UC.01.32-16-0002
UC.01.32-16-0002
    BBJCONN(步步精)
    USB连接器 Type-C 24Pin 沉板
UC.01.32-16-0002 数据手册
1 2 3 4 6 5 A B B C C D D 1.25 A E E TOLERANCE UNSPECIFIED . ±0.50 .0 ±0.38 .00 ±0.25 .000 ±0.10 ANGLE ±3.00° CUSTOMER DRAWING F 1 2 3 4 深圳市步步精科技有限公司 TITLE: TYPE-C 24P 母座 沉板1.25 L=8.65单壳 CH0.32 DRAWN BY: HMY CHECKED BY: LYX SCALE: 1:1 APPROVED BY: LJP DWG . PATH 5 SIZE:A4 6 UNIT:mm. PART NO. F UC.01.32-16-0002 PROJECTION REV.: A 0285-1 SHEET:1/4 7 8 1 2 3 4 6 5 7 8 USB TYPE-C FULL-FEATURED RECEPTACLE INTERFACE PIN ASSIGNMENTS A B PIN Signal Name A1 GND Description Ground return PIN Signal Name B12 GND Description Ground return A2 Positive half of firs t SSTXp1 SuperSpeed TX B11 differential pair Positive half of firs t SSRXp1 SuperSpeed RX differential pair A3 Negative half of SSTXn1 first SuperSpeed TX differential pair Negative half of SSRXn1 first SuperSpeed RX differential pair B10 A4 VBUS Bus Power B9 VBUS Bus Power A5 CC1 Configuration Channel B8 SBU2 Sideband Use (SBU) A6 Dp1 B7 Dn2 A7 Dn1 A8 SBU1 A9 VBUS Positive half of the USB 2.0 differential pair-Position 1 Negative half of the USB 2.0 differential pair-Position 1 B6 Dp2 Sideband Use(SBU) B5 CC2 Configuraation Channel Bus Power B4 VBUS Bus Power B3 Negative half of SSTXn2 second SuperSpeed TX differential pair A11 Positive half of SSRXp2 second SuperSpeed RX differential pair B2 Positive half of SSTXp2 second SuperSpeed TX differential pair B1 Ground return GND C Positive half of the USB 2.0 differential pair-Position 2 A10 GND B Negative half of the USB 2.0 differential pair-Position 2 Negative half of SSRXn2 second SuperSpeed RX differential pair A12 A D Ground return E E TOLERANCE UNSPECIFIED . ±0.50 .0 ±0.38 .00 ±0.25 .000 ±0.10 ANGLE ±3.00° CUSTOMER DRAWING F RECOMMEND P.C.B LAYOUT(COMPONENT SIDE) TOLERANCE FOR PCB LAYOUT IS ± 0.05 KEEP OUT AREA 1 2 3 4 深圳市步步精科技有限公司 TITLE: TYPE-C 24P 母座 沉板1.25 L=8.65单壳 CH0.32 DRAWN BY: HMY CHECKED BY: LYX SCALE: 1:1 APPROVED BY: LJP DWG . PATH 5 SIZE:A4 6 UNIT:mm. PART NO. F UC.01.32-16-0002 PROJECTION REV.: A 0285-1 SHEET:2/4 7 8 1 2 3 4 5 7 6 8 出料方向 A A EMPTY 25 PCS EMPTY 25PCS PART 空余25PCS B MM 空余25PCS TOP PART (EMPTY) 300MM MIN B TAIL PART (EMPTY) 300MM MIN COMPONENT SUPPLIER C D E E TOLERANCE UNSPECIFIED . ±0.50 .0 ±0.38 .00 ±0.25 .000 ±0.10 ANGLE ±3.00° CUSTOMER DRAWING F 1 2 3 4 深圳市步步精科技有限公司 TITLE: TYPE-C 24P 母座 沉板1.25 L=8.65单壳 CH0.32 SIZE:A4 UNIT:mm. PART NO. DRAWN BY: HMY CHECKED BY: LYX SCALE: 1:1 APPROVED BY: LJP DWG . PATH 5 6 F UC.01.32-16-0002 PROJECTION REV.: A 0285-1 SHEET:3/4 7 8 1 2 3 4 6 5 7 8 at small positioning hole of the carrier tape side). 標簽黏貼處 (朝捲裝包材的小定位孔一側) Location of label sticking (label A A 緩衝材 (保麗龍) B B 包裝盤 防水袋 C 緩衝材 (保麗龍) D 防撞三角柱(4Pcs) E E 紙箱 TOLERANCE UNSPECIFIED . ±0.50 .0 ±0.38 .00 ±0.25 .000 ±0.10 ANGLE ±3.00° CUSTOMER DRAWING F 1 2 3 4 深圳市步步精科技有限公司 TITLE: TYPE-C 24P 母座 沉板1.25 L=8.65单壳 CH0.32 DRAWN BY: HMY CHECKED BY: LYX SCALE: 1:1 APPROVED BY: LJP DWG . PATH 5 SIZE:A4 6 UNIT:mm. PART NO. F UC.01.32-16-0002 PROJECTION REV.: A 0285-1 SHEET:4/4 7 8
UC.01.32-16-0002 价格&库存
很抱歉,暂时无法提供与“UC.01.32-16-0002”相匹配的价格&库存,您可以联系我们找货
