UC.01.72-46-0005
UC.01.72-46-0005
    BBJCONN(步步精)
    USB连接器 Type-C 24Pin
UC.01.72-46-0005 数据手册
1 2 3 4 6 5 7 8 REV. ECN. NO. C 新增规格 D 新增规格 NAME DATE A A B B C C D D E E TOLERANCE UNSPECIFIED . ±0.50 .0 ±0.35 .00 ±0.25 .000 ±0.15 ANGLE ±3.00° CUSTOMER DRAWING F 1 2 3 4 深圳市步步精科技有限公司 TITLE: TYPE-C 24P 母座 夹板式0.8 H=8.8 DRAWN BY: HMY CHECKED BY: LYX SCALE: 1:1 APPROVED BY: LJP DWG . PATH 5 SIZE:A4 6 F UC.01.72-46-0005 UNIT:mm. PART NO. REV.: D PROJECTION 0285-1 7 SHEET:1/3 8 1 2 3 4 5 7 6 8 USB TYPE-C FULL-FEATURED RECEPTACLE INTERFACE PIN ASSIGNMENTS A A B PIN Signal Name A1 GND Description PIN Signal Name B12 GND Ground return Description Ground return A2 Positive half of firs t SSTXp1 SuperSpeed TX B11 differential pair Positive half of firs t SSRXp1 SuperSpeed RX differential pair A3 Negative half of SSTXn1 first SuperSpeed TX differential pair Negative half of SSRXn1 first SuperSpeed RX differential pair B10 A4 VBUS Bus Power B9 VBUS Bus Power A5 CC1 Configuration Channel B8 SBU2 Sideband Use (SBU) B7 Dn2 A6 Dp1 A7 Dn1 A8 SBU1 A9 VBUS Positive half of the USB 2.0 differential pair-Position 1 Negative half of the USB 2.0 differential pair-Position 1 Negative half of the USB 2.0 differential pair-Position 2 B6 Dp2 Sideband Use(SBU) B5 CC2 Configuraation Channel Bus Power B4 VBUS Bus Power A10 B3 Negative half of SSTXn2 second SuperSpeed TX differential pair A11 Positive half of SSRXp2 second SuperSpeed RX differential pair B2 Positive half of SSTXp2 second SuperSpeed TX differential pair GND B1 Ground return GND C Positive half of the USB 2.0 differential pair-Position 2 Negative half of SSRXn2 second SuperSpeed RX differential pair A12 B D Ground return E E TOLERANCE UNSPECIFIED . ±0.50 .0 ±0.35 .00 ±0.25 .000 ±0.15 ANGLE ±3.00° CUSTOMER DRAWING F 1 2 3 4 深圳市步步精科技有限公司 TITLE: TYPE-C 24P 母座 夹板式0.8 H=8.8 DRAWN BY: HMY CHECKED BY: LYX SCALE: 1:1 APPROVED BY: LJP DWG . PATH 5 SIZE:A4 6 F UNIT:mm. PART NO. UC.01.72-46-0005 PROJECTION REV.: D 0285-1 SHEET:2/3 7 8 2 1 3 4 7 8 三. 一. A 6 5 將成品依同一方向放入真空盤內,如圖所示. 1).將標籤貼於紙箱側麥上方. At same direction, put product onto the tray. Direction refers to below drawing. Stick the needful label On the up-right corner of the side of carton. A 標籤黏貼處 Location of Sticking lable B B VIEW-1 二. 1) 一只紙箱可放置之包裝盤(包括上蓋)見下表. 1) trays per carton,please see next table. 2).每1個紙箱用的包裝數量詳見下表。 2)The Q'ty of products per carton please see next tabel. 註(REMARK) 備 3) 將裝滿成品的真空盤用 PE帶捆緊後放在塑膠袋內(10盘一捆), 裝完後再封箱。 若有未裝滿之零數箱 必須以緩衝材塞滿 The unfilling-carton must be filled with assuagement. 3) Bind the trays with PE tape and then( a bundle of 10 trays ),put them into the poly bag. Seal the carton with tape. 2. 防水袋需用膠帶貼實且封口. 緩衝材 (珍珠棉) Cushion waterproof plastic bag must be folded up. About the box fully filled with products, the MAX accumulating quantity of boxes is 5. 4. 如須貼Bar-code,請依Bar-code作業辦法執行 防水袋 If barcode lable is required,do it according to the related barcode lable operation standards. Water proof bag 緩衝材 (珍珠棉) E Cushion 紙箱 Carton F TOLERANCE UNSPECIFIED . ±0.50 .0 ±0.35 .00 ±0.25 .000 ±0.15 ANGLE ±3.00° CUSTOMER DRAWING 包裝明細表 包裝容量 產品料號 重量 60 100 1 2 D 3. 裝滿成品后之外箱,最大堆積箱數:5箱 真空盤 Tray E C 6000 3 4 深圳市步步精科技有限公司 TITLE: TYPE-C 24P 母座 夹板式0.8 H=8.8 DRAWN BY: HMY CHECKED BY: LYX SCALE: 1:1 APPROVED BY: LJP DWG . PATH 5 SIZE:A4 6 F UNIT:mm. PART NO. UC.01.72-46-0005 PROJECTION REV.: D 0285-1 SHEET:3/3 7 8
UC.01.72-46-0005 价格&库存
很抱歉,暂时无法提供与“UC.01.72-46-0005”相匹配的价格&库存,您可以联系我们找货
