ESD5451N-2/TR
ESD5451N-2/TR
    WILLSEMI(韦尔)
    DFN1006-2
    ESD抑制器/TVS二极管 双向 5V 8A 80W DFN1006-2L
ESD5451N-2/TR 数据手册
ESD5451N ESD5451N 1-Line, Bi-directional, Transient Voltage Suppressors http//:www.sh-willsemi.com Descriptions The ESD5451N is a bi-directional TVS (Transient Voltage Suppressor). It is specifically designed to protect sensitive electronic components which are connected to low speed data lines and control lines from over-stress caused by ESD (Electrostatic Discharge), EFT (Electrical Fast Transients) and Lightning. DFN1006-2L (Bottom View) The ESD5451N may be used to provide ESD protection up to ±30kV (contact and air discharge) according to IEC61000-4-2, and withstand peak pulse current up to 8A (8/20μs) according to IEC61000-4-5. Pin1 Pin2 The ESD5451N is available in DFN1006-2L package. Standard products are Pb-free and Halogen-free. Circuit diagram Features  Reverse stand-off voltage: ±5V Max  Transient protection for each line according to 2 Pin1 IEC61000-4-2 (ESD): ±30kV (contact and air discharge) IEC61000-4-4 (EFT): 40A (5/50ns) IEC61000-4-5 (surge): 8A (8/20μs) 2 = Device code  Capacitance: CJ = 17.5pF typ.  Low leakage current: IR < 1nA typ.  Low clamping voltage: VCL = 9V typ. @ IPP = 16A (TLP)  Solid-state silicon technology * = Month code ( A~Z) Marking (Top View) Order information Applications  Cellular handsets  Tablets  Laptops  Other portable devices  Network communication devices Will Semiconductor Ltd. * Pin2 Device Package Shipping ESD5451N-2/TR DFN1006-2L 10000/Tape&Reel 1 Revision 1.5, 2017/09/18 ESD5451N Absolute maximum ratings Parameter Symbol Rating Unit Peak pulse power (tp = 8/20μs) Ppk 80 W Peak pulse current (tp = 8/20μs) IPP 8 A ESD according to IEC61000-4-2 air discharge VESD ESD according to IEC61000-4-2 contact discharge Operation junction temperature Storage temperature kV ±30 125 o TL 260 o TSTG -55~150 o TJ Lead temperature ±30 C C C Electrical characteristics (TA=25 oC, unless otherwise noted) I VRWM Reverse stand-off voltage IR Reverse leakage current VCL Clamping voltage IPP Peak pulse current IPP IHOLD VCL VTRIG VHOLD VBR VRWM IBR ITRIG IR IR ITRIG IBR VRWM VBR VHOLD VTRIG VCL V IHOLD VTRIG Reverse trigger voltage ITRIG Reverse trigger current VBR Reverse breakdown voltage IBR Reverse breakdown current VHOLD Reverse holding voltage IPP IHOLD Reverse holding current Definitions of electrical characteristics Will Semiconductor Ltd. 2 Revision 1.5, 2017/09/18 ESD5451N o Electrical characteristics (TA=25 C, unless otherwise noted) Parameter Symbol Condition Min. Typ. Max. Unit ±5 V 100 nA Reverse stand-off voltage VRWM Reverse leakage current IR VRWM = 5V VBR IBR = 1mA 5.1 V IHOLD = 50mA 5.1 V Reverse breakdown voltage Reverse holding voltage VHOLD
ESD5451N-2/TR
物料型号:ESD5451N
器件简介:ESD5451N是一款双向瞬态电压抑制器(TVS),专为保护低速数据线和控制线连接的敏感电子元件设计,以防止由静电放电(ESD)、电快速瞬变(EFT)和雷击引起的过应力。
引脚分配:该器件为DFN1006-2L封装,具有两个引脚,引脚1和引脚2。
参数特性: - 反向工作电压:±5V - 每个线路的瞬态保护符合IEC61000-4-2(ESD):±30kV(接触和空气放电),IEC61000-4-4(EFT):40A(5/50ns),IEC61000-4-5(浪涌):8A(8/20μs) - 电容:CJ = 17.5pF(典型值) - 漏电流:IR < 1nA(典型值) - 钳位电压:VCL = 9V(典型值)@ IPP = 16A(TLP)
功能详解:ESD5451N能够提供高达±30kV的ESD保护,并能承受高达8A的峰值脉冲电流。它使用固态硅技术,具有低漏电流和低钳位电压。
应用信息:适用于手机、平板电脑、笔记本电脑、其他便携设备和网络通信设备。
封装信息:DFN1006-2L封装,标准产品无铅和无卤素。
ESD5451N-2/TR 价格&库存
很抱歉,暂时无法提供与“ESD5451N-2/TR”相匹配的价格&库存,您可以联系我们找货
ESD5451N-2/TR
    • 1+0.04360
    • 100+0.04240
    库存:7991
    ESD5451N-2/TR
    • 20+0.18690
    • 100+0.11260
    • 1000+0.07650
    • 10000+0.05460
    • 20000+0.05190
    • 100000+0.04810
    库存:999999
    ESD5451N-2/TR
    • 1+0.05100
    • 10000+0.04180
    库存:3309724
    ESD5451N-2/TR
    • 50+0.08801
    • 2000+0.06138
    • 4000+0.06046
    • 10000+0.05564
    库存:29834
