CL-SB
SLIDE SWITCHES
CL-SB内部構造図.eps
RoHS compliant
INTERNAL STRUCTURE
2
3
1
6
4
5
Part name
Material
Flammability
①
Cover
Stainless steel (SUS 304)
■ FEATURES
②
Slider
Polyamido
UL94V-0
● Wide variety
(circuit composition, operating direction, terminal shape:
J-hook, Gull wing, Through hole pins)
● Standardization of the silver contacts as well as gold
contacts
● Stroke is 2mm
● Using heat-resistant resin to support reflow soldering
mounting
● Adopted Twin-contacts mechanism
③
Housing
Polyphenylenesulphide
UL94V-0
④
Moving contact
Copper alloy, gold or silver plate
⑤
Fixed contact
⑥
Terminal pin
■ PART NUMBER DESIGNATION
CL - SB - 2 3 B - 0 2 T
Series name
No. of poles
1:1 pole
2:2 poles
Form of packaging
T : Taping
Blank : Bulk in plastic bag
Contact material
No. of positions
1:Silver
2:Gold
2:2 positions
3:3 positions
Setting position
Shape of terminal
A:J-hook
B:Gull wing
C:Through hole pins
※ Please refer to the LIST OF PART NUMBERS when placing orders.
0:Top setting
1:Side setting
CL-SB
SLIDE SWITCHES
■LIST OF PART NUMBERS
Setting position
No. of
poles
No. of
positions
2
1
3
Top setting
2
2
3
2
1
3
Side setting
2
2
3
Contact material
Silver
Gold
CL-SB-12A-01T
CL-SB-12A-02T
CL-SB-12A-01
CL-SB-12A-02
CL-SB-12B-01T
CL-SB-12B-02T
CL-SB-12B-01
CL-SB-12B-02
CL-SB-12C-01
CL-SB-12C-02
CL-SB-13A-01T
CL-SB-13A-02T
CL-SB-13A-01
CL-SB-13A-02
CL-SB-13B-01T
CL-SB-13B-02T
CL-SB-13B-01
CL-SB-13B-02
CL-SB-13C-01
CL-SB-13C-02
CL-SB-22A-01T
CL-SB-22A-02T
CL-SB-22A-01
CL-SB-22A-02
CL-SB-22B-01T
CL-SB-22B-02T
CL-SB-22B-01
CL-SB-22B-02
CL-SB-22C-01
CL-SB-22C-02
CL-SB-23A-01T
CL-SB-23A-02T
CL-SB-23A-01
CL-SB-23A-02
CL-SB-23B-01T
CL-SB-23B-02T
CL-SB-23B-01
CL-SB-23B-02
CL-SB-23C-01
CL-SB-23C-02
CL-SB-12A-11T
CL-SB-12A-12T
CL-SB-12A-11
CL-SB-12A-12
CL-SB-12B-11T
CL-SB-12B-12T
CL-SB-12B-11
CL-SB-12B-12
CL-SB-12C-11
CL-SB-12C-12
CL-SB-13A-11T
CL-SB-13A-12T
CL-SB-13A-11
CL-SB-13A-12
CL-SB-13B-11T
CL-SB-13B-12T
CL-SB-13B-11
CL-SB-13B-12
CL-SB-13C-11
CL-SB-13C-12
CL-SB-22A-11T
CL-SB-22A-12T
CL-SB-22A-11
CL-SB-22A-12
CL-SB-22B-11T
CL-SB-22B-12T
CL-SB-22B-11
CL-SB-22B-12
CL-SB-22C-11
CL-SB-22C-12
CL-SB-23A-11T
CL-SB-23A-12T
CL-SB-23A-11
CL-SB-23A-12
CL-SB-23B-11T
CL-SB-23B-12T
CL-SB-23B-11
CL-SB-23B-12
CL-SB-23C-11
CL-SB-23C-12
※Verify the above part numbers when placing orders.
Taping version can be supplied only in reel unit.
