BZX84C13
BZX84C13
    YENJI(台湾元基)
    SOT-23
    稳压二极管 Vz=13V Pd=350mW SOT23-3
BZX84C13 数据手册
BZX84 Series Zener Diodes ◇ Planar Die construction ◇ 350mW Power Dissipation ◇ Zener Voltages from 2.4V 51V - ◇ RoHS compliant / Green EMC MAXIMUM RATINGS (Ta = 25 ℃) Symbol VF P(AV) TJ, Tstg Parameter Value Units Maximum Forward Voltage @ IF=10mA 0.9 V Power Dissipation 350 mW -55 to 150 ℃ Operating And StorageTemperature IFSM Peak Forward Surge Surge Current Tstg Storage Temperature Rance Rj 2.0 A -55 to 150 ℃ 357 ℃/W Thermal Resistance Junction to Ambient ELECTRICAL CHARACTERISTICS (Ta = 25 ℃ unless otherwise noted) Max.Reverse Nominal Zener Voltage Part Number Max. Zener Impedance Leakage Marking Current Vz(V) @ IZT ZZT @ IZT ZZK @ IZK IR @ VR Nom. Min. Max. Ohm mA Ohm mA µA V BZX84C2V4 W1/Z11 2.4 2.28 2.52 100 5 600 1 50 1.0 BZX84C2V7 W2/Z12 2.7 2.5 2.9 100 5 600 1 20 1.0 BZX84C3V0 W3/Z13 3 2.8 3.2 95 5 600 1 10 1.0 BZX84C3V3 W4/Z14 3.3 3.1 3.5 95 5 600 1 5 1.0 BZX84C3V6 W5/Z15 3.6 3.4 3.8 90 5 600 1 5 1.0 BZX84C3V9 W6/Z16 3.9 3.7 4.1 90 5 600 1 3 1.0 BZX84C4V3 W7/Z17 4.3 4 4.6 90 5 600 1 3 1.0 1 BZX84 Series Zener Diodes BZX84C4V7 W8/Z1 4.7 4.4 5 80 5 500 1 3 2.0 BZX84C5V1 W9/Z2 5.1 4.8 5.4 60 5 480 1 2 2.0 BZX84C5V6 WA/Z3 5.6 5.2 6 40 5 400 1 1 2.0 BZX84C6V2 WB/Z4 6.2 5.8 6.6 10 5 150 1 3 4.0 BZX84C6V8 WC/Z5 6.8 6.4 7.2 15 5 80 1 2 4.0 BZX84C7V5 WD/Z6 7.5 7 7.9 15 5 80 1 1 5.0 BZX84C8V2 WE/Z7 8.2 7.7 8.7 15 5 80 1 0.7 5.0 BZX84C9V1 WF/Z8 9.1 8.5 9.6 15 5 100 1 0.5 6.0 BZX84C10 WG/Z9 10 9.4 10.6 20 5 150 1 0.2 7.0 BZX84C11 WH/Y1 11 10.4 11.6 20 5 150 1 0.1 8.0 BZX84C12 WI/Y2 12 11.4 12.7 25 5 150 1 0.1 8.0 BZX84C13 WK/Y3 13 12.4 14.1 30 5 170 1 0.1 8.0 BZX84C15 WL/Y4 15 13.8 15.6 30 5 200 1 0.1 10.5 BZX84C16 WM /Y5 16 15.3 17.1 40 5 200 1 0.1 11.2 BZX84C18 WN/Y6 18 16.8 19.1 45 5 225 1 0.1 12.6 BZX84C20 WO/Y7 20 18.8 21.2 55 5 225 1 0.1 14.0 BZX84C22 WP/Y8 22 20.8 23.3 55 5 250 1 0.1 15.4 BZX84C24 WR/Y9 24 22.8 25.6 70 5 250 1 0.1 16.8 BZX84C27 WS/Y10 27 25.1 28.9 80 2 300 1 0.1 18.9 BZX84C30 WT /Y11 30 28 32 80 2 300 1 0.1 21.0 BZX84C33 WU/Y12 33 31 35 80 2 325 1 0.1 23.1 BZX84C36 WW/Y13 36 34 38 90 2 350 