FL100M400G160A
FL100M400G160A
    CAPXON(台湾丰宾)
    插件,D10xL16mm
    直插铝电解电容 插件,D10xL16mm 10µF ±20% Ф10.00 x 16.00mm 400V 130mA 10000Hrs@105℃
FL100M400G160A 数据手册
  Aluminum Electrolytic Capacitor    FL series  Part number  Capacitance  Voltage  Surge Voltage  Capacitance  Tolerance (@ +20°C) Ripple current (max, @120Hz,+105°C)  Dissipation factor(tanδ @120Hz, +20°C)  Leakage Current (max, @ +20°C)*  Size  Operating temperature  Endurance  L.C.:  After  1 min. with rated working voltage applied.  Test conditions  Duration time  Applied voltage  After test requirements (+20°C):  Capacitance  change  Dissipation factor change  Leakage current  comment  FL100M400G160A 10 400 440 ±20 130 20 260 10x16 ‐40 to 105 10000 µF VDC VDC % mA % µA mm °C h         10µF 400V FL 105°C Endurance  Shelf Life  10000h @ 105°C  1000h @ 105°C  Rated DC working voltage, IR  None      ≤ ±20% of initial measured value  ≤ 200% of the initial specified value  ≤ the initial specified value    Pre‐treatment for measurements shall  be conducted after application of DC  working voltage for 30 min.  PET Sleeve dø±0.02   L±1.5  Series  1_2  Cap  3_4_5  Tol.  6  Voltage  7_8_9  Case D 10  Case L  11_12_13 Type  14  Lead Treatm.  15_16  FL  100  M  400  G  160  A  A          =10µF    …  =±20%      =400V      =10mm      =16mm      A=standard     no request            D 10  L 16  F 5  dø 0.6  Special  17_18_19_20  Specification and description for the component(s) are subject to change without notice. For packaging, handling, precautions and warning information, please visit our website: www.capxongroup.com CapXon        V.ED‐20171027
FL100M400G160A 价格&库存
很抱歉,暂时无法提供与“FL100M400G160A”相匹配的价格&库存,您可以联系我们找货
