UC.01.62-16-0006
UC.01.62-16-0006
    BBJCONN(步步精)
    USB24_C_11R00X13R0_TM
    USB连接器 TYPE-C USB24_C_11R00X13R0_TM
UC.01.62-16-0006 数据手册
1 2 3 4 5 6 7 8 REV. DESCRIPTION A NEWS ISSUE NAME DATE 1.Contact Resistance:40mOHM Max.; 2.Dielectric Withstanding Voltage:100V AC For 1 Minute; 3.Insulation Resistance:100M OHM Min.; 4.Mating And Unmating Force: Mating Force: 5~20N Unmating Force: 8~20N(0~1000cycle); 6~20N(1001~10000cycle); 5.Durability:10000 Cycles; A A USB TYPE-C FULL-FEATURED RECEPTACLE INTERFACE PIN ASSIGNMENTS B C PIN Signal Name A1 GND Description Ground return PIN Signal Name B12 GND Description A2 Positive half of firs t SSTXp1 SuperSpeed TX B11 differential pair Positive half of firs t SSRXp1 SuperSpeed RX differential pair A3 Negative half of SSTXn1 first SuperSpeed TX differential pair Negative half of SSRXn1 first SuperSpeed RX differential pair B10 A4 VBUS Bus Power B9 VBUS Bus Power A5 CC1 Configuration Channel B8 SBU2 Sideband Use (SBU) A6 Dp1 B7 Dn2 Positive half of the USB 2.0 differential pair-Position 1 Negative half of the USB 2.0 differential pair-Position 1 Negative half of the USB 2.0 differential pair-Position 2 A7 Dn1 B6 Dp2 SBU1 Sideband Use(SBU) B5 CC2 Configuraation Channel VBUS Bus Power B4 VBUS Bus Power A10 Negative half of SSRXn2 second SuperSpeed RX differential pair B3 Negative half of SSTXn2 second SuperSpeed TX differential pair A11 Positive half of SSRXp2 second SuperSpeed RX differential pair B2 Positive half of SSTXp2 second SuperSpeed TX differential pair D A12 GND Ground return B1 GND C Positive half of the USB 2.0 differential pair-Position 2 A8 A9 B Ground return D Ground return E E TOLERANCE UNSPECIFIED .0 ±0.3 .00 ±0.2 .000 ±0.1 .0° ±1.0° .00° ±0.5° .000° ±0.2° F 1 2 3 4 深圳市步步精科技有限公司 TITLE: TYPE-C 24P 母座 直立式H=13.0 DRAWN/ DATE 设计 HMY CHECKED/ DATE 审核 LYX SCALE: 1:1 APPROVED/ DATE 核准 LJP DWG. 5 SIZE:A4 6 UNIT:MM. PART.NO: PATH F UC.01.62-16-0006 REV.: PROJECTION 0299-2 7 版本 SHEET: 页码 8 1 2 3 4 5 6 7 8 REV. DESCRIPTION A NEWS ISSUE NAME DATE A A B B C C D D 250 /PCS盘 备注: 1.包装数量:250 /PCS/盘,10盘/箱或15盘/箱。 2.包装袋长度:每盘前后各空10-20个空格,中间包装。 3.材质: 载体:聚丙烯(PS),阻抗10 6-9 Ω 上带:聚乙烯(PET),阻抗10 6-11Ω 卷盘:聚苯乙烯。 TOLERANCE UNSPECIFIED . 深圳市步步精科技有限公司 .0 ±0.35 纸箱规格:345*345*23MM .00 ±0.25 .000 ±0.15 纸箱规格:345*345*35MM TITLE: X.° ±2.00° E TYPE-C 24P 母座 直立式H=13.0 CUSTOMER DRAWING F 1 2 3 4 DRAWN/ DATE 设计 HMY CHECKED/ DATE 审核 LYX SCALE: 1:1 APPROVED/ DATE 核准 LJP DWG. 5 E SIZE:A4 6 UNIT:MM. PART.NO: F UC.01.62-16-0006 REV.: PROJECTION 0299-2 PATH 7 版本 SHEET: 页码 8
UC.01.62-16-0006 价格&库存
很抱歉,暂时无法提供与“UC.01.62-16-0006”相匹配的价格&库存,您可以联系我们找货