Shape of terminal
A(J-hook)
B(Gull wing)
C(Through hole pins)
A(J-hook)
B(Gull wing)
A(J-hook)
B(Gull wing)
A(J-hook)
B(Gull wing)
A(J-hook)
B(Gull wing)
A(J-hook)
B(Gull wing)
A(J-hook)
B(Gull wing)
A(J-hook)
B(Gull wing)
Form of packaging
Pieces in package
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Taping
500pcs. / reel
Plastic bag
50pcs. / pack
Plastic bag
50pcs. / pack
CL-SB
SLIDE SWITCHES
■ STANDARD SPECIFICATIONS
Operating temperature range
■ ELECTRICAL CHARACTERISTICS
Contact rating
Non-switching
Switching
Minimum
− 40 ~ 85 °C
Storage temperature range
Sealing
Non- Washable
0.21 g (CL-SB-12*-0*)
0.22 g (CL-SB-22*-0*)
0.26 g (CL-SB-13*-0*)
0.28 g (CL-SB-23*-0*)
Net weight
DC50 V 200 mA
DC12 V 200 mA
DC20 mV 1 μ A (Gold contacts)
DC5 V 10 mA (Silver contacts)
0.21 g (CL-SB-12*-1*)
0.23 g (CL-SB-22*-1*)
0.27 g (CL-SB-13*-1*)
0.29 g (CL-SB-23*-1*)
Contact timing
Non-shorting
70m Ω maximum
(Gold contacts)
50m Ω maximum
(Silver contacts)
Contact resistance
■ MECHANICAL CHARACTERISTICS
100 M Ω minimum (DC500 V)
Insulation resistance
No. of positions
2, 3
Stroke
Operation force
Stop strength
Solderability
■ ENVIRONMENTAL CHARACTERISTICS
A → B / C → B ※ 2
3 Contacts
1.5 ± 1.0 N {0.153 ± 0.102kgf}
(CL-SB-*3*-**) B → A / B → C
2.5 ± 1.5 N {0.255 ± 0.153kgf}
20 N {2.04 kgf} 15 s
245 ± 3 °C, 2 ~ 3 s
(Please refer to the profile below)
Soldering heat
Substrate bending
Pull-off strength
Load life
10000 cycles,
DC12 ± 0.5V, 200 ± 10mA
Humidity
40 °C, Relative humidity 90 ~ 95 %,
240 h, No load
85 °C, 96 h, No load
Manual soldering:350 ± 10 °C, 3 ~ 4 s
Low temperature exposure
− 40 °C, 96 h, No load
Width 90 mm, bend 3 mm, 5 s, 1 time
※1
A B
5 N {0.51 kgf} 10s
Thermal shock
※ 2 ※2
− 40 (0.5 h) ~ 85 °C ( 0.5 h ), 5 cycles
〈Reflow profile for soldering heat evaluation〉
250
Peak : 250
200
150
100
50
+5
Over 230 ℃
A B C
Temperature
A B C
490 m/s2, 11 ms
6 directions for 3 times each
High temperature exposure
{ } : Reference only
A B
Shock
Flow : 260 ± 3 °C, 5 ~ 6 s
5 N {0.51 kgf} 10 s
Shear
(Amplitude) 1.5 mmor
(Acceleration) 98 m/s2,
10-500-10 Hz, 3 directions for 2 h each
Vibration
Reflow:255 °C (Peak temperature)
※2
AC500 V, 60 s
Dielectric strength
2 mm
2 Contacts
A ⇔ B ※ 1
(CL-SB-*2*-**) 1.5 ± 1.0 N {0.153 ± 0.102kgf}
※ 1 ※1
1.5 mA 1 kHz
20 mV maximum
180 ℃
150 ℃
Pre Heating Zone
90 ± 30 s
30 ± 10 s
Heating time
Reflow : two times maximum
Soldering Zone
4_5-6p
4_5-6p
4_5-6p
CL-SB
SLIDE SWITCHES
■ OUTLINE DIMESIONS
Unless otherwise specified, tolerance: ± 0.3 (Unit: mm)
● CL-SB-12B-01
● CL-SB-12B-02
● CL-SB-12A-01
● CL-SB-12A-02
8.5
● CL-SB-12C-01
