CHS-06TB
CHS-06TB
    NIDEC(尼得科)
    SMD,9.2x5.4mm
    拨码开关-SPST-6-位置-表面贴装型-滑动式(标准)-触动器-100mA-6VDC
CHS-06TB 数据手册
SLIDE SWITCHES (HALF PITCH) RoHS compliant CHS INTERNAL STRUCTURE ① ② ③ ⑤ ④ ⑥ Part name ■ FEATURES ● RoHS compliant ● Meets EIAJ SOP standard outline dimensions (B type) ● Low profile design of 2.5 mm ● 12 types of 1, 2, 4, 6, 8 or 10 bit with either gull wing or J-hook available ● Excellent contact stability by twin Gold-plated contact Material Flammability ① Cover Polyphenylenesulphide ② Slider Polyamide ③ Housing ④ Slider contact ⑤ Fixed contact ⑥ Terminal pin UL94V-0 Polyphenylenesulphide Copper alloy, Gold-plated ■ PART NUMBER DESIGNATION CHS - 06 T A 1 Series name Structure 1:Non-washable type (Without seal tape) No. of bits 01:1 bit 02:2 bits 04:4 bits 06:6 bits 08:8 bits 10:10 bits Standard type 2:Non-washable type (With seal tape) Blank : Washable type (With seal tape) Form of packaging Shape of terminal T :Taping (Reel) M:Magazine Blank:Bulk in plastic bag A:J-hook B:Gull wing ※ Please refer to the LIST OF PART NUMBERS when placing orders. CHS SLIDE SWITCHES (HALF PITCH) ■ LIST OF PART NUMBERS No. of bits 1 2 4 6 8 10 No. of bits 1 2 4 6 8 10 Form of packaging Shape of terminals Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag J-hook A (    ) Non-washable type (With seal tape) Gull wing ) A (    ) J-hook B(       Gull wing ) B(       Pieces in package CHS-01TA1 CHS-01TB1 CHS-01TA2 CHS-01TB2 1000 pcs./reel Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Form of packaging Non-washable type (Without seal tape) CHS-01A1 CHS-01B1 50 pcs./pack CHS-02TA1 CHS-02TB1 CHS-02TA2 CHS-02TB2 500 pcs./reel CHS-02A1 CHS-02B1 50 pcs./pack CHS-04TA1 CHS-04TB1 CHS-04TA2 CHS-04TB2 500 pcs./reel CHS-04MA1 CHS-04MB1 70 pcs./stick CHS-04A1 CHS-04B1 50 pcs./pack CHS-06TA1 CHS-06TB1 CHS-06TA2 CHS-06TB2 500 pcs./reel CHS-06MA1 CHS-06MB1 50 pcs./stick CHS-06A1 CHS-06B1 50 pcs./pack CHS-08TA1 CHS-08TB1 CHS-08TA2 CHS-08TB2 500 pcs./reel CHS-08MA1 CHS-08MB1 40 pcs./stick CHS-08A1 CHS-08B1 50 pcs./pack CHS-10TA1 CHS-10TB1 CHS-10TA2 CHS-10TB2 500 pcs./reel CHS-10MA1 CHS-10MB1 30 pcs./stick CHS-10A1 CHS-10B1 50 pcs./pack Shape of terminals Washable type (With seal tape) J-hook A (    ) Gull wing ) B(       Pieces in package CHS-01TA CHS-01TB 1000 pcs./reel CHS-01A CHS-01B 50 pcs./pack CHS-02TA CHS-02TB 500 pcs./reel CHS-02A CHS-02B 50 pcs./pack CHS-04TA CHS-04TB 500 pcs./reel CHS-04MA CHS-04MB 70 pcs./stick CHS-04A CHS-04B 50 pcs./pack CHS-06TA CHS-06TB 500 pcs./reel CHS-06MA CHS-06MB 50 pcs./stick CHS-06A CHS-06B 50 pcs./pack CHS-08TA CHS-08TB 500 pcs./reel CHS-08MA CHS-08MB 40 pcs./stick CHS-08A CHS-08B 50 pcs./pack CHS-10TA CHS-10TB 500 pcs./reel CHS-10MA