DSK22-DSK220
Surface Mount Schottky Rectifier
SOD-123FL
Features
Low profile package
Ideal for automated placement
Ultrafast reverse recovery time
Low power losses, high efficiency
Low forward voltage drop
High surge capability
0.114(2.9)
0.098(2.5)
0.008(0.20)
0.004(0.10)
0.047(1.19)
0.043(1.09)
High temperature soldering:
0.043(1.09)
0.035(0.89)
0.075(1.90)
0.067(1.70)
260℃/10 seconds at terminals
Component in accordance to
0.030(0.76)
0.018(0.45)
RoHS 2002/95/1 and WEEE 2002/96/EC
Mechanical Date
Case: JEDEC SOD-123FL molded plastic
0.154(3.9)
0.138(3.5)
body over passivated chip
Terminals: Solder plated, solderable per
Dimensions in inches and(millimeters)
J-STD-002B and JESD22-B102D
Polarity: Laser band denotes cathode end
Weight: 0.017gram
Maximum Ratings & Thermal Characteristics & Electrical Characteristics
(TA = 25 °C unless otherwise noted)
SYMBOLS DSK22 DSK23 DSK24 DSK25 DSK26 DS K27 DSK 28 DSK29 DSK210 DSK215 DSK220
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Operating junction temperature range
Storage temperature range
30
21
30
40
28
40
50
35
50
60
42
60
70
49
70
80
56
80
90
63
90
100
70
100
150
83
150
200
90
200
I(AV)
2.0
VOLTS
VOLTS
VOLTS
Amp
IFSM
40.0
Amps
VRRM
VRMS
VDC
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 2.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
UNITS
VF
0.70
0.55
0.85
0.5
IR
CJ
TJ
TSTG
0.95
Volts
mA
10.0
5.0
80
pF
-65 to +125
-65 to +150
C
C
220
-65 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V
D.C.
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
DSK22-DSK220
Characteristic Curves (TA=25 ℃ unless otherwise noted)
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SOD-123FL
3000/REEL
90000
40X20X22
5.00
4.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“DSK26”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32446
- 100+0.26380
- 300+0.23348
- 3000+0.17856
- 6000+0.16038
- 9000+0.15125
- 国内价格
- 10+0.29742
- 100+0.24182
- 600+0.21402
- 1200+0.21081
- 3000+0.16368
