BCIHP0420TB-2R2M
BCIHP0420TB-2R2M
    BC(台湾诚阳)
    SMD,4.45x4.1mm
    功率电感 IND_4.45X4.1MM_SM
BCIHP0420TB-2R2M 数据手册
(SMD Power Inductors) Powder Molding Type BCIHP0412/18/20/30 Series ● Photograph picture ● Dimensions MARKING ITEM BCIHP0412-Series BCIHP0418-Series BCIHP0420-Series BCIHP0420TB-Series BCIHP0430-Series Recommend PC Board Pattern A(mm) 4.10±0.25 4.10±0.25 4.10±0.25 4.10±0.25 4.10±0.25 B(mm) 4.45±0.25 4.45±0.25 4.45±0.25 4.45±0.25 4.45±0.25 C(mm) 1.2MAX 1.8MAX 2.0MAX 2.0MAX 3.0MAX D(mm) 1.60±0.3 1.60±0.3 1.60±0.3 1.60±0.3 1.60±0.3 E(mm) F(mm) G(mm) H(mm) 0.76±0.3 4.95 1.95 1.60 0.76±0.3 4.95 1.95 1.60 0.76±0.3 4.95 1.95 1.60 0.76±0.3 4.95 1.95 1.60 0.76±0.3 4.95 1.95 1.60 ● Part Numbering BCIHP 0410 – 4R7 M A B C D A:Series(系列代號) B:Dimension(尺寸) B×C C:Inductance(電感值) 4R7=4.7uH D:Inductance Tolerance(電感值公差) M=±20% ● Features 1. Compliance with RoHs. 2. Lowest DCR. 3. Frequency range up to 3.0MHz. Height 1.0~1.5mm frequency of 1.0 MHz 4. Handles high transient current spikes without saturation 5. Ultra low buzz noise, due to composite construction. ● Applications 1. 2. 3. 4. Notebook/Desktop/Server applications. Low profile, high current power supplies. Battery powered devices. DC/DC converter for Field Programmable Gate Array (FPGA). TEL:+86-512-57823500 TAX:+86-512-57823503 ● 特點 1. 符合 RoHs. 2. 低電阻. 3. 頻率可達到 3.0 MHz.. 高度 1.0~1.5mm 頻率為 1.0 MHz 4. 可處理在未飽和時的高瞬間電流. 5. 設計緊湊/超低噪音 ● 應用 1. 筆記本型電腦/伺服器等設. 2. 備形體小,可耐高電流. 3. 電源,電池設備. 4. 用於 FPGA 領域中的 DC/DC 轉換設備 Cheng YangElectronics Corp Ltd www.baocheng.biz 17 March 2015 TAPE BCIHP04-Series P: 1 / 9 (SMD Power Inductors) Powder Molding Type BCIHP0412/18/20/30 Series ● Specification ITEM BCIHP0412-R047NIHLP-1616AB-01/11 BCIHP0412-R10N IHLP-1616AB-01/11 BCIHP0412-R15N IHLP-1616AB-01/11 BCIHP0412-R20N IHLP-1616AB-01/11 BCIHP0412-R22N IHLP-1616AB-01 BCIHP0412-R47M IHLP-1616AB-01 BCIHP0412-R68M IHLP-1616AB-01 BCIHP0412HC-1R0M IHLP-1616AB-01 BCIHP0412HC-1R2M IHLP-1616AB-01 BCIHP0412HC-1R5M[14] BCIHP0412HC-2R2M BCIHP0412-3R3M BCIHP0412-4R7M BCIHP0412-6R8M BCIHP0412-100M BCIHP0418-R20M BCIHP0418-R47M BCIHP0418-R80N BCIHP0418-1R0M BCIHP0420-R10N [IHLP-1616BZ-01] BCIHP0420-R20N [IHLP-1616BZ-01] BCIHP0420-R22N[15] [IHLP-1616BZ-01] BCIHP0420-R47M [IHLP-1616BZ-01] BCIHP0420-R56M BCIHP0420-R68M BCIHP0420-1R0M IHLP-1616BZ-01 BCIHP0420-1R2M BCIHP0420HC-1R5M BCIHP0420HC-2R2M IHLP-1616BZ-01 BCIHP0420-3R3M BCIHP0420-4R7M BCIHP0420-6R8M BCIHP0420-8R2M BCIHP0420-100M BCIHP0420-220M[17] TEL:+86-512-57823500 TAX:+86-512-57823503 HEAT RATING SATU RATION INDUCTANCE uH DCR mΩ DCR mΩ CURRENT DC AMPS CURRENT DC AMPS @200KHZ,0.25V,0A(1 25℃ MAX. 25℃ Typ. (5) (6) ) TYPICAL(Irms) TYPICAL(Isat) 0.047 3.75 