CHS-10MB 30 pcs./stick CHS-10A CHS-10B 50 pcs./pack   : Not manufactured ※ Verify the above part numbers when placing orders. Taping and magazine version can be supplied only in reel or stick units. CHS SLIDE SWITCHES (HALF PITCH) ■ STANDARD SPECIFICATIONS ■ ELECTRICAL CHARACTERISTICS Operating temp. range Contact rating Non-switching Switching Minimum − 40 ~ 85 °C Storage temp. range Sealing Net weight Washable type available with seal tape Contact resistance Approx. 0.05 g (CHS-01) Approx. 0.08 g (CHS-02) Approx. 0.12 g (CHS-04) Approx. 0.17 g (CHS-06) Approx. 0.22 g (CHS-08) Approx. 0.25 g (CHS-10) Insulation resistance Dielectric strength ■ MECHANICAL CHARACTERISTICS Operating force DC50 V 100 mA DC6 V, 100 mA DC24 V, 25 mA DC20 mV 1 μA 50 mΩ maximum 1000 MΩ (DC100 V) minimum AC500 V, 60 s ■ ENVIRONMENTAL CHARACTERISTICS 0.5 ~ 5 N {0.05 ~ 0.51 kgf} Vibration (Amplitude) 1.5 mm or (Acceleration) 98 m/s2, 10-500 Hz, 3 directions for 10 cycles each Stop strength 10 N {1.02 kgf}, 60 s Shock 490 m/s2, 11 ms 6 directions for 3 times each Solderability 245 ± 3 °C, 2 ~ 3 s Load life Continuous load 2000 cycles, DC6 ± 0.5 V, 100 ± 10 mA Reflow:255 °C (Peak temperature) (Please refer to the profile below) Humidity −10 ~ 65 °C, Relative humidity 0 ~ 96 %, 24 h for 10 cycles Soldering heat Manual soldering:350 ± 10 °C, 3 ~ 4 s High temp. exposure 85 °C, 96 h Shear (Adhesion) 5 N {0.51 kgf} 10 s Low temp. exposure − 40 °C, 96 h Substrate bending Width 90 mm, bend 3 mm, 5 s, 1 time Pull-off strength Thermal shock 5 N {0.51 kgf} 10 s { } : Reference only 〈Reflow profile for soldering heat evaluation〉 Temperature (℃) 250 200 150 100 50 Peak : 250 +5 0 ℃ Over 230 ℃ 180 ℃ 150 ℃ Pre Heating Zone 90 ± 30 s 30 ± 10 s Heating time Reflow : two times maximum Soldering Zone − 40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) 8 5.4 O N 0.1 0.15+–0.05 0.3 2.5 2.5 max. 0.6 CHS-02B1 外形図 0.1 0.6+–0.05 0 0.1–0.1 + 0.1 –0.05 2.5 Schematic Schematic ● CHS-02B1 Non-washable type (Without seal tape) 1.4±0.15 Schematic 0.4 min. O N 0.1 0.15+–0.05 0.3 2 0.1 0.4+–0.05 1.27±0.15 4.1 2.5 max. 0.1±0.1 0.3 2.5 max. 0.1±0.1 - C Stroke 0.6 0. 5 0.1 0.15+–0.05 3.8 5.6+0.3 0 5.4 O N Production date code 2 - C Stroke 0.6 0. 5 Production date code (In accordance with EIAJ ED-7402-1) 0.1 0.4+–0.05 1.27±0.15 4.1 1.4±0.15 Schematic 0.4 min. ● CHS-02A1 Non-washable type (Without seal tape) 8 5.4 0.3 0 0.1 –0.1 2.5 max. 2 – 2 C – C 0.1 0.15+–0.05 Stroke 0.6 0. 5 0. 