KH-8010080-A3T
KH-8010080-A3T
    KINGHELM(金航标)
    ANT_8X1.05MM_SM
    RF天线 8x1.05mm
KH-8010080-A3T 数据手册
深圳市金航标电子有限公司 CERAMIC ANTENNA RoHS Compliance Halogens Free Product 2.4 GHz ISM Band Working Frequency P/N: KH8010080-A3T WWW.BDS666.COM 0755-83044319 FEATURES 3 1. Surface Mounted Devices with a small dimension of 8.0 x 1.0 x 0.8 mm meet future miniaturization trend. 2. Low profile for thin type terminal 3. High Stability in Temperature / Humidity Change 4. High mechanical strength APPLICATIONS 1. Bluetooth 2. Wireless LAN 3. HormRF 4. ISM band 2.4GHz wireless applications CONSTRUCTION 3 1 1. Identification mark 2. Soldering terminal 3. Feeding 2 Outline of 2.4GHz Antenna – KH8010080A3T DIMENSIONS Figure Symbol Dimension L 8.00 ± 0.20mm W 1.05 ± 0.20 mm T 0.80 ± 0.10 mm A 0.30 ± 0.20 mm WWW.BDS666.COM 0755-83044319 SOLDER LAND PATTERN DESIGN Figure (Vertical type) ELECTRICAL CHARACTERISTICS KH8010080-A3T Specification Working Frequency Range 2.4 GHz ~ 2.5GHz Gain 2 dBi (Typical) VSWR 2 max. Polarization Linear Azimuth Bandwidth Omni-directional Impedance 50Ω Rated Power (max.) 3 Watts Maximum Input Power 5 Watts for 5 minutes Operation Temperature -40˚C ~ +85˚C Remark: The specification is defined based on the test board dimension as in below WWW.BDS666.COM 0755-83044319 Antenna on Test Board ( FR4 Thickness 0.8mm) Vertical type Antenna S11 on Test Board Vertical type WWW.BDS666.COM 0755-83044319 RADIATION PATTERN (Vertical type) Radiation Pattern and Gain were dependent on measurement board design. The specification of KH8010080A3T antenna was measur ed based on the PCB size and installation position as shown in the below figure Test Board Empty Area Z Y X GROUND GROUND 30.5x18 mm 42x18 mm Vertical Horizontal Y Y Y-Z Plane z z Average Gain= 1.19 dBi Peak Gain = 3.03 dBi Average Gain = 0.71 dBi Peak Gain= -1.37 dBi Average Gain=-8.6 dBi X-Z Plane z Average Gain= -2.91dBi X X Peak Gain= -3.76 dBi Average Gain= -8.72dBi Average Gain= -0.95 dBi Peak Gain= -0.25 dBi Average Gain= -4.24 dBi X X-Y Plane z X Y Y Peak Gain= 0.76 dBi Average Gain= -5.81dBi Peak Gain= 1.37 dBi Average Gain= -2.67 dBi WWW.BDS666.COM 0755-83044319 RELIABILITY TEST Test item Test condition / Test method Specification Solderability JIS C 0050-4.6 *Solder bath temperature:235 ± 5°C At least 95% of a surface of each terminal JESD22-B102D *Immersion time:2 ± 0.5 sec electrode must be covered by fresh solder. *Solder:Sn3Ag0.5Cu for lead-free Leaching *Solder bath temperature:260 ± 5°C Loss of metallization on the edges of each of metallization) *Leaching immersion time:30 ± 0.5 sec electrode shall not exceed 25%. IEC 60068-2-58 *Solder : SN63A (Resistance to dissolution Resistance to soldering heat *Preheating temperature:120~150℃, No mechanical damage. JIS C 0050-5.4 Samples shall satisfy electrical specification 1 minute. after test. *Solder temperature:270±5°C Loss of metallization on the edges of each *Immersion time:10±1 sec electrode shall not exceed 25%. *Solder:Sn3Ag0.5Cu for lead-free Measurement to be made after keeping at room temperature for 24±2 hrs Drop Test JIS C 0044 *Height:75 cm No mechanical damage. *Test Surface:Rigid surface of concrete or Samples shall satisfy electrical specification after test. steel. *Times:6 surfaces for each units;2 times for each side. Adhesive Strength of Termination JIS C 