3.10 13.00[1] 32.00 0.10 10.2 7.5 8.00 25.00 0.15 13.2 9.4 7.00 23.00 0.20 13.2 9.4 7.00 23.00 0.22 12.00 9.9 8.50 15.00 0.47 22.00[5] 19.50 6.00 7.00 0.68 39.00 33.5 5.00 9.00 1.00 47.00 41.5 4.20 4.50 1.20 55.00 50.00 3.75 3.75 1.50 75.00 66.00 3.25 3.25 2.20 100.00 2.75 3.00 91.5 3.30 185.00 155.00 2.00 2.30 4.70 246.00 225.00 1.80 2.00 6.80 360.00 325.00 1.50 1.70 10.00 550.00 515.00 1.20[9] 1.50[9] 0.20 11.00 7.80 8..00 9.00 0.47 18.50 16.50 6.00 8.00 0.80 33.00 25.50 5.00 6.00 1.00 42.00 32.00 4.50 5.50 0.10 5.00 4.40 11.0[12] 28.00 [11] 0.20 7.80 11.0 8.00[12] 9.00[ 11] 0.22 7.30 6.60 9.00 12.50 0.47 18.00 15.00 7.00[1 8.00[1 2] 2] 0.56 21.30 17.80 6.50 7.80 0.68 26.00 21.50 6.00 7.50 1.00 42.00[12] 31.50[1 4.50[1 7.00[ 2] 2] 12] 1.20 46.00 40.00 3.50 7.50 1.50 63.00 53.50 3.30 4.00 2.20 58.00 47.00 5.00[ 3.00 12] 3.30 106.00 90.00 2.50 3.00 4.70 132.00 120.00 2.40 3.00 6.80 202.00 185.00 2.00 2.50 8.20 255.00 232.00 1.60 1.80 10.00 282.00 252.00 1.60 1.80[16] 22.00 640.00 590.00 1.20 1.40 Cheng YangElectronics Corp Ltd www.baocheng.biz 17 March 2015 TAPE BCIHP04-Series P: 2 / 9 (SMD Power Inductors) Powder Molding Type BCIHP0412/18/20/30 Series ● Specification ITEM BCIHP0420TB-R22N[IHLP-1616BZ-11] BCIHP0420TB-R33M BCIHP0420TB-R47M[IHLP-1616BZ-11] BCIHP0420TB-R68M BCIHP0420TB-1R0M[IHLP-1616BZ-11] BCIHP0420TB-1R2M PCMB042T-1R2MS BCIHP0420TB-1R5M PCMB042T-1R5MS BCIHP0420TB-2R2M PCMB042T-2R2MS BCIHP0420TB-3R3M [IHLP-1616BZ-11] BCIHP0420TB-4R7M[17][IHLP-1616BZ-11] BCIHP0420TB-5R6M[17] BCIHP0420TB-6R8M[17] BCIHP0430-R47M BCIHP0430-R56M BCIHP0430-1R0M BCIHP0430-1R5M BCIHP0430-2R2M Note: (1) (2) (3) (4) (5) (6) (7) (8) (1) (2) (3) (4) (5) (6) (7) (8) HEAT RATING SATU RATION INDUCTANCE uH DCR mΩ DCR mΩ CURRENT DC AMPS CURRENT DC AMPS @200KHZ,0.25V,0A(1 25℃ MAX. 25℃ Typ. (5) (6) ) TYPICAL(Irms) TYPICAL(Isat) 0.22 6.60 6.00 9.00 12.50 0.33 13.00 10.50 10.0 12.00 0.47 14.00 12.50 0 7.00 9.50 0.68 26.00 19.50 6.00 7.50 1.00 27.00 23.50 4.50 7.00 1.20 29.00 25.00 4.50 7.00 1.50 46.00 41.50 4.00 6.00 2.20 58.00 52.50 3.00[13] 5.00 3.30 87.00 80.00 2.50 4.00 4.70 110.00 92.50 2.00 3.50 5.60 125.00 107.50 2.20 3.00 6.80 172.00 150.00 2.10 2.80 0.47 16.00 15.00 7.50 8.50 0.56 19.30 16.50 7.00 8.00 1.00 43.50 38.80 3.50 5.00 1.50 63.80 49.00 4.00 4.50 2.20 65.00 55.00 4.00 4.00 Tolerance of Inductance: N=±30% ,M=±20%. All test data is referenced to 25℃ ambient. Inductance is measured at 200KHz. 25℃ ambient. Operating Temperature Range-40℃ to +125℃. DC current (Irms) (A) that will cause an approximate △T of 40℃. DC current (Isat) (A) that will cause Lo to drop approximately 20%. BCIHP0410/BCIHP0420TB-Seraes DC current (Isat) (A) that will cause Lo to drop approximately 30%. The part Temperature (ambient + temp rise) should not exceed 125℃ under worst case operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature Part temperature should be verified in the end application. 