5 3.8 Production date code 5.6+0.3 0 5.4 O N Stroke 0.6 Production date code 0.4 min. ● CHS-01B1 Non-washable type (Without seal tape) 0.4 min. ● CHS-01A1 Non-washable type (Without seal tape) CHS SLIDE SWITCHES (HALF PITCH) CHS-04B1 外形図 ■ OUTLINE DIMENSIONS ● CHS-04B1 (In accordance with EIAJ ED-7402-1) Non-washable type (Without seal tape) 1.4±0.15 0.1 0.4+–0.05 1.27±0.15 CHS-06B1 外形図 Schematic ● CHS-06B1 (In accordance with EIAJ ED-7402-1) Non-washable type (Without seal tape) Schematic 8 5.4 O N - C Stroke 0.6 0. 5 0.3 2.5 max. 1.4±0.15 0.1±0.1 9.2 0.1 0.4+–0.05 1.27±0.15 0.1 0.15+–0.05 2 3.8 5.6+0.3 0 5.4 O N - C Stroke 0.6 0. 5 0.3 2.5 max. 2 0.1 0.15+–0.05 0.4 min. Production date code Production date code 0.1±0.1 1.4±0.15 Schematic ● CHS-06A1 Non-washable type (Without seal tape) 0.4 min. 8 5.4 2 0.1 0.15+–0.05 6.6 0.3 2.5 max. 0.1±0.1 0.1±0.1 2.5 max. 0.3 6.6 0.1 0.4+–0.05 1.27±0.15 O N - C Stroke 0.6 0. 5 3.8 5.6+0.3 0 5.4 O N 2 - C Stroke 0.6 0. 5 0.1 0.15+–0.05 0.4 min. Production date code Production date code 9.2 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic 0.4 min. ● CHS-04A1 Non-washable type (Without seal tape) Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) SLIDE SWITCHES (HALF PITCH) CHS-08B1 外形図 ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CHS-08B1 (In accordance with EIAJ ED-7402-1) Non-washable type (Without seal tape) 2.5 max. 0.1±0.1 1.4±0.15 Schematic 1 外形図 ● CHS-10A1 Non-washable type (Without seal tape) CHS-10B1 0.1 0.4+–0.05 1.27±0.15 Schematic ● CHS-10B1 (In accordance with EIAJ ED-7402-1) Non-washable type 外形図 (Without seal tape) Production date code 2.5 max. 0.1±0.1 2.5 max. 0.1±0.1 8 5.4 O N - C Stroke 0.6 0. 5 14.3 14.3 0.1 0.4+–0.05 1.27±0.15 0.1 0.15+–0.05 2 3.8 5.6 +0.3 0 5.4 O N 2 - C Stroke 0.6 0. 5 Production date code 0.1 0.15+–0.05 1.4±0.15 1.4±0.15 Schematic 0.4 min. 0.1 0.4+–0.05 1.27±0.15 0.4 min. 8 5.4 O N 2 0.1 0.15+–0.05 11.7 0.3 2 11.7 0.3 2.5 max. - C Stroke 0.6 0. 5 3.8 5.6 +0.3 0 5.4 O N - C Stroke 0.6 0. 5 0.1 0.15+–0.05 0.4 min. Production date code Production date code 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic 0.4 min. ● CHS-08A1 Non-washable type (Without seal tape) 0.1±0.1 図 CHS CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CHS-01A ● CHS-01B Washable type (With seal tape) Washable type (With seal tape) ● CHS-01TA2 ● CHS-01TB2 0. 5 2 8 5.4 – 2 Seal tape 0.1 0.6 +–0.05 2.5 0 0.1–0.1 CHS-02B 外形図 Schematic 0.3 2.5 max. 2.5 0.3 0.1 –0.1 2.5 max. O N 3.8 Seal tape 0 0.1 0.15 +–0.05 C – C 0.1 0.15 +–0.05 Stroke 0.6 0. 5 Production date code 5.6 +0.3 0 5.4 O N Stroke 0.6 Production date code 0.4 min. Non-washable type (With seal tape) 0.4 min. Non-washable type (With seal tape) 0.1 0.6 +–0.05 Schematic ● CHS-02A ● CHS-02B Washable type (With seal tape) Washable type (With seal tape) ● CHS-02TB2 ● CHS-02TA2 Non-washable type (With seal tape) Non-washable type (With seal tape) (In accordance with EIAJ ED-7402-1) 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 0.3 Seal tape 2.5 max. 0.1±0.1 0.3 4.1 4.1 0.1 0.4+–0.05 1.27±0.15 Schematic Seal tape 1.4±0.15 Schematic 0.4 min. 8 5.4 O N - C Stroke 0.6 0. 