FH-00088
FH-00088
    LIANSHENG(连盛)
    插件,P=2.54mm
    排母 间距2.54mm 2x10Pin 直插
FH-00088 数据手册
A 1 SPECIFICATIONS Rated Current:3.0AMP Contact Resistance:20mΩ Max Withstand Voltage:1000V AC/DC Insulation Resistance:1000MΩ Min Operation Temperature:-40°c to +105°c 1 DATE 2012.03.28 MODIFICATION DESCRIPTION NEW DRAWING Contact Material:Brass Contact Plating:Au Over Ni Insulator Material:Polyester(UL94V-0) Standard: PBT Max.Processing Temp: 180°C for 30-60 seconds (200°C for 10 seconds) A0 REV CHANGE ±0.30 TOL ±3° DRAW CHECK APPROVE UNIT SCALE mm FIT 1/1 A4 PROJ. SHEET SIZE Recommended P.C.B Layout(Top Side) (PCB BOARD TOLERANCE±0.05) X.X ±0.20 OPERATION X.XX Angle X.XXX ±0.10 DIM 2.54FH H8.5mm 2x10pin 180° W5.0mm FH-00088 深圳市连盛精密连接器有限公司 PART NO. TITLE: A
FH-00088 价格&库存
很抱歉,暂时无法提供与“FH-00088”相匹配的价格&库存,您可以联系我们找货
FH-00088
  • 23+0.80501
  • 230+0.62429
  • 690+0.54559
  • 2300+0.48657
  • 11500+0.43937
  • 23000+0.41583
库存:473