1 0.1 25.2 BZX84C39 WX/Y14 39 37 41 130 2 350 1 0.1 27.3 BZX84C43 WY/Y15 43 45.15 150 5 375 1 0.1 30.10 49.35 170 5 375 1 0.1 32.90 0.1 35.70 BZX84C47 WZ/Y16 47 40.85 44.65 BZX84C51 XA/Y17 51 48.45 53.55 100 5 400 1 BZX84C62 Y19 62 58.0 66.0 215 2 450 0.5 2 0.05 43.40 BZX84 Series Zener Diodes ELECTRICAL CHARACTERISTICS (Ta = 25 ℃ unless otherwise noted) Max.Reverse Nominal Zener Voltage Part Number Max. Zener Impedance Leakage Marking Current Vz(V) @ IZT ZZT @ IZT ZZK @ IZK IR @ VR Nom. Min. Max. Ohm mA Ohm mA µA V BZX84B4V3 W7 4.3 4.21 4.39 90 5 600 1 3.0 1.0 BZX84B4V7 W8/Z1 4.7 4.61 4.79 80 5 500 1 3.0 2.0 BZX84B5V1 W9/2Z2 5.1 5.00 5.20 60 5 480 1 2.0 2.0 BZX84B5V6 WA/2Z3 5.6 5.49 5.71 40 5 400 1 1.0 2.0 BZX84B6V2 WB/2Z4 6.2 6.08 6.32 10 5 150 1 3.0 4.0 BZX84B6V8 WC/2Z5 6.8 6.66 6.94 15 5 80 1 2.0 4.0 BZX84B7V5 WD/2Z6 7.5 7.35 7.65 15 5 80 1 1.0 5.0 BZX84B8V2 WE/2Z7 8.2 8.04 8.36 15 5 80 1 0.7 5.0 BZX84B9V1 WF/2Z8 9.1 8.92 9.28 15 5 100 1 0.5 6.0 BZX84B10 WG/2Z9 10 9.80 10.20 20 5 150 1 0.2 7.0 BZX84B11 WH/2Y1 11 10.78 11.22 20 5 150 1 0.1 8.0 BZX84B12 WI/2Y2 12 11.76 12.24 25 5 150 1 0.1 8.0 BZX84B13 WK/2Y3 13 12.74 13.26 30 5 170 1 0.1 8.0 BZX84B15 WL/2Y4 15 14.70 15.30 30 5 200 1 0.1 10.5 BZX84B16 WM /2Y5 16 15.68 16.32 40 5 200 1 0.1 11.2 BZX84B18 WN/2Y6 18 17.64 18.36 45 5 225 1 0.1 12.6 BZX84B20 WO/2Y7 20 19.60 20.40 55 5 225 1 0.1 14.0 BZX84B22 WP/Y8 22 21.56 22.44 55 5 250 1 0.1 15.4 BZX84B24 WR/Y9 24 23.52 24.48 70 5 250 1 0.1 16.8 BZX84B27 WS/Y10 27 26.46 27.54 80 5 300 1 0.1 18.9 BZX84B30 WT /Y11 30 29.40 30.60 80 5 300 1 0.1 21.0 BZX84B33 WU/Y12 33 32.34 33.66 80 5 325 1 0.1 23.1 BZX84B36 WW/Y13 36 35.28 36.72 90 5 350 1 0.1 25.2 BZX84B39 WX/Y14 39 38.22 39.78 130 5 350 1 0.1 27.3 BZX84B43 WY 43 42.14 43.86 150 5 375 1 0.1 30.1 3 BZX84 Series Zener Diodes BZX84B47 WZ 47 46.06 47.94 170 5 375 1 0.1 32.9 BZX84B51 XA 51 49.98 52.02 100 5 750 1 0.1 38.0 ORDERING INFORMATION Package Device BZX84C2V4BZX84B51 SOT23 Shipping Tape & Reel 3000pcs /7” Reel PACKAGE DIMENSIONS 4 Tape wide Emboss pitch Tape specification 8mm 4mm Conductive Notes
BZX84C13 价格&库存
很抱歉,暂时无法提供与“BZX84C13”相匹配的价格&库存,您可以联系我们找货
