UC.01.31-1N-0001
UC.01.31-1N-0001
    BBJCONN(步步精)
    USB16_C_11R24X6R5_TM
    USB连接器 TYPE-C USB16_C_11R24X6R5_TM
UC.01.31-1N-0001 数据手册
1 2 3 4 5 6 7 REV. 1 0.20±0.05 6.50 3.20±0.10 0.50±0.20 3.60±0.15 4.45±0.10 3 1 5 B 2 4 0.50 2.50 5.50 +0.045 2.10±0.05 B1 11.24±0.1 B6 2-1.20±0.05 B7 B8 B9 B1 2.10 A12 2-0.80±0.05 4.00±0.05 A9 A8 A7 REF2.05 A 100VAC MIN. 1.4.LOW CONTACT RESISTANCE: Ω MAX. Ω MAX. AFTER 50m INITIAL 40m 2. MECHANICAL CHARACTERISTICS: 2.1.INSERTION FORCE:5N~20N. 2.2.EXTRACTION FORCE: 8N~20N FORM 1 TO 1000CYCLES. 6N~20N FORM 1001 TO 10000CYCLES. 2.3.DURABILITY:10,000 MATING CYCLES 2.4.OPERATING TEMPERATURE:-55°C TO +85°C 3. COPLANARITY:0.10MAX. 4.ROHS REACHER. CH0.52 2.56±0.04 D B1 B5 B4 2.10±0.05 A12 ref 3.16 C +0.15 0.70-0 1.20±0.05 0.73±0.05 6.69-0.055 8.94 DATE JACKSON 2021.01.15 NOTES: 1.ELECTRICAL: 1.1.CONTACT CURRENT RATING 5.0A FOR VBUS AND GND(PINS A4 A9 B4 B9) 1.2. INSULATION RESISTANCE: 100 MEGAOHMS MIN. AT 250VDC. 1.3.DIELECTRIC WITHSTANDING VOLTAGE: A A1 8 NAME DESCRIPTION A4 A5 B C B12 A1 D A6 REF4.55 E E MATING INTERFACE TOLERANCE UNSPECIFIED . .0 ±0.35 .00 ±0.25 .000 ±0.15 X.° ±2.00° CUSTOMER DRAWING 0.50±0.05 1.50±0.05 2.50±0.05 3.50±0.05 F 4.55±0.05 5.05±0.05 6.15±0.05 6.65±0.05 1 2 3 4 深圳市步步精科技有限公司 TITLE: TYPE-C 16P 母座L=6.5沉板2.1 DRAWN/ DATE LXF CHECKED/ DATE LYX SCALE: 1:1 APPROVED/ DATE LJP DWG. 5 SIZE:A4 6 UNIT:MM. PART.NO: (CH=0.52mm) F UC.01.31-1N-0001 REV.: PROJECTION 9999-9 PATH 7 版本 SHEET: 页码 8 2 1 3 4 5 6 7 REV. 8 NAME DESCRIPTION 1 DATE 2021.01.14 JACKSON A A 6.40 4.80 3.50 2.50 1.50 0.50 B B A6 B7 A7 B6 A8 B5 A9 B4 A12 B1 C 2.10 A5 4.00 4.60 5.70 B12 A1 B9 A4 B8 C 9.24 11.24 D D RECOMMEND P.C.B LAYOUT(COMPONENT SIDE) TOLERANCE FOR PCB LAYOUT IS ± 0.05 TABLE E ITEM PART NAME F E REMARK QTY MATERIAL 1 SHELL 1PCS STAINLESS NICKEL PLATED 50u'' MIN. OVER ALL 2 INSERT HOUSING 1PCS LCP UL94V-0 3 Mid-PLATE 1PCS STAINLESS 4 TOP CONTACT COPPER ALLOY 5 BOTTOM CONTACT 1 1SET 1SET COPPER ALLOY 2 NI PLATED 50u'' MIN. OVER ALL TOLERANCE UNSPECIFIED . .0 ±0.35 .00 ±0.25 .000 ±0.15 X.° ±2.00° CUSTOMER DRAWING 深圳市步步精科技有限公司 TITLE: TYPE-C 16P 母座L=6.5沉板2.1(CH=0.52mm) NICKEL PLATED 50u'' MIN OVER ALL. DRAWN/ DATE LXF Au 1u''ON CONTACT AREA. CHECKED/ DATE LYX SCALE: 1:1 APPROVED/ DATE LJP DWG. GOLD FLASH PLATING ON SOLDER AREA 3 4 5 SIZE:A4 6 UNIT:MM. PART.NO: F UC.01.31-1N-0001 REV.: PROJECTION PATH 9999-9 7 版本 SHEET: 页码 8 2 1 3 4 5 6 7 REV. 堤蹋源砃 DATE A B B W 105.0 330 F E A NAME JACKSON 2021.01.15 1 P P0 P2 PULL OUT DIRECTEON 8 DESCRIPTION 3 ∅1 .5 C C 16.0 NOTES BOX LABEL 1.帶子引導長度 LEAD TAPE LENGTH 出料方向 PULL OUT DIRECTEON 堤蹋源砃 PULL OUT DIRECTEON D D 1 CARTON =10 REELS =10000 PCS 1000PCS产品 后空5PCS E 前空5PCS E 2.上帶 剝力力為:0.1~1.3N(10.2gf~130gf) PEELING OFF FORCE OF TOP TAPE:0.1~1.3N(10.2gf~130gf) 出貨'運輸過程中一定注意: THIS REQUIREMENT SHOULD BE APPLIED AT SHIPMENT: 卷帶在運輸過程中不能散開 PEELING OFF SHOULD NOT BE ALLOWED DURING TRANSPORTATION (The detail of the packing) Carton F 包裝明細表 包裝容量(Packing Capacity) 產品料號 (Product No.) pcs/box boxs/Carton Pcs/Box 1000 1 重量 N.W./Pcs ---- 10000 2 3 TOLERANCE UNSPECIFIED . .0 ±0.35 .00 ±0.25 .000 ±0.15 X.° ±2.00° CUSTOMER DRAWING Weight (Kg) N.W./Box G.W./Box ---- ---- 4 深圳市步步精科技有限公司 TITLE: TYPE-C 16P 母座L=6.5沉板2.1(CH=0.52mm) DRAWN/ DATE LXF CHECKED/ DATE LYX SCALE: 1:1 APPROVED/ DATE LJP DWG. 5 SIZE:A4 6 UNIT:MM. PART.NO: F UC.01.31-1N-0001 PROJECTION REV.: 9999-9 PATH 7 1 SHEET: 3/3 8
UC.01.31-1N-0001 价格&库存
很抱歉,暂时无法提供与“UC.01.31-1N-0001”相匹配的价格&库存,您可以联系我们找货
