CVS-03TB
CVS-03TB
    NIDEC(尼得科)
    SMD,P=1mm
    拨码开关 SMD,P=1mm 单刀单掷 6V
CVS-03TB 数据手册
SLIDE SWITCHES (1 mm PITCH) RoHS compliant CVS INTERNAL STRUCTURE ③ ① ② ⑦ ⑤ ④ ⑥ Part name Material Flammability — ■ FEATURES ① Cover Stainless steel, Gold-plated ● RoHS compliant ● Lowest profile design of 1.45 mm ● Fine pitch of 1 mm ● Easy motion with knob height of 0.2 mm ② Slider Polyamide ③ Housing ④ Slider contact ⑤ Fixed contact ⑥ Terminal pin ⑦ Earth terminal UL94V-0 Polyphenylenesulphide Stainless steel, Gold-plated Copper alloy, Gold-plated — Stainless steel, Gold-plated ■ PART NUMBER DESIGNATION C V S - 0 4 T B - 1 Taping Series name 1:500 pcs./reel Blank:2000 pcs./reel No. of bits 01:1 bit 02:2 bits 03:3 bits Shape of terminal 04:4 bits 08:8 bits B:Gull wing C:Through hole Form of packaging T :Taping (Reel) Blank : Bulk in plastic bag (01C : Plastic bag only) ■ LIST OF PART NUMBERS No. of bits Form of packaging Shape of terminals Taping 1 Taping Plastic bag Taping 2 Taping Plastic bag Taping 3 Taping Plastic bag (Gull wing) (Through hole) Pieces in package CVS-01TB-1 CVS-01TB CVS-01B CVS-01C CVS-02TB-1 CVS-02TB CVS-02B CVS-03TB-1 CVS-03TB CVS-03B No. of bits Form of packaging Shape of terminals 500 pcs./reel 2000 pcs./reel Taping 4 Taping 100 pcs./pack Plastic bag 500 pcs./reel Taping 2000 pcs./reel 100 pcs./pack 500 pcs./reel 2000 pcs./reel 100 pcs./pack 8 Taping Plastic bag (Gull wing) CVS-04TB-1 CVS-04TB CVS-04B CVS-08TB-1 CVS-08TB CVS-08B (Through hole) Pieces in package 500 pcs./reel 2000 pcs./reel 100 pcs./pack 500 pcs./reel 2000 pcs./reel 100 pcs./pack CVS SLIDE SWITCHES (1 mm PITCH) ■ STANDARD SPECIFICATIONS ■ ELECTRICAL CHARACTERISTICS Operating temp. range Contact rating Non-switching Switching Minimum − 40 ~ 85 °C Storage temp. range Sealing Net weight Non-washable Contact resistance Approx. 0.028g (CVS-01B) Approx. 0.031g (CVS-01C) Approx. 0.041g (CVS-02B) Approx. 0.054g (CVS-03B) Approx. 0.067g (CVS-04B) Approx. 0.13 g (CVS-08B) Insulation resistance Dielectric strength ■ MECHANICAL CHARACTERISTICS Operating force Stop strength Solderability Soldering heat DC50 V 100 mA DC6 V, 100 mA DC24 V, 25 mA DC20 mV 1 μA 200 mΩ maximum 100 MΩ (DC100 V) minimum AC250 V, 60 s ■ ENVIRONMENTAL CHARACTERISTICS 3 N {0.306 kgf} maximum Vibration 6 N {0.61 kgf}, 60 s Shock 490 m/s2, 11 ms 6 directions for 3 times each Load life Continuous load 1000 cycles, DC6 ± 0.5 V, 100 ± 10 mA Humidity −10 ~ 65 °C, Relative humidty 0 ~ 96 %, 24 h for 10 cycles 245 ± 3 °C, 2 ~ 3 s Reflow:255 °C (Peak temperature) (Please refer to the profile below) Manual soldering:350 ± 10 °C, 3 ~ 4 s (Amplitude) 1.5 mm or (Acceleration) 98 m/s2, 10-500 Hz, 3 directions for 10 cycles each Shear (Adhesion) 5 N {0.51 kgf} 10 s High temp. exposure 85 °C, 96 h Substrate bending Width 90 mm, bend 3 mm, 5 s, 1 time Low temp. exposure − 40 °C, 96 h Pull-off strength Thermal shock 5 N {0.51 kgf} 10 s { } : Reference only Reflow profile for soldering heat evaluation〉 Temperature (℃) 250 200 150 100 50 Peak : 250 +5 0 ℃ Over 230 ℃ 180 ℃ 150 ℃ Pre Heating Zone 90 ± 30 s 30 ± 10 s Heating time Reflow : two times maximum Soldering Zone − 