B3D090L-C
Order Code:
B3D090L-C
Version: A0 2013-09-17
Gas Discharge Tube
Exterior
Features
Surface Mounting Design 7.6×5.0×5.8mm
High Current Handling Capability 5,000A @ 8/20μs
Low Capacitance and Insertion Loss
Quick Response and Long Service Life
Moisture sensitivity level:Level 1
SMD
Application information
Package (Top View)
RS485/232/422
1
Agency Approvals
3
2
Schematic Symbol
Icon
Description
Compliance with 2011/65/EU
1
3
Compliance with IEC61249-2-21:2003
Mean lead free
2
UL Certificated E232249
Electrical Parameter
DC Breakdown Voltage 1)2)
Impulse Spark-over Voltage
100V/s
68-112
V
At 1kV/μs
for 99 % of measured values 700
At 1kV/μs
Typical values of distribution
600
V
V
Impulse Discharge Current 3)
8/20μs
5,000
A
Arc Voltage
At 1A
~8
V
Insulation Resistance
DC=50V
≥1
GΩ
Capacitance at 1MHz
VDC=0.5V
≤1.5
pF
Weight
~1.1
g
Operating And Storage Temperature
-40-90
Marking
Bencent Logo YY MM B3D090L-C(YY:year
of production,MM:month of production)
1) At delivery AQL 0.65 level II GB/T 2828.1-2003
2) In ionized mode
3) Terms and waveforms in accordance with ITU-T Rec. K. 12; IEC 61643-21
1/3
www.bencent.com.cn
Specifications are subject to change without notice.
Customers should verify actual device performance in their specific applications
B3D090L-C
Order Code:
B3D090L-C
Gas Discharge Tube
Part Numbering System
Product Characteristics
B3D
090
L
-C
(1)
(2)
( 3)
(4)
(1) Bencent 3-Electrode SMD Gas Discharge Tube
7.6×5.0×5.8mm
Lead Material
Copper
Body Material
Ceramics
Terminal Finish
100% Matte-Tin Plated
(2) DC Breakdown Voltage, e.g., 090=90V
(3) Surge Rating @8/20μs, L=5,000A ( Total Impulse
Discharge Current 5,000A @ 8/20μs)
(4)
“ -C ” Means it is Suitable for High-Speed SMT
Environmental Reliability Characteristics
Testing items
Technical standards
Temperature: 85℃
Time:2H
Temperature: -40℃
Time:2H
Frequency:10-500Hz
Amplitude:0.15mm
Time:45min
Temperature: 260±5℃
Time of dip soldering:10s,1time
High Temperature Storage Test
Low Temperature Storage Test
Vibration
Resistance of soldering heat
Note: Up-screen program can be specified by customer’s request via contacting Bencent service
Solderability test
Solderability
Solder Pot Temperature:
245℃±5℃
Solder Dwell Time:
4-6 seconds
Product Dimensions
A
B
C
D
E
F
Recommended Soldering Pad
A
B
C
D
2/3
www.bencent.com.cn
G
REF
mm
inch
A
7.6±0.3
0.299±0.012
B
0.5±0.2
0.020±0.008
C
1.6±0.2
0.063±0.008
D
0.5±0.2
0.020±0.008
E
5.0±0.2
0.197±0.008
F
5.0±0.2
0.197±0.008
G
5.8±0.3
0.228±0.012
REF
mm
inch
A
9.6
0.378
B
1.5
0.059
C
1.5
0.059
D
5.0
0.197
B3D090L-C
Order Code:
B3D090L-C
Gas Discharge Tube
Reflow Profile
Reflow Condition
Heat
Temperature Min
150°C
Temperature Max
200°C
Time (min to max)
60 – 180 secs
Average ramp up rate(Liquids)Tamp
(TL) to peal
TS(max) to TL - Ramp-up Rate
3°C/second max
- Temperature (TL)
- Temperature (TL)
Peak Temperature (TP)
217°C
60 – 150 seconds
tS
25
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (TP)
8 minutes Max.
Do not exceed
260°C
3/3
Reel
Ramp-down
Preheat
TS(min)
~10 seconds
Temperature (tp)
Package
TL
TS(max)
260+0/-5 °C
Time within 5°C of actual peak
Critical Zone
TL to TP
Ramp-up
TL
3°C/second max
(Liquids)
Reflow
tP
TP
Temperature
Pre
Pb-Free assembly
Time
time to peak temper ature
Information
REF
mm
inch
A
5.4±0.1
0.216±0.004
B
8.4±0.1
0.331±0.004
d
Φ1.5±0.1
Φ0.059±0.004
P0
4.0±0.1
0.157±0.004
P1
2.0±0.1
0.079±0.004
P
8.0±0.1
0.315±0.004
E
1.75±0.1
0.069±0.004
F
7.5±0.1
0.295±0.004
W
16.0±0.3
0.630± 0.012
D
Φ330.0
Φ13.0
D1
Φ50Min
Φ1.97Min
D2
Φ13±0.15
0.512±0.006
W1
16.8±2.0
0.661±0.079
Outline
Reel
(PCS)
Per Carton
(PCS)
Reel Diameter (mm)
TAPING
1,000
16,000
330
www.bencent.com.cn
Carton Size(mm)
L
W
H
360
360
380
很抱歉,暂时无法提供与“B3D090L-C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.45490
- 10+4.19760
- 200+2.97990
- 400+2.68290
- 1000+2.50470
- 国内价格
- 1+2.37600
- 50+1.82600
- 1000+1.69400
- 国内价格
- 1+5.95080
- 10+4.57920
- 30+3.98520
- 100+3.25080
- 500+2.92680
- 1000+2.73240
