XYEBCLNANF-24MHz
XYEBCLNANF-24MHz
    TAITIEN(泰艺)
    SMD2520_4P
    无源晶振 80Ω 24MHz 15pF ±10ppm -40℃~+85℃ SMD2520_4P
XYEBCLNANF-24MHz 数据手册
XY Type 2.5 x 2.0 mm SMD Crystal Actual Size FEATURE - Typical 2.5 x 2.0 x 0.45 mm ultra thin ceramic package. - 8 mm width Tape & Reel package for automatic assembly. - Tight tolerance 10 ppm available. T YPICAL APPLICATION - Bluetooth , Mobile phone, Wireless LAN. - Office Automation - Audio & Video RoHS Compliant XY DIMENSION (mm) SOLDER PAD L AYOUT (mm) [ TOP VIEW ] 2.55±0.20 GND #4 #3 2.05±0.20 1.62 #1 GND #3 1.60 1.10 0.55±0.10 #4 #2 #2 and #4 are connected to the cover (please connect to ground) #2 1.25±0.10 [ BOTTOM VIEW ] 1.62±0.10 #1 0.45±0.10 [ SIDE VIEW ] 1.20 0.72±0.10 ELECTRICAL SPECIFICATION Parameter Min. Storage Temp. Range Standard Frequency Level of Drive Shunt Capacitance (Co) Insulation Resistance Aging Typical -40 500 MΩ@ DC100V Max. 16, 24, 26, 40 10 ±1.0 to ± 3.0 Unit 125 MHz µw pF 200 3.0 - ppm / year Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. EQUIVALENT SERIES RESISTANCE (E. S. R.) Frequency Range 12 MHz Fo < 20 MHz 20 MHz Fo 30 MHz 30 MHz < Fo 54 MHz FREQ. STABILITY vs. TEMP. RANGE o Temp. ( C) ppm ±5 ±10 MODE E.S.R A1 A1 A1
XYEBCLNANF-24MHz
物料型号:XY Type 2.5 x 2.0 mm SMD Crystal
器件简介:该晶体振荡器具有2.5 x 2.0 x 0.45 mm的超薄陶瓷封装,8 mm宽度的胶带和卷轴包装,适用于自动组装。可提供10 ppm的紧密容差。
引脚分配:文档中提到#2和#4引脚连接到外壳(请连接到地)。
参数特性: - 存储温度范围:-40°C至125°C - 标准频率:16.24 MHz或26.40 MHz - 驱动电平:10 mW至200 mW - 并联电容(Co):3.0 pF - 绝缘电阻:500MΩ @ DC100V - 老化率:±1.0至±3.0 ppm/年
功能详解:文档中提到了等效串联电阻(E.S.R.)的值,以及频率稳定性与温度范围的关系。
应用信息:适用于蓝牙、手机、无线局域网、办公自动化、音频和视频设备。
封装信息:符合RoHS标准的2.55±0.20 mm x 2.05±0.20 mm尺寸,以及1.62±0.10 mm至0.72±0.10 mm的厚度。
XYEBCLNANF-24MHz 价格&库存
很抱歉,暂时无法提供与“XYEBCLNANF-24MHz”相匹配的价格&库存,您可以联系我们找货
XYEBCLNANF-24MHz
  • 1+0.79793
  • 30+0.76944
  • 100+0.74094
  • 500+0.68394
  • 1000+0.65544
  • 2000+0.63835
库存:900
