PS122M6R3F115P
PS122M6R3F115P
    CAPXON(台湾丰宾)
    插件,D8xL11.5mm
    直插铝电解电容 插件,D8xL11.5mm 1.2mF ±20% Ф8.00 x 11.50mm 6.3V 12mΩ 5.5A 2000Hrs@105℃
PS122M6R3F115P 数据手册
PS series PS series Standard Products Features ◆ Low ESR at high frequency range. ◆ Large permissible ripple current. Specifications Performance Characteristics -55~+105℃ Rated Voltage Range 2.5~25 VDC Capacitance Range Conductive Polymer Item Operating Temperature Range 39 to 3500μF Capacitance Tolerance ±20%(120Hz,+20℃) Leakage Current (+20℃,max.) ≦0.2CV (μA, after 2 minutes) Dissipation Factor (tanδ,at 20℃,120Hz) Not to exceed the value specified ESR(100K~300KHz) Not to exceed the value specified Endurance 105℃,2000h,at rated voltage Moisture Resistance Stored at 60℃,RH90~95%, 1000h Capacitance Change Within ±20% of the value before test Leakage current Not to exceed the value specified ESR Not to exceed 150% of the value specified Dissipation Factor Not to exceed 150% of the value specified Capacitance Change Within ±20% of the value before test Leakage current Not to exceed the value specified ESR Not to exceed 150% of the value specified Dissipation Factor Not to exceed 150% of the value specified Frequency Coefficient for Ripple Current Frequency 120Hz≦freq.
PS122M6R3F115P 价格&库存
很抱歉,暂时无法提供与“PS122M6R3F115P”相匹配的价格&库存,您可以联系我们找货
