UC.01.32-1F-0002
UC.01.32-1F-0002
    BBJCONN(步步精)
    SMD
    USB连接器 Type-C 24Pin 卧贴
UC.01.32-1F-0002 数据手册
1 2 3 4 5 6 7 8 REV. DESCRIPTION A NEWS ISSUE NAME DATE A A B B C C D D E E TOLERANCE UNSPECIFIED .0 ±0.3 .00 ±0.2 .000 ±0.1 .0° ±1.0° .00° ±0.5° .000° ±0.2° F 1 2 3 4 深圳市步步精科技有限公司 TITLE: TYPE-C 24P 母座 沉板1.25 L=10.0外壳无固定脚 CH0.33 DRAWN/ DATE 设计 HMY CHECKED/ DATE 审核 LYX SCALE: 1:1 APPROVED/ DATE 核准 LJP DWG. 5 SIZE:A4 6 UNIT:MM. PART.NO: PATH F UC.01.32-1F-0002 PROJECTION REV.: 0299-2 7 版本 SHEET: 页码 8 1 2 3 4 5 6 7 8 REV. DESCRIPTION A NEWS ISSUE NAME DATE A A USB TYPE-C FULL-FEATURED RECEPTACLE INTERFACE PIN ASSIGNMENTS B PIN Signal Name A1 GND TOLERANCE FOR PCB LAYOUT IS ± 0.05 KEEP OUT AREA B12 GND Description B Ground return A2 B11 A3 Negative half of SSTXn1 first SuperSpeed TX differential pair B10 Negative half of SSTXn1 first SuperSpeed TX differential pair A6 RECOMMEND P.C.B LAYOUT(COMPONENT SIDE) Signal Name Positive half of firs SSTXp1 SuperSpeed TX differential pair A5 D Ground return PIN Positive half of firs SSTXp1 SuperSpeed TX differential pair A4 C Description VBUS Bus Power CC1 Configuration Channel Dp1 B9 Positive half of the USB 2.0 differential pair-Position 1 Negative half of the USB 2.0 differential pair-Position 1 B8 VBUS Bus Power CC1 Configuration Channel B7 Dp1 B6 Dn1 Negative half of the USB 2.0 differential pair-Position 1 A7 Dn1 A8 RFU1 Reserved for Future Use (RFU) B5 RFU1 Reserved for Future Use (RFU) A9 VBUS Bus Power B4 VBUS Bus Power A10 Negative half of SSRXn2 second SuperSpeed RX differential pair B3 Negative half of SSRXn2 second SuperSpeed RX differential pair A11 Positive half of SSRXn2 second SuperSpeed RX differential pair B2 Positive half of SSRXn2 second SuperSpeed RX differential pair A12 GND Ground return B1 GND C Positive half of the USB 2.0 differential pair-Position 1 D Ground return E E TOLERANCE UNSPECIFIED .0 ±0.3 .00 ±0.2 .000 ±0.1 .0° ±1.0° .00° ±0.5° .000° ±0.2° F 1 2 3 4 深圳市步步精科技有限公司 TITLE: TYPE-C 24P 母座 沉板1.25 L=10.0外壳无固定脚 CH0.33 DRAWN/ DATE 设计 HMY CHECKED/ DATE 审核 LYX SCALE: 1:1 APPROVED/ DATE 核准 LJP DWG. 5 SIZE:A4 6 UNIT:MM. PART.NO: PATH F UC.01.32-1F-0002 REV.: PROJECTION 0299-2 7 版本 SHEET: 页码 8 1 2 3 4 5 6 7 8 REV. DESCRIPTION A NEWS ISSUE NAME DATE A A B B C C D D 1000 /PCS盘 备注: 1000 /PCS/盘,10盘/箱或15盘/箱。 1.包装数量: 2.包装袋长度:每盘前后各空10-20个空格,中间包装。 3.材质: 载体:聚丙烯(PS),阻抗10 6-9 Ω 上带:聚乙烯(PET),阻抗10 6-11Ω 卷盘:聚苯乙烯。 TOLERANCE UNSPECIFIED . 深圳市步步精科技有限公司 .0 ±0.35 纸箱规格:345*345*23MM .00 ±0.25 .000 ±0.15 纸箱规格:345*345*35MM TITLE: X.° ±2.00° E TYPE-C 24P 母座 沉板1.25 L=10.0外壳无固定脚 CH0.33 CUSTOMER DRAWING F 1 2 3 4 DRAWN/ DATE 设计 HMY CHECKED/ DATE 审核 LYX SCALE: 1:1 APPROVED/ DATE 核准 LJP DWG. 5 E SIZE:A4 6 F UC.01.32-1F-0002 UNIT:MM. PART.NO: REV.: PROJECTION 0299-2 PATH 7 版本 SHEET: 页码 8
UC.01.32-1F-0002 价格&库存
很抱歉,暂时无法提供与“UC.01.32-1F-0002”相匹配的价格&库存,您可以联系我们找货
