XZCBBCNANF-32.000000
    TAITIEN(泰艺)
    SMD2016_4P
    无源晶振 32MHz ±10ppm 10pF 80Ω -20℃~+70℃
XZCBBCNANF-32.000000 数据手册
XZ Type 2.0 x 1.6 mm SMD Crystal Actual Size FEATURE - Typical 2.05 x 1.65 x 0.45 mm ultra thin ceramic package. - 8 mm width Tape & Reel package for automatic assembly. - Tight tolerance 10 ppm available. T YPICAL APPLICATION - Bluetooth , Mobile phone, Wireless LAN. - Office Automation - Audio & Video [ TOP VIEW ] 2.05±0.10 GND #4 RoHS Compliant #3 1.65±0.10 1.40 #1 [ BOTTON VIEW ] 1.27±0.10 GND 1.10 #2 0.97±0.10 #1 #2 #2 and #4 are connected to the cover (please connect to ground) 0.80 0.45±0.10 [ SIDE VIEW] #4 0.47±0.10 0.90 #3 0.57±0.10 Parameter Storage Temp. Range Standard Frequency Level of Drive Shunt Capacitance (Co) Insulation Resistance Aging Min. Typical Max. -55 26, 30, 32, 40 10 ±1.0 to ±3.0 125 500 MΩ@ DC100V Unit MHz µw pF 200 3.0 - ppm / year Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. Frequency Range 16 MHz Fo 20 MHz < Fo 30 MHz < Fo Temp. ( o C) ppm 20 MHz 30 MHz 60 MHz ±5 ±10 MODE E.S.R A1 A1 A1
XZCBBCNANF-32.000000 价格&库存
很抱歉,暂时无法提供与“XZCBBCNANF-32.000000”相匹配的价格&库存,您可以联系我们找货
  • 3000+3.194313000+0.41327
  • 6000+3.062266000+0.39619
  • 9000+2.987629000+0.38653
  • 15000+2.8962115000+0.37471
  • 21000+2.8375521000+0.36712
  • 30000+2.7767030000+0.35924
库存:2985
  • 1+5.216311+0.67487
  • 10+4.5257910+0.58554
  • 25+4.2748125+0.55306
  • 50+4.0999350+0.53044
  • 100+3.93008100+0.50846
  • 250+3.71654250+0.48084
  • 500+3.56291500+0.46096
  • 1000+3.415471000+0.44189
库存:2985
