A
2.54*No.of positions±0.3
CHECK
APPROVE
SIZE
UNIT
SCALE
1/1
A4
mm
FIT
PROJ.
SHEET
0.64 SQ
YiYuSheng 12.03.28
2.54*(N-1)Positions±0.2
±0.30
TOL
±3°
DRAW
2.54±0.1
X.X
±0.20
OPERATION
X.XX
Angle
X.XXX ±0.10
DIM
Recommended P.C.B Layout(Top Side)
(PCB BOARD TOLERANCE±0.05)
2.54
2.54*(N-1)Positions
TITLE:
PART NO.
2.54PH H2.5mm 2X19P DIP PA7.7 PC3.0
PH-00347
深圳市连盛精密连接器有限公司
2.54
1
2P
1P
CHANGE
7.70±0.25
02
∅1
FILE NO
:E362810
NEW DRAWING
MODIFICATION DESCRIPTION
5.0±0.15
HSF RoHS
2012.03.28
DATE
3.00±0.25
SPECIFICATIONS
Rated Current:3.0AMP
Contact Resistance:20mΩ Max
Withstand Voltage:1000V AC/DC
Insulation Resistance:1000MΩ Min
Operation Temperature:-40°c to +105°c
1
Contact Material:Brass
Contact Plating:Au3U Over Ni
Insulator Material:Polyester(UL94V-0)
Standard:
PA6T
Max.Processing Temp: 230°C for 30-60 seconds
(260°C for 10 seconds)
A0
REV
2.54±0.1
2.5±0.15
A
很抱歉,暂时无法提供与“PH-00347”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.49700
- 50+1.99830
- 300+1.66890
- 600+1.40230
- 国内价格
- 5+2.22878
- 50+1.78361
- 300+1.48960
- 600+1.25165
- 2400+1.14566
- 5100+1.08200
