
0.020 TYP
9
Rev
1.2
MT816X
XXXX
XXXX
YWW
Product ID
YWW
DateCode: week (01~55)
DateCode: year (0~9)
3 OUT
2 GND
1 Vcc
Figure.15
Flat TO-92 Chip Marking Spec
Sensing
Center
Figure.16
Flat TO-92 Package Drawing
Symbol
Min
Max
Min
Max
A
1.420
1.620
0.056
0.064
A1
0.660
0.860
0.026
0.034
b
0.350
0.480
0.013
0.019
b1
0.400
0.510
0.016
0.020
c
0.330
0.510
0.013
0.020
D
3.900
4.100
0.154
0.161
D1
2.280
2.680
0.090
0.106
E
3.050
3.250
0.120
0.128
e
1.270 TYP
0.050 TYP
e1
2.440
2.640
0.096
0.104
L
14.350
14.750
0.565
0.581
θ
45︒ TYP
45︒ TYP
x
2.025 TYP
0.080 TYP
y
1.545 TYP
0.061 TYP
z
0.500 TYP
0.020 TYP
10
Rev
1.2
MT816X
13 Copy Rights and Disclaimer
1. This document may not be reproduced or duplicated, in any form, in whole or in part without prior
written consent of MagnTek . Copyrights © 2019, MagnTek Incorporated.
2. MagnTek reserves the right to make changes to the information published in this document at
anytime without notice.
3. MagnTek’s products are limited for use in normal commercial applications. MagnTek’s products are
not to be used in any device or system, including but not limited to medical life support equipment and
system.
For the latest version of this document, please visit our website: www.magntek.com.cn
11
Rev
1.2
很抱歉,暂时无法提供与“MT8161A”相匹配的价格&库存,您可以联系我们找货
