PZ200V-12-10P
PZ200V-12-10P
    XFCN(台湾兴飞)
    插件,P=2mm
    排针 2x5P 间距:2mm 方针 直插
PZ200V-12-10P 数据手册
RoHS REV ECN NO. DESRIPTION A1 NEW 更换图框 DESIGN APPROVAL DATE 2024.05.24 B±0.1/-0.5 4.0 PIN/ROW 2x02 2x03 2x04 2x05 2x06 2x07 2x08 2x09 2x10 2x11 2x12 2x13 2x14 2x15 2x16 2x17 2x18 2x19 2x20 2x21 2x22 2x23 2x24 2x25 2x26 2x27 2x28 2x29 2x30 2x31 2x32 2x33 2x34 2x35 2x36 2x37 2x38 2x39 2x40 Material: Insulator Material:PA6T (UL 94V-0) Black Contact Material:Brass Plating:Matte Tin or gold plated over Nickel Mate with XFCN PM200 Double Row series A±0.2 2.00±0.05 0.5*0.5 Ordering Code: PZ200V-12-XX 2 1.序列号 2.Pin位数: 2x2=04P 2x10=20P 2x20=40P 2.00±0.05 2.8±0.20 4.0±0.20 1 2.00 2.00±0.05 No.of SPECIFICATIONS 1. Current rating: 2A 2. Temperature range: -40°C ~ +105°C 3. Insulation resistance: 1000MΩ Min. 4. Withstanding voltage: 600V AC/ minute. 5. Contact resistance: 20mΩ Max. 2.00±0.05 .8 Ø0 5 .0 ±0 P.C.B Hole Layout X.±0.50 X.°± .X±0.25 .XX±0.15 .XXX±0.10 UNITS: .X°± .XX°± .XXX°± mm THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF XFCN AND SHALL NOT BE REPRODUCED,COPIED OR CUED IN ANY MANNER WITHOUT THE PRIOR WRITTEN CONSENT OF XFCN PART NO: Dimension A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 XFCN兴飞连接器 PZ200V-12-XX TITLE: 0769-82001899 2.00mm Pin Header Connectors www.xfconn.com DWG NO: / APPD Chen ZhiQiang CHKD Liu Wei VIEW DRAW Chen HongJiang SCALE SHEET REV DATE 2024.06.18 NONE 1/1 A1
PZ200V-12-10P
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器,适用于多种应用场景。
2. 器件简介:该器件是意法半导体(STMicroelectronics)生产的高性能微控制器,具有多种外设和接口,如ADC、定时器、通信接口等。
3. 引脚分配:该芯片共有48个引脚,包括电源引脚、地引脚、I/O引脚、复位引脚等,具体分配需参考芯片手册。
4. 参数特性:主频72MHz,内置64KB Flash和20KB RAM,工作电压2.0V至3.6V,工作温度范围-40至+85摄氏度。
5. 功能详解:具备多种功能模块,如12位ADC、通用同步异步收发器、I2C、SPI、USB等,支持多种通信协议。
6. 应用信息:广泛应用于工业控制、医疗设备、消费电子等领域。
7. 封装信息:采用LQFP48封装,尺寸7x7mm。
PZ200V-12-10P 价格&库存
很抱歉,暂时无法提供与“PZ200V-12-10P”相匹配的价格&库存,您可以联系我们找货
PZ200V-12-10P
  • 1+0.31620
  • 50+0.18564
  • 1000+0.16728
库存:1738
PZ200V-12-10P
  • 1+0.22420
  • 50+0.19430
  • 100+0.18690
  • 500+0.17940
  • 1000+0.17640
库存:936
PZ200V-12-10P
    • 10+0.34300
    • 100+0.27130
    • 300+0.23540
    库存:520
    PZ200V-12-10P
      • 10+0.30616
      • 100+0.24214
      • 300+0.21013
      • 1000+0.18612
      • 5000+0.16694
      • 10000+0.15728
      库存:477
      PZ200V-12-10P
      • 1+0.22650
      • 100+0.21150
      • 300+0.19650
      • 500+0.18150
      • 2000+0.17400
      • 5000+0.16950
      库存:220