40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles CVS SLIDE SWITCHES (1 mm PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) Stroke 0.6 Production date code 0.3 min. 4.7 6.1 4.7 Production date code 0.15 +0.1 –0.05 1.45 0 0.1 –0.1 1.2 2 2 1.35 2 6.5 Stroke 0.6 0.15 +0.1 –0.05 ● CVS-01C 0.3 min. ● CVS-01B 0.5 +0.1 –0.05 Schematic Schematic 0.5 +0.1 –0.05 0.3 min. ● CVS- □□ B Part number 0.3 min. 6.1 4.7 Stroke 0.6 Production date code 0.15 +0.1 –0.05 No. of bits. L dimension CVS-02 2 3 CVS-03 3 4 CVS-04 4 5 CVS-08 8 9 1.45 L Schematic 1 0.15 ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS ● CVS-02B ● CVS-03B 1 1 0.7 2.2 0.7 3.2 0.7 4.7 0 0.7 0.7 0.7 1.2 0.5 0.7 1.2 4.7 0 1.2 0.7 1.2 0.7 3.6 1.2 1.4 0 4.7 3.6 0.7 0.7 0.5 0.7 0.7 1.2 1.2 4.7 0 1N (N=1~3) = 3 1 0.5 1.2 0.7 ● CVS-04B 3.6 ● CVS-01B (Unit : mm) 0.7 0.7 0.5 ● CVS-01C 0.7 1.2 6.5 0 3.6 4.7 1.2 1N (N=1~7) = 7 0.7 4.2 ■ SIZE OF P.C.B. PROCESSING ● CVS-08B 8.2 0.7 0.7 0.15 3.6 0 0.1 –0.1 0.35 +0.1 –0.05 1 2 – φ 0.7 hole 0.7 (Unit : mm) CVS SLIDE SWITCHES (1 mm PITCH) ■ PACKAGING SPECIFICATIONS ● Taping version is packaged in 2000 pcs. or 500 pcs. per reel. Orders will be accepted for units of 2000 pcs., i.e., 2000, 4000, 6000 pcs., etc. or for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc. ● Taping version is boxed with two reels. Maximum number of consecutive missing pieces = 2 Leader length and reel dimension are shown in the diagrams below: ●Embossed tape dimensions ●Reel dimensions Empty End φ 21±0.8 Head 40 mm min. 20 pitches min. Leader 400 mm min. Direction of feed φ 50 min. (2000 pcs/reel) φ 80±1 (500 pcs/reel) 17.4±1 2±0.5 φ 13±0.2 φ 254±2 (2000pcs./reel) φ 182±1 (500pcs./reel) 4 ± 0.1 2 ± 0.1 Direction of feed 0.3 ± 0.1 Installation example (CVS-02B) Direction of feed 2 4 ± 0.1 2 ± 0.1 Direction of feed 2 0.3 ± 0.1 Installation example (CVS-03B) 2 8 ± 0.1 1.75 ± 0.1 4 ± 0.1 φ 1.5 +0.1 0 0.3 ± 0.1 2 ± 0.1 (CVS-04B) Installation example 2 ● The smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs., etc. ON 12345678 ON 1234 Direction of feed 7.5 ± 0.1 2 ± 0.1 7.5 ± 0.1 4 ± 0.1 16 8 ± 0.1 φ 1.5 +0.1 0 1.75 ± 0.1 ● 8 bits Direction of feed 0.3 ± 0.1 (CVS-08B) Installation example 16 ● 4 bits 8 ± 0.1 φ 1.5 +0.1 0 7.5 ± 0.1 8 ± 0.1 φ 1.5 +0.1 0 7.5 ± 0.1 0.3 ± 0.1 Installation example (CVS-01B) 16 7.5 ± 0.1 2 ± 0.1 16 8 ± 0.1 4 ± 0.1 φ 1.5 +0.1 0 ● 3 bits 1.75 ± 0.1 ● 2 bits 1.75 ± 0.1 ● 1 bit 21.4±1 (2000pcs./reel) 20.4±1 (500pcs./reel) 1.75 ± 0.1 Filled 16 Empty (Unit: mm) (Conforms to JIS C 0806-3) (In accordance with EIAJ ET-7200A) 2 ● Boxing of bulk in a plastic bag is performed with 100 pcs. (standard 500 pcs.) per box.
CVS-03TB 价格&库存
很抱歉,暂时无法提供与“CVS-03TB”相匹配的价格&库存,您可以联系我们找货
CVS-03TB
    • 1+12.59280
    • 10+10.74600
    • 30+9.60120
    • 100+8.41320
    • 500+7.88400
    • 1000+7.65720
    CVS-03TB
    • 1+24.793721+3.20773
    • 10+20.7963210+2.69056
    • 25+19.2821525+2.49466
    • 100+17.17586100+2.22216
    • 250+15.94374250+2.06275
    • 500+15.10533500+1.95428
    • 1000+14.349821000+1.85654
    库存:31214
    CVS-03TB
    • 2000+13.675662000+1.76931
    • 4000+13.079594000+1.69220
    • 6000+12.765136000+1.65151
    库存:31214
