BXA50VC220M10*10_10.0TP
    SAMYOUNG(韩国三莹)
    SMD,D10xL10mm
    贴片铝电解电容 SMD,D10xL10mm 220µF ±20% 50V 2000Hrs@105℃
BXA50VC220M10*10_10.0TP 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS BXA Series Solventproof •105℃ 1,000~2,000Hrs assured. •Vertical SMD type. •Low Impedance. •For STB, Satellite Radio, Computer Server. •RoHS compliant. •Halogen-free capacitors are also available. MVY BXA Low Imp. SPECIFICATIONS Item Rated Voltage Range Operating Temperature Range Capacitance Tolerance Leakage Current Characteristics 6.3 ~ 50 V DC -55 ~ +105℃ ±20%(M) (at 20℃, 120Hz) I=0.01CV(μA) or 3 μA, whichever is greater. Where, I:Max. Leakage current(μA), C:Nominal capacitance(μ F), V:Rated voltage(VDC) (at 20℃, 2 minutes) Rated Voltage(VDC) 6.3 10 16 25 35 50 D56~H63 0.24 0.20 0.16 0.14 0.12 0.12 H10~J10 0.28 0.24 0.20 0.16 0.14 0.12 SIZE Dissipation Factor(Tan δ) Temperature Characteristics (Max. Impedance ratio) Rated voltage(VDC) 6.3 10 16 25 35 50 Z(-25℃)/Z(20℃) Z(-55℃)/Z(20℃) 3 5 2 4 2 4 2 3 2 3 2 3 (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied with the following conditions. Load Life Ø4~Ø6.3 : 105℃, 1,000 hours, Ø8 & Ø10 : 105℃, 2,000 hours. Capacitance change ≦ ±25% of the initial value Tanδ ≦ 200% of the initial specified value Leakage current ≦ The initial specified value Shelf Life Tanδ ≦ 200% of the initial specified value Leakage current ≦ The initial specified value Series Others Capacitance change ≦ ±25% of the initial value Satisfied characteristics KS C IEC 60384-4 PART NUMBERING SYSTEM RATED RIPPLE CURRENT MULTIPLIERS Frequency Multipliers BXA 16 VC 100 M F60 TP With tape Case code Capacitance tolerance(±20%) Nominal capacitance code (ex. 0.1㎌:R1, 1.0㎌:1, 4.7㎌:4R7, 10㎌:10) Lead type Rated voltage Series name Freq.(㎐) Cap.(㎌) 2.2 ~ 4.7 10 ~ 100 220 ~ 470 1,000 ~ 1,500 BXA The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1000 hours at 105℃ without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. 120 1K 10K 100K 0.35 0.40 0.50 0.60 0.70 0.75 0.85 0.87 0.90 0.90 0.94 0.95 1.00 1.00 1.00 1.00 59 SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS DIMENSIONS OF BXA Series Unit(mm) DIMENSIONS MARKING Note 1 : L±0.5 for 8×6.3(H63), 10×10(J10) Note 2 : 4×5.3(D56), 5×5.3(E56) is excluded symbol mark. Note 3 : 6.3WV is marked by 6V. Case code Ø D D56 4 E56 5 F60 6.3 F80 6.3 Recommended solder land on PC board H63 8 H10 8 J10 10 L A 5.3 4.3 5.3 5.3 5.7 6.6 7.7 6.6 6.3 8.3 10 8.3 10 10.3 B 4.3 5.3 6.6 6.6 8.3 8.3 10.3 C 5.1 5.9 7.2 7.2 9.0 9.0 11.0 W 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.7~1.1 0.7~1.1 P 1.0 1.4 1.9 1.9 2.3 3.1 4.5 a 1.0 1.4 1.9 1.9 2.3 3.1 4.5 b 2.6 3.0 3.5 3.5 4.5 4.2 4.4 c 1.6 1.6 1.6 1.6 1.6 2.2 2.2 : Solder land on PC board RATINGS OF BXA Series ㎌ VDC 6.3 10 16 25 35 50 D56 4.80 30 80 E56 3.00 50 80 E56 0.90 150 F60 2.00 70 70 2.2 D56 2.10 4.7 D56 2.10 10 D56 2.10 22 33 D56 2.10 47 E56 68 F60 80 E56 0.90 150 E56 0.90 150 E56 0.90 150 F60 2.00 80 E56 0.90 150 F60 0.44 230 F60 0.44 230 F60 0.44 230 F80 1.00 170 0.90 150 F60 0.44 230 F60 0.44 230 F60 0.44 230 F60 0.44 230 H63 0.90 180 0.44 230 F60 0.44 230 F60 0.44 230 F60 0.44 230 F80 0.34 280 H10 0.44 230 F80 0.34 280 H63 0.32 300 H10 0.17 450 H10 0.44 230 J10 100 F60 0.44 230 F60 0.44 230 F60 0.44 230 220 F60 0.44 230 F80 0.34 280 F80 0.34 280 H10 0.17 450 H10 0.17 450 330 F80 0.34 280 H10 0.17 450 H10 0.17 450 H10 0.17 450 J10 470 H10 0.17 450 H10 0.17 450 H10 0.17 450 J10 670 1,000 H10 0.17 450 J10 670 1,500 J10 670 0.09 0.09 0.09 Rated Ripple Current (mArms/105℃, 100kHz) Impedance (Ωmax./20℃, 100kHz) Case code 60 0.09 670 0.30 350
BXA50VC220M10*10_10.0TP 价格&库存
很抱歉,暂时无法提供与“BXA50VC220M10*10_10.0TP”相匹配的价格&库存,您可以联系我们找货