5 0.1 0.15+–0.05 2 3.8 5.6+0.3 0 5.4 O N - C Stroke 0.6 0. 5 2.5 max. 0.1±0.1 2 0.1 0.15+–0.05 0.4 min. Production date code Production date code CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS CHS-04B 外形図 ● CHS-04A Washable type (With seal tape) Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CHS-04B Washable type (With seal tape) ● CHS-04TB2 ● CHS-04TA2 Non-washable type (With seal tape) Non-washable type (With seal tape) (In accordance with EIAJ ED-7402-1) 0.4 min. 8 5.4 2 0.1 0.4+–0.05 1.27±0.15 Seal tape 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic CHS-06B 外形図 ● CHS-06A 6.6 2.5 max. 0.1±0.1 0.3 6.6 0.3 2.5 max. 0.1±0.1 0.1 0.15+–0.05 Washable type (With seal tape) ● CHS-06TA2 Seal tape 0.4 min. 0.1 0.15+–0.05 O N - C Stroke 0.6 0. 5 3.8 5.6+0.3 0 5.4 O N Production date code 2 - C Stroke 0.6 0. 5 Production date code 1.4±0.15 Schematic ● CHS-06B Washable type (With seal tape) ● CHS-06TB2 Non-washable type (With seal tape) Non-washable type (With seal tape) (In accordance with EIAJ ED-7402-1) 1.4±0.15 Schematic 0.3 9.2 0.1 0.4+–0.05 1.27±0.15 Seal tape 1.4±0.15 Schematic 0.4 min. 8 5.4 O N - C Stroke 0.6 0. 5 0.1 0.15+–0.05 2 0.1 0.4+–0.05 1.27±0.15 Seal tape 2.5 max. 9.2 0.1±0.1 0.3 2 0.1±0.1 2.5 max. 3.8 5.6+0.3 0 5.4 O N - C Stroke 0.6 0. 5 0.1 0.15+–0.05 0.4 min. Production date code Production date code CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS CHS-08B 外形図 ● CHS-08A Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CHS-08B Washable type (With seal tape) Washable type (With seal tape) ● CHS-08TA2 ● CHS-08TB2 Non-washable type (With seal tape) Non-washable type (With seal tape) (In accordance with EIAJ ED-7402-1) 2 0.1 0.15+–0.05 1.4±0.15 Schematic CHS-10A 外形図● Washable type (With seal tape) 11.7 0.3 2.5 max. 0.1±0.1 0.1 0.4+–0.05 1.27±0.15 Schematic Washable type (With seal tape) CHS-10B 外形図 ● CHS-10TB2 Non-washable type (With seal tape) (In accordance with EIAJ ED-7402-1) Production date code 2.5 max. 8 5.4 14.3 0.1±0.1 2.5 max. 0.1±0.1 Schematic O N - C Stroke 0.6 0. 5 Seal tape 1.4±0.15 0.1 0.15+–0.05 2 3.8 5.6 +0.3 0 5.4 O N 0.1 0.15+–0.05 2 - C Stroke 0.6 0. 5 Production date code 0.4 min. Non-washable type (With seal tape) 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 ● CHS-10B ● CHS-10TA2 14.3 Seal tape 0.1 0.4+–0.05 1.27±0.15 Seal tape 1.4±0.15 Schematic 0.4 min. 0.1 0.4+–0.05 1.27±0.15 Seal tape 0.4 min. 8 5.4 O N - C Stroke 0.6 0. 5 3.8 5.6 +0.3 0 5.4 O N - C Stroke 0.6 0. 