0051- 7.4.3 *Pressurizing force: No remarkable damage or removal of the 5N(≦0603);10N(>0603) termination. *Test time:10±1 sec Bending test The middle part of substrate shall be No mechanical damage. JIS C 0051- 7.4.1 pressurized by means of the pressurizing Samples shall satisfy electrical specification rod at a rate of about 1 mm/s per second after test. until the deflection becomes 1mm/s and then pressure shall be maintained for 5±1 sec. Measurement to be made after keeping at room temperature for 24±2 hours WWW.BDS666.COM 0755-83044319 Temperature cycle JIS C 0025 1. 30±3 minutes at -40°C±3°C, No mechanical damage. 2. 10~15 minutes at room temperature, Samples shall satisfy electrical specification 3. 30±3 minutes at +85°C±3°C, 4. 10~15 minutes at room temperature, after test. Total 100 continuous cycles Measurement to be made after keeping at room temperature for 24±2 hrs Vibration JIS C 0040 *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. *Total amplitude:1.5mm Samples shall satisfy electrical specification *Test times:6hrs.(Two hrs each in three after test. mutually perpendicular directions) High temperature JIS C 0021 *Temperature:85°C±2°C No mechanical damage. *Test duration:1000+24/-0 hours Samples shall satisfy electrical specification Measurement to be made after keeping at after test. room temperature for 24±2 hrs Humidity (steady conditions) *Humidity:90% to 95% R.H. No mechanical damage. *Temperature:40±2°C Samples shall satisfy electrical specification JIS C 0022 after test. *Time:1000+24/-0 hrs. Measurement to be made after keeping at room temperature for 24±2 hrs ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40°C±2°C No mechanical damage. *Test duration:1000+24/-0 hours Samples shall satisfy electrical specification Measurement to be made after keeping at after test. room temperature for 24±2 hrs WWW.BDS666.COM 0755-83044319 SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2 Fig 2. Infrared soldering profile ORDERING CODE RF KH Walsin 801008 Product code HF: RF /Pb free device KH : Antenna Dimension code Per 2 digits of Length, Width, Thickness : 0 A 3 T Unit of dimension Application Specification Packing A : 2.4GHZ ISM Band Design Code T : Reeled 0 : 0.1 mm 1 : 1.0 mm e.g. : 801008 = Length 80, Width 10, Thickness 8 Minimum Ordering Quantity: 2000 pcs per reel. PACKAGING Plastic Tape specifications (unit :mm) Index Ao Bo ΦD T W Dimension (mm) 1.20 ± 0.10 8.20 ± 0.10 1.50 ± 0.10 1.00 ± 0.10 16.0 ± 0.10 Index E F Po P1 P2 Dimension(mm) 1.75 ± 0.10 7.50 ±0.10 4.00 ± 0.05 4.00 ± 0.10 2.00 ± 0.05 WWW.BDS666.CCOM 0755-83044319 Reel dimensions C Index Dimension (mm) A B A B C Φ178 Φ60.0 Φ13.0 Typing Quantity: 2000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) Aircraft equipment (2) Aerospace equipment (3) Undersea equipment (4) Medical equipment (5) Disaster prevention / crime prevention equipment (6) Traffic signal equipment (7) Transportation equipment (vehicles, trains, ships, etc.) (8) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection, which can be confirmed. (2) Storage environment condition. Products should be storage in the warehouse on the following conditions. Temperature : -10 to +40°C Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. WWW.BDS666.COM 0755-83044319
KH-8010080-A3T 价格&库存
很抱歉,暂时无法提供与“KH-8010080-A3T”相匹配的价格&库存,您可以联系我们找货
