BAS70-04
BAS70-04
    BLUECOLOUR(蓝彩电子)
    SOT-23
    SOT23
BAS70-04 数据手册
BAS70/-04/-05/-06 Surface Mount Schottky Barrier Diode Features • Low turn-on voltage • Fast switching • PN junction guard ring for transient and ESD protection SOT-23 Plastic Package BAS70 BAS70-04 3 1 BAS70-05 3 2 1 Marking Code: 73 BAS70-06 3 2 1 3 2 Marking Code: 75 Marking Code: 74 1 2 Marking Code: 76 Absolute Maximum Ratings (Ta = 25 C) O Value Unit r Parameter Symbol 70 V VRSM 70 V VR 70 V IF(AV) 70 mA Peak Forward Surge Current (t < 10 ms) IFSM 100 mA Power Dissipation PD 200 mW RθJA 500 Tj - 55 to + 125 O Tstg - 65 to + 150 O Repetitive Peak Reverse Voltage ou VRRM Non-Repetitive Peak Reverse Voltage Maximum DC Blocking Voltage ec ol Average Forward Rectified Current Thermal Resistance Junction to Ambient Air Operating Junction Temperature Range bl u Storage Temperature Range C/W O C C Characteristics at Ta = 25 C O Parameter Forward Voltage at IF = 1 mA at IF = 15 mA Reverse Breakdown Voltage at IR = 10 µA Reverse Current at VR = 50 V Total Capacitance at VR = 0 , f = 1 MHz Reverse Recovery Time at IF = IR = 10 mA to IR = 1 mA, RL = 100 Ω Page 1 of 3 Symbol Min. Max. Unit VF - 0.41 1 V V(BR)R 70 - V IR - 100 nA CT - 2 pF trr - 5 ns REV01: 09/2011 Typical Characteristics MRA803 10 2 MRA805 10 2 IR IF (mA) (1) (µA) 10 10 (2) 1 1 10 1 (3) 10 1 10 0 (2) (3) (4) 0.2 0.4 0.6 0.8 10 3 1 0 Tamb = 125 °C. Tamb = 85 °C. Tamb = 25 °C. Tamb = −40 °C. Forward current as a function of forward voltage; typical values. Fig.2 ec MGL762 103 bl u rdif (Ω) 102 60 80 VR (V) (1) Tamb = 150 °C. (2) Tamb = 85 °C. (3) Tamb = 25 °C. ol Fig.1 40 ou VF (V) (1) (2) (3) (4) 20 r (1) 10 2 2 Reverse current as a function of reverse voltage; typical values. MRA804 2 Cd (pF) 1.5 1 10 0.5 1 10−1 0 1 10 IF (mA) f = 10 kHz. Fig.3 Page 2 of 3 0 102 Differential forward resistance as a function of forward current; typical values. 20 40 60 80 VR (V) f = 1 MHz. Fig.4 Diode capacitance as a function of reverse voltage; typical values. REV01: 09/2011 PACKAGE OUTLINE SOT-23 bl u ec ol ou r Plastic surface mounted package; 3 leads Page 3 of 3 REV01: 09/2011
BAS70-04
物料型号:BAS70系列,包括BAS70、BAS70-04、BAS70-05、BAS70-06。
器件简介:这些是低开启电压、快速开关的肖特基二极管,具备PN结保护环以提供瞬态和ESD保护。
引脚分配:文档没有提供具体的引脚分配信息,但通常SOT-23封装有3个引脚。
参数特性:包括重复峰值反向电压(VRRM)、非重复峰值反向电压(VRSM)、最大直流阻断电压(VR)、平均正向整流电流(IF(AV))、峰值正向浪涌电流(IFSM)、功耗(Po)、结到环境空气的热阻(RBJA)、工作结温范围(-55°C至+125°C)、存储温度范围(-65°C至+150°C)。
功能详解:文档提供了在Ta = 25°C时,正向电压(VF)、反向击穿电压(V(BR)R)、反向电流(IR)、总电容(CT)和反向恢复时间(tr)等特性。
应用信息:文档没有直接提供应用信息,但基于其特性,这些二极管可能适用于高频开关电路、电源转换等。
封装信息:SOT-23塑料表面封装,具有3个引脚。
BAS70-04 价格&库存
很抱歉,暂时无法提供与“BAS70-04”相匹配的价格&库存,您可以联系我们找货
