PZ200R-12-12P
PZ200R-12-12P
    XFCN(台湾兴飞)
    弯插,P=2mm
    排针 间距:2mm 弯插
PZ200R-12-12P 数据手册
RoHS REV ECN NO. DESRIPTION A1 NEW 更换图框 DESIGN APPROVAL 2024.05.24 B±0.35 PIN/ROW 2x02 2x03 2x04 2x05 2x06 2x07 2x08 2x09 2x10 2x11 2x12 2x13 2x14 2x15 2x16 2x17 2x18 2x19 2x20 2x21 2x22 2x23 2x24 2x25 2x26 2x27 2x28 2x29 2x30 2x31 2x32 2x33 2x34 2x35 2x36 2x37 2x38 2x39 2x40 Material: Insulator Material:PA6T (UL 94V-0) Black Contact Material:Brass Plating:Matte Tin or gold plated over Nickel Mate with XFCN PM200 Double Row series 2.00±0.05 Ordering Code: PZ200R-12-xx 2.00±0.15 4.00±0.25 2.00±0.05 1 2 1.序列号 2.Pin位数: 2x02=04P 3.2±0.25 0.5*0.5 No.of SPECIFICATIONS 1. Current rating: 2A 2. Temperature range: -40°C ~ +105°C 3. Insulation resistance: 1000MΩ Min. 4. Withstanding voltage: 250V AC/ minute. 5. Contact resistance: 20mΩ Max. 4.0±0.15 2.8±0.25 A±0.25 5.80±0.25 2.00±0.05 DATE 2.00±0.05 Ø 0±0 0.9 .05 P.C.B Hole Layout X.±0.50 X.°± .X±0.25 .XX±0.15 .XXX±0.10 UNITS: .X°± .XX°± .XXX°± mm THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF XFCN AND SHALL NOT BE REPRODUCED,COPIED OR CUED IN ANY MANNER WITHOUT THE PRIOR WRITTEN CONSENT OF XFCN PART NO: Dimension A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 XFCN兴飞连接器 PZ200R-12-xx TITLE: 0769-82001899 www.xfconn.com 2.00mm Pin Header Connectors DWG NO: / APPD Chen ZhiQiang CHKD Liu Wei VIEW DRAW Chen HongJiang SCALE SHEET REV DATE 2024.06.18 NONE 1/1 A1
PZ200R-12-12P 价格&库存
很抱歉,暂时无法提供与“PZ200R-12-12P”相匹配的价格&库存,您可以联系我们找货
PZ200R-12-12P
  • 5+0.47956
  • 50+0.37911
  • 150+0.32883
  • 1000+0.29118
  • 2000+0.26102
  • 5000+0.24594
库存:446
