504L50R0FTNCFT
504L50R0FTNCFT
    ATC
    贴片电阻 0402 50Ω ±1% 1/8W -150~-50ppm/℃
504L50R0FTNCFT 数据手册
AT C U LT R A - B R O A D B A N D R E S I S T I V E P R O D U C T S ATC 504L Series UBRTM Ultra-Broadband Resistors Features: • Frequency Range: DC to 20 GHz • EIA 0402 Case Size • Power Rating: 125 mW • Operating Temperature: -40°C to +125°C • 100% Laser Trimming for Tight Tolerances Patent Pending • RoHS Compliant ATC // AVX Thin Film Technologies is pleased to introduce the 504L Series next generation of surface mount UltraBroadband Resistors. This product was designed with our proprietary Glass Sandwich Flexiterm® Technology, (GSFT). The Flexiterm® is a surface mountable automotive qualified termination that adds an extra margin against damage due to flexture during installation. The 504L Series has been designed with high quality selected materials that yield excellent performance. This product is ideal for use in Optical Transceiver Modules or any application requiring excellent ultrabroadband performance. Markets: Applications: • Optical Transceiver Modules • Opto-electronics • Broadband Receiver • Automotive • TOSA / ROSA • Telecom • Wideband Test Equipment • Broadband Jamming for EW • Low Noise Amplifier • Satellite Communication • MMIC Amplifiers • Mixers • Directional Couplers • Ultra-Broadband Splitters and Combiners ATC 504L Series Flatness vs. Frequency Specifications Resistor Detail Outline EIA 0402 Package Glass wafer sandwich Standard Resistance Values (Ω) 25Ω, 50Ω, 100Ω, 200Ω Resistance Value Range From 25Ω to 400Ω Termination Flexiterm® (Ag/Epoxy), NiSn plated Power Rating 125 mW Operating Temperature Range -40°C to +125°C Tolerance 1% Magnitude (dB) - Modeled -5.9 -6.01 -6.12 -6.23 -6.34 -6.45 -6.56 -6.67 -6.78 -6.89 -7 1 3.9 6.8 9.7 12.6 15.5 18.4 21.3 24.2 27.1 30 Frequency (GHz) Modeled with HFSS using Rogers 3003 substrate, with a thickness of 10 mils and a line width of 24 mils, representing data for 100 Ohms. ATC # 001-1108 Rev C, 8/13 AT C U LT R A - B R O A D B A N D R E S I S T I V E P R O D U C T S Resistor Material Properties Resistor Material (TaN): Properties Sheet Resistance (Ohms per Square) TCR ppm/°C 30 to 100 -50 to -150 COVER GLASS FLEX TERMINATION (Ag EPOXY) PLATED WITH Ni / Sn Mechanical Dimensions W L T EPOXY t t Size (EIA) 0402 Length (L) Width (W) .039 ±.004 .020 ±.004 (1.00 ±0.10) (0.50 ±0.10) Thickness (T) .020 ±.004 (0.50 ±0.10) GLASS SUBSTRATE Terminal (t) .010 ±.006 (0.25 ±0.15) inches (mm) ATC Part Number Code ATC 504 L 100 0 F T NC F T Series Packaging: T = Tape & Reel Case Size Temperature Coefficient of Resistance (-50 to -150 ppm/°C) Resistance Value (Ω) 3 significant digits R= decimal point Multiplyer Compensation NC = Non-Compensated Tolerance F= 1% Termination T = NiSn Plated The above part number refers to a 504 Series (case size L), 100 Ohms, F tolerance (1%), NiSn Plated Non-Compensated, with a TCR of -50 to -150 ppm/ºC, with Tape and Reel Packaging. ATC accepts orders for our parts using designations with or without the “ATC” prefix. Both methods of defining the part number are equivalent, i.e., part numbers referenced with the “ATC” prefix are interchangeable to parts referenced without the “ATC” prefix. Customers are free to use either in specifying or procuring parts from American Technical Ceramics. For additional information and catalogs contact your ATC representative or call direct at +1-631-622-4700. Consult factory for additional performance data. Sales of ATC products are subject to the terms and conditions contained in American Technical Ceramics Corp. Terms and Conditions of Sale (ATC document #001-992 Rev. A 10/03). Copies of these terms and conditions will be provided upon request. They may also be viewed on ATC's website at www.atceramics.com/productfinder/default.asp. Click on the link for Terms and Conditions of Sale. ATC has made every effort to have this information as accurate as possible. However, no responsibility is assumed by ATC for its use, nor for any infringements of rights of third parties which may result from its use. ATC reserves the right to revise the content or modify its product line without prior notice. © 2012 American Technical Ceramics Corp. All Rights Reserved. ATC # 001-1108, Rev C, 8/13
504L50R0FTNCFT 价格&库存
很抱歉,暂时无法提供与“504L50R0FTNCFT”相匹配的价格&库存,您可以联系我们找货
504L50R0FTNCFT
  • 50+55.01244
  • 500+49.51119
  • 5000+45.84370
  • 10000+44.00995
  • 30000+42.17620
  • 50000+41.07595
