TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD
承 認 書
Specification For Approval
Customer: (客戶)
Description: (產品描述)
Part number:(產品型號)
Date:
SMDLED1608
TJ-S1608Y06HQYJY-A3
(日期)
Approved By: (客戶承認)
Prepared By:(我司承認)
Approval
核准
Check
Design
審核
製作
Sales
業務
Customer Service Hotline:400-676-8616
TEL:0769-8662 5999
0769-8200 2226
E-MIAL∶dg@togialed.com
FAX:0769-8200 2227
WEB:www.togialed.com
Features
1.6mmⅹ0.8mm SMT LED, 0.6mm thickness
Low power consumption
Wide view angle
Package: 4000pcs/reel
RoHS Compliant
Applications
Ideal for back light and indicator
Various colors and lens types available
Package outlines
Recommend Pad Layout
0.80 [0.03"]
0.80 [0.03"]
0.04 [0.02"]
0.60 [0.02"]
1.10 [0.04"]
3.00°
2.40 [0.09"]
ATTENTION
0.70 [0.03"]
0.60 [0.02"]
2
1
1
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
2
SENSITIVE
Part No.
Emitted color
Dice
Lens color
TJ-S1608Y06HQYJY-A3
Yellow
AlGaInP
Water transparent
Notes:
1. All dimensions are in millimeters (inches);
2. Tolerances are ±0.1mm (0.004inch) unless otherwise noted.
0.80 [0.03"]
2
1
0.80 [0.03"]
1.60 [0.06"]
Absolute maximum ratings (TA=25℃)
Parameter
Symbol
Value
Unit
Forward current
If
mA
Reverse voltage
Vr
5
V
Power dissipation
Pd
72
mW
Operating temperature
Top
-40 ~+80
Storage temperature
Tstg
-40 ~+85
Ifp
125
mA
Peak pulsing current (1/8 duty f=1kHz)
Electro-optical characteristics (TA=25℃)
Parameter
Test
Condition
Value
Symbol
Unit
Min
Typ
Max
Wavelength at peak emission
If=20mA
λp
595
nm
Spectral half bandwidth
If=20mA
△λ
18
nm
Dominant wavelength
If=20mA
λd
585
595
nm
Forward voltage
If=20mA
Vf
1.8
2.4
V
Luminous intensity
If=20mA
Iv
80
200
mcd
Viewing angle at 50% Iv
If= 10mA
2θ1/2
120
Deg
Vr=5V
Ir
10
µA
Reverse current
Optical characteristic curves
Relative Intensity (%)
Relative Intensity vs. Wavelength
Wavelength (nm)
Forward Voltage (V)
Forward Current vs. Forward Voltage
Forward Current (mA)
Directive Characteristics
Reflow Profile
� Reflow Temp/Time
300
10 S Max.
260℃ Max.
250
230℃
4℃ /S Max.
Temperature
200
1 5 0~ 1 8 0 ℃
4℃ /S Max.
150
6 0~ 1 2 0 S
100
3 0~ 5 0 S
50
25℃
100
150
200
250
Time
300
(sec)
Notes:
1.We recommend the reflow temperature 245℃(±5℃).the maximum soldering
temperature should be limited to 260℃.
2.Don’t cause stress to the epoxy resin while it is exposed to high temperature.
3.Number of reflow process shall be 2 times or less.
�Soldering iron
Basic spec is 5sec when 260℃. If temperature is higher, time should be shorter
(+10℃� -1sec ).Power dissipation of iron should be smaller than 20W,
and temperatures should be controllable .Surface temperature of the device should
be under 230℃ .
�Rework
1.Customer must finish rework within 5 sec under 260℃.
2.The head of iron can not touch copper foil
3.Twin-head type is preferred.
Correct(
Mistake(
� Avoid rubbing or scraping the resin by any object, during high temperature,
for example reflow solder etc.
Test circuit and handling precautions
� Test circuit
R
V
LED
� Handling precautions
1. Over-current-proof
Customer must apply resistors for protection; otherwise slight voltage shift
will cause big current change (Burn out will happen).