電感的公差:N=±30%,M=±20%. 所有的測試資料應該是在 25℃的環境溫度下測試. 感值測試頻率 200KHz. 操作溫度範圍-40℃到+125℃. 加 DC(Irms)電流值(A)會導致△T 40℃左右的變化. 加 DC(Isat)電流值(A)會導致初始值下降 20%左右. BCIHP0410/BCIHP0420TB-Seraes 加 DC(Isat)電流值(A)會導致初始值下降 30%左右. 產品的溫度不能超過 125℃,即使在最壞的操作情況下,基板設計,元件放置,PWB 尺寸和厚度,氣流 和一些冷卻設備都會影響產品溫度,產品溫度要在最終應用時才被驗證. TEL:+86-512-57823500 TAX:+86-512-57823503 Cheng YangElectronics Corp Ltd www.baocheng.biz 17 March 2015 TAPE BCIHP04-Series P: 3 / 9 (SMD Power Inductors) Powder Molding Type BCIHP0412/18/20/30 Series ● Material List NO 1 2 ITEM Core Wire External Electode 3 Electroplating 4 Paint Materials Magnetic Metal Powder or equivalen Polyester Wire or equivalen Copper Ni/Sn Epoxy resin ● Packaging Information (1) Reel Dimension & Tape Dimension / Packaging Quantity. ITEN DIMENSIONS (m/m) Q’TY (PCS) W1±0.3 W2±0.5 W±0.3 P±0.1 F±0.1 T±0.05 BCIHP0412 4,000 12.80 17.00 12.00 A0±0.1 B0±0.1 K0±0.1 4.30 4.60 1.50 8.00 5.50 0.30 BCIHP0418 3,000 12.80 17.00 12.00 4.30 4.60 2.20 8.00 5.50 0.30 BCIHP0420 3,000 12.80 17.00 12.00 4.30 4.60 2.20 8.00 5.50 0.30 BCIHP0420TB 3,000 12.80 17.00 12.00 4.30 4.60 2.20 8.00 5.50 0.30 BCIHP0430 2,000 12.80 17.00 12.00 4.30 4.60 3.20 8.00 5.50 0.30 (2) Tearing Off Force The force tearing off cover 10 to 130 grams (0.1N to 1.3N) in the arrow direction under the following conditions. ● Storage conditions/Note things (1) Storage temperature and humidity conditions : 1. Product packing with Carrier tape: +5℃~+40℃ and less than 60% RH. 2. Product alone: -20℃~+60℃ and less than 60% RH. (2) Products should be used within 6 months. (3) The packaging material should be kept where no chlorine or sulfur exists in the air. (4) Do not touch the electrodes (soldering terminals) with fingers as this may lead to deterioration of solder ability. (5) The use of tweezers or vacuum pick-ups is strongly recommended for individual components. (6) Bulk handling should ensure that abrasion and mechanical shock are minimized. TEL:+86-512-57823500 TAX:+86-512-57823503 Cheng YangElectronics Corp Ltd www.baocheng.biz 17 March 2015 TAPE BCIHP04-Series P: 4 / 9 (SMD Power Inductors) Powder Molding Type BCIHP0412/18/20/30 Series ● Inside and Outside package for standard ITEM Packing method & Dimensions Box Size W=345mm D=345mm H=185mm ITEM BCIHP0412 Packing Quantity 4,000 Pcs/Reel (0.76Kg(Ref)) Reel Quantity 8 Reel/Box Total Quantity 32,000 Pcs/Box (6.80Kg(Ref)) BCIHP0418 3,000 Pcs/Reel (0.80Kg(Ref)) 8 Reel/Box 24,000 