5 11.7 0.3 0.1±0.1 2.5 max. 2 0.1 0.15+–0.05 0.4 min. Production date code Production date code CHS-08D 外形図 CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CHS-08D 2.5 max. 0.4 min. 8 5.4 O N 0 0.8 –0.2 2 - C Stroke 0.6 0. 5 Production date code 0.4 min. The D version with opposite pin direction is available upon receipt of your order. 11.7 0.1 0.15+–0.05 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS (Unit : mm) ● 1 bit B type 1.6 0 5.08 0 1.27 1 7.62 A type 1 ● 2 bits 1.27 B type 1.27 0 1.27 1.6 5.08 0 0.76 7.62 A type 0.76 Note) The zero point is the center of mounting. 0.76 5.08 0 1.27 1.6 0 0.76 7.62 1.27N (N=1~3) =3.81 1.27N (N=1~3) =3.81 CHS SLIDE SWITCHES (HALF PITCH) 1.27 1.27 0 0 1.27N 0.76 (N=1~7) =8.89 1.27N (N=1~9) 0 =11.43 1.6 1.6 1.6 A type 0 1.27N (N=1~9) 0 =11.43 0.76 1.27 0.76 1.6 0.76 0.76 0 B type 1.27 1.27 1.27 1.27N (N=1~9) =11.43 0.76 0.76 0 1.27N (N=1~7) =8.89 0.76 1.27N (N=1~7) =8.89 1.27N 0.76 (N=1~7) =8.89 0 0 1.27N (N=1~7) =8.89 0.76 0 0.76 0 1.27N (N=1~9) =11.43 0.76 1.27N (N=1~9) =11.43 1.27N (N=1~9) =11.43 0.76 0 0 1.27N (N=1~9) =11.43 0.76 0.76 0.76 0 0 1.27 0.76 0 1.27N (N=1~9) =11.43 1.27 1.27 1.27 0.76 5.08 5.08 5.08 ● 10 bits 0 1.27N (N=1~7) =8.89 0.76 0 5.08 1.6 1.6 1.6 1.6 1.27N (N=1~7) 0 =8.89 B type 5.08 5.08 5.08 A type 1.27 5.08 0.760 1.27N (N=1~7) =8.89 1.27N (N=1~5) =6.35 0 0.76 7.62 7.62 7.62 0.76 1.27N (N=1~5) =6.35 7.62 1.27N (N=1~5) =6.35 5.08 1.6 ● 8 bits 1.27N (N=1~5) =6.35 0.76 0 1.27 1.27 1.27 0 1.27N (N=1~5) =6.35 7.62 1.27N (N=1~5) =6.35 1.27N (N=1~3) =3.81 7.62 7.62 7.62 0 0.76 1.27 1.27N (N=1~5) =6.35 0.76 0 B type 5.08 5.08 5.08 0.76 0 0.76 7.62 5.08 1.27N (N=1~5) =6.35 1.6 1.6 1.6 1.27 1.27 1.27 1.6 1.6 0.76 0 0.76 0.761.27N (N=1~3) =3.81 0 0 1.27N (N=1~3) =3.81 0.76 0 0 0.76 1.27N (N=1~3) =3.81 1.27N (N=1~3) =3.81 5.08 5.08 5.08 1.6 0 1.6 A type 0.76 1.27N (N=1~3) =3.81 1.27 1.6 0 ● 6 bits 0 1.27N (N=1~3) =3.81 0.761.27N (N=1~3) =3.81 (Unit : mm) 0.76 7.62 7.62 7.62 B type 0.76 7.62 0 0.76 5.08 A type 0.76 7.62 7.62 7.62 0 0.76 1.6 1.6 ● 4 bits 1.27 1.27 1.27 1.6 1.27 ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS 1.27 0 7.62 0 1.27 0 5.08 5.08 5.08 1.270 7.62 7.62 7.62 1.27 1.27 0.76 Note) The zero point is the center of mounting. CHS SLIDE SWITCHES (HALF PITCH) ■ PACKAGING SPECIFICATIONS ● Taping version (CHS-02 ~ 10 types) are packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc. CHS-01 type is packaged in 1000 pcs. per reel. Orders will be accepted for units of 1000 pcs., i.e., 2000, 3000 pcs., etc. ● Taping version is boxed with two reels. Maximum number of consecutive missing pieces=2 Leader length and reel dimension are shown in the diagrams below: ● Embossed