2. Storage
2.1 It is recommended to store the products in the following conditions:
Humidity: 60% R.H. Max.
Temperature : 5℃~30℃(41℉~86℉)
2.2 Shelf life in sealed bag: 12 month at <5℃~30℃ and <30% R.H. after
the package is Opened, the products should be used within a week or they
should be keeping to stored at≦20 R.H. with zip-lock sealed.
3. Baking
It is recommended to baking before soldering when the pack is unsealed
after 72hrs. The Conditions are as followings:
3.1 60±3℃ x(12~24hrs) and <5%RH, taped reel type
3.2 100±3℃ x(45min~1hr), bulk type
3.3 130±3℃ x(15~30min), bulk type
Test items and results of reliability
Operation
Sequence
Environmental
Sequence
Type
Number of
Test Item
Test Conditions
Note
Temperature Cycle
-20℃ 30min
80℃ 30min
100 cycle
0/22
Thermal Shock
-20℃ 15min
80℃ 15min
100 cycle
0/22
High Humidity Heat Cycle
30℃⇔ 65℃
90%RH 24hrs/1cycle
10 cycle
0/22
High Temperature Storage
Ta=80℃
1000 hrs
0/22
Humidity Heat Storage
Ta=60℃
RH=90%
1000 hrs
0/22
Low Temperature Storage
Ta=-30℃
1000 hrs
0/22
Life Test
Ta=25℃
IF=20mA
1000 hrs
0/22
High Humidity Heat Life Test
60℃ RH=90%
IF=10mA
500 hrs
0/22
Low Temperature Life Test
Ta=-20℃
IF=20mA
1000 hrs
0/22
Damaged
1608 Series SMD Chip LED Lamps Packaging Specifications
Feeding Direction
Dimensions of Reel (Unit: mm)
RoHS
57.54 [2.27"]
Feeding Direction
13.30 [0.52"]
颜色标签
Lable
9.40 [0.37"]
Dimensions of Tape (Unit: mm)
SEC.A-A
2.00 [0.08"]
0.20 [0.01"]
8.00 [0.31"]
A
5.25 [0.21"]
4.00 [0.16"]
1.75 [0.07"]
1.10 [0.04"]
178.50 [7.03"]
1.05 [0.04"]
4.00 [0.16"]
A
Arrangement of Tape
Empty parts
(Min.20pcs)
Loaded parts
(LED :4000pcs)
Empty parts
(Min.40pcs)
Feeding Direction
Conclusion parts
(Min.80mm)
Introduction parts
(Min.160mm)
Notes:
1. Empty component pockets are sealed with top cover tape;
2. The maximum number of missing lamps is two;
3. The cathode is oriented towards the tape sprocket hole in accordance with
ANSI/EIA RS-481 specifications.
4. 4,000 pcs/Reel.
Packaging specifications
Moisture-proof bag
颜色标签
Ree l (4,000PCS)
RoHS
RoHS
Lable
Lable
Ro
HS
La
bl
ble
e
HS
La
Inside box
Maximums ten reels
Ro
Outside box
Maximums six inside boxes
Notes:
Reeled products (numbers of products are 4,000pcs) packed in a seal off
moisture-proof bag along with a desiccant one by one, Seven moisture-proof bag of
maximums (total maximum number of products are 40,000pcs) packed in an inside
box (about size: 260x 220x 130mm) and four inside boxes of maximums are put in
the outside box (about size: 450mm x 260mm x 400mm) Together with buffer
material, and it is packed. (Part No., Lot No., quantity should appear on the label on
the moisture-proof bag, part No. And quantity should appear on the label on
the
cardboard box.) The number of the loading steps of outside box (cardboard box)
has it to three steps.
TJ-S1608Y06HQYJY-A3 价格&库存
很抱歉,暂时无法提供与“TJ-S1608Y06HQYJY-A3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.11550
- 100+0.10500
- 500+0.09800
- 1000+0.09100
- 5000+0.08260
- 10000+0.07910