Pcs/Box (7.20Kg(Ref)) BCIHP0420 3,000 Pcs/Reel (0.80Kg(Ref)) 8 Reel/Box 24,000 Pcs/Box (7.20Kg(Ref)) BCIHP0420TB 3,000 Pcs/Reel (0.80Kg(Ref)) 8 Reel/Box 24,000 Pcs/Box (7.20Kg(Ref)) BCIHP0430 2,000 Pcs/Reel (0.85Kg(Ref)) 8 Reel/Box 16,000 Pcs/Box (7.60Kg(Ref)) TEL:+86-512-57823500 TAX:+86-512-57823503 Cheng YangElectronics Corp Ltd www.baocheng.biz 17 March 2015 TAPE BCIHP04-Series P: 5 / 9 (SMD Power Inductors) Powder Molding Type BCIHP0412/18/20/30 Series ● General Characteristics Operation Temperature External Appearance -40℃ to +125℃ (Includes temperature when the coil is heated) On visual inspection, the coil has no external defects. ● Electrical Performance Test Inductance DCR Refer to standard electrical characteristics list. Saturation Current(Isat) Heat Rated Current(Irms) BCIHP0412/18/20/30-Series △L≦20% typical. BCIHP0410/0420TB-Series △L≦30% typical. Approximately △T≦40℃. ● Reliability Test Solder Ability Test 1. More than 90% of terminal electrode should be covered with solder.  After fluxing, component shall be dipped in a melted.  Solder: bath at 245℃±5℃ for 5±0.5 seconds. 1. 2. Heat resistance of  Reflow Soldering Test    1. Adhesion strength Test Components should have not evidence of electrical and mechanical damage. Inductance: within±10% of initial value. Preheat:150±5℃ 60seconds. Solder temperature: 255+5℃/-0℃. Flux: rosin. Dip time:10±0.5seconds. No apparent damage  Product is mounted on PCB. Thereafter R340 pressure fixture is used to apply pressure to product from backside of the board at a rate of approx. 1mm/sec. until bending width becomes 1mm and keep it for 5sec. 1. No separation or indication of electrode. Welding strength Test  A static load using a R5.0 pressing tool shall be applied to the body of the specimen in the direction of the arrow and shall be hold for 3±1 sec. Insulating Resistance Over 100MΩ at 100V D.C. between coil and core. Dielectric Strength Vibration Test Drop Test TEL:+86-512-57823500 TAX:+86-512-57823503 No dielectric breakdown at 30V D.C. for 1 minute between coil and core. 1. No separation or Inductance deviation within +10% after vibration for 1 hour. In each of three orientations at Sweep vibration indication of (10~55~10HZ) with 1.5mmP-P amplitudes. electrode. Inductance deviation within +10% after being dropped 2. △L/L≦15% once with 981m/s2 (100G) shock Attitude upon a rubber block method shock testing machine, in three different orientations. Cheng YangElectronics Corp Ltd www.baocheng.biz 17 March 2015 TAPE BCIHP04-Series P: 6 / 9 (SMD Power Inductors) Powder Molding Type BCIHP0412/18/20/30 Series ● Reliability Test Item High Temperature Storage Test Low Temperature Storage Test High Temperature Humidity Test Thermal Shock Test Storage Test Required Characteristics 1. No case deformation or change in appearance 2. △L/L≦15% 3. △Q/Q≦30% 4. △DCR/DCR≦15% Test Method/Condition  Temperature:125℃±3℃ Time:96±2 hours.  