tape dimensions ● Reel dimensions (Unit: mm) (Conforms to JIS C 0806-3) (In accordance with EIAJ ET-7200A) Empty Filled End Head 40 mm min. 20 pitches min. Leader 400 mm min. Direction of feed φ 21±0.8 φ 50 min. (1,2,4,6 bits) φ 100±1 (8,10 bits) Empty 17.4±1 (1,2,4,6 bits) 25.4±1 (8,10 bits) 2±0.5 φ 13±0.2 21.4±1 (1,2,4,6 bits) 29.4±1 (8,10 bits) φ 254±2 ● 1 bit O N 7.5 ± 0.1 4 ± 0.1 2 ± 0.1 (CHS-01A) Installation example Direction of feed Direction of feed 0.3 ± 0.1 (CHS-02A) Installation example 16 O N 2 ± 0.1 7.5 ± 0.1 12 ± 0.1 4 ± 0.1 φ 1.5 +0.1 0 3 1.75 ± 0.1 ● 2 bits (Unit : mm) 0.3 ± 0.1 16 8 ± 0.1 φ 1.5 +0.1 0 1.75 ± 0.1 (Conforms to JIS C 0806) 3 CHS SLIDE SWITCHES (HALF PITCH) O N (Conforms to JIS C 0806) 1.75 ± 0.1 φ 1.5 +0.1 0 7.5 ± 0.1 12 ± 0.1 4 ± 0.1 2 ± 0.1 0.3 ± 0.1 (Unit : mm) (CHS-04A) Installation example 16 ● 4 bits 3 7.5 ± 0.1 12 ± 0.1 4 ± 0.1 2 ± 0.1 φ 1.5 +0.1 0 O N 0.3 ± 0.1 (CHS-06A) Installation example 16 ● 6 bits 1.75 ± 0.1 Direction of feed 3 ● 8 bits 2 ± 0.1 0.3 ± 0.1 (CHS-08A) Installation example 11.5 ± 0.1 24 12 ± 0.1 4 ± 0.1 φ 1.5 +0.1 0 1.75 ± 0.1 Direction of feed O N CHS-10 Taping (J) 3 ● 10 bits O N 0.3 ± 0.1 (CHS-10A) Installation example 11.5 ± 0.1 24 12 ± 0.1 4 ± 0.1 2 ± 0.1 φ 1.5 +0.1 0 1.75 ± 0.1 Direction of feed Direction of feed 3 CHS SLIDE SWITCHES (HALF PITCH) ● Packing quantities of magazines are different depending on the bit number of the switches. Please order the multiple numbers of the specific packing quantities. (e.g. 70 pcs., 140 pcs., 210 pcs., etc., in case of 4 bits version) Pieces in package : 4 bits, 70pcs./stick 6 bits, 50pcs./stick 8 bits, 40pcs./stick 10 bits, 30pcs./stick CHS マガジン ● Magazine dimensions (Unit : mm) 10.4 ± 0.3 3.9 ± 0.3 ※ The magazine is common to A and B terminal pin. Magazine length : 500 ± 2 mm long (B type) Installation example ● The smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs., etc. ● Boxing of bulk in a plastic bag is performed with 50 pcs. (standard 200 pcs.) per box.
CHS-06TB 价格&库存
很抱歉,暂时无法提供与“CHS-06TB”相匹配的价格&库存,您可以联系我们找货
CHS-06TB
  • 2+16.56321
  • 10+16.06855
  • 100+15.58431
  • 250+15.12090
库存:780
CHS-06TB
  • 500+15.18754
  • 1000+14.57417
  • 2000+13.80667
库存:780
CHS-06TB
  • 1+26.913391+3.48197
  • 10+22.6108910+2.92533
  • 25+20.9607625+2.71184
  • 100+18.67205100+2.41573
  • 250+17.33651250+2.24294
库存:4310
CHS-06TB
  • 500+14.84812500+1.92100
  • 1000+14.236731000+1.84190
  • 2500+13.537992500+1.75150
  • 5000+13.013945000+1.68370
CHS-06TB
  • 500+16.42993500+2.12565
  • 1000+15.613511000+2.02003
  • 1500+15.177281500+1.96359
  • 2500+14.670052500+1.89797
  • 3500+14.360773500+1.85795
  • 5000+14.053625000+1.81821
库存:4310
CHS-06TB
    库存:17