Tested not less than 1 hour, nor more than 2 hours at room. 1. No case deformation or change in appearance 2. △L/L≦15% 3. △Q/Q≦30% 4. △DCR/DCR≦15%  Temperature:-40℃±3℃ Time:96±2 hours.  Tested not less than 1 hour, nor more than 2 hours at room. 1. No case deformation or change in appearance 2. △L/L≦15% 3. △Q/Q≦30% 4. △DCR/DCR≦15%     Temperature:85℃±3℃. Humidity:85±5%RH Test Time:96±2 hours Tested not less than 1 hour. Nor more than 2 hours at room temperature. 1. 2. 3. 4. No case deformation or change in appearance △L/L≦15% △Q/Q≦30% DCR/DCR≦15%  First–40℃ for 30 Minutes, last 125℃ for 30 Minutes as 1 cycle. Go through 20 cycles. TEL:+86-512-57823500 TAX:+86-512-57823503 Cheng YangElectronics Corp Ltd www.baocheng.biz 17 March 2015 TAPE BCIHP04-Series P: 7 / 9 (SMD Power Inductors) Powder Molding Type BCIHP0412/18/20/30 Series ● Soldering re-flow IPC/JEDEC J-STD-020C, Figure 5-1 TEL:+86-512-57823500 TAX:+86-512-57823503 Cheng YangElectronics Corp Ltd www.baocheng.biz 17 March 2015 TAPE BCIHP04-Series P: 8 / 9 (SMD Power Inductors) Powder Molding Type BCIHP0412/18/20/30 Series ● Modify records Numbering Date [1] [ 2] [3] [4] [5] [6] [7] [8] [9] [10] [11] [12] [12] [12] [12] [13] [14] [15] [16] [17] 2015/4/29 2015/4/29 2015/4/29 2015/4/29 2015/4/29 2015/4/29 2015/4/29 2015/5/9 2015/5/9 2015/5/9 2015/8/21 2015/8/21 2015/8/21 2015/8/21 2015/8/21 2015/10/28 2015/11/16 2015/11/16 2015/11/16 2015/11/16 2018/6/8 [18] TEL:+86-512-57823500 TAX:+86-512-57823503 Modify content BCIHP0412-47NN Irms:12A>13A. BCIHP0412-R10N DCR:10.2mΩ>6.0mΩ. Irms:10A>11.5A. Isat:15A>25A. BCIHP0412-R20N Isat:10A>20A. BCIHP0412-R22N Isat:12A>20A. BCIHP0412-R47N DCR:26mΩ>22mΩ. Irms:6A>5A. Isat:7A>13A. BCIHP0412-R68N DCR:39mΩ>31.4mΩ. Irms:3.3A>4.9A. Isat:9A>9.3A. BCIHP0412-1R0N DCR:55.5mΩ>52.5mΩ. Irms:4.5A>4A. BCIHP0410-100M DCR:550mΩ>800mΩ. BCIHP0412-100M Irms:0.90A>1.20A. Isat:1.00A>1.50A. BCIHP0412-R68N Isat:7.0A>9.3A. BCIHP0420-R10N Isat:22A>35A. BCIHP0420-R10N Irms:12A>11A. BCIHP0420-R47M Irms:7A>5.6A. Isat:8A>11.50A. BCIHP0420-1R0N DCR:42mΩ>37mΩ. Irms:4A>3.75A. Isat:5.7A>8.5A. BCIHP0420-2R2M Isat:3A>6A. BCIHP0420TB-2R2M Irms:3.0A>3.25A Added BCIHP0412-1R5M. Added BCIHP0420-R22M. BCIHP0420-R20M BCIHP0420-100M Isat:1.8A>2.3A. Added BCIHP0420-220M’BCIHP0420TB-4R7M’BCIHP0420TB-5R6M’BCIHP0420TB-6R8M 删除未量产过机种,已量产机种实际参数为准! Cheng YangElectronics Corp Ltd www.baocheng.biz 17 March 2015 TAPE BCIHP04-Series P: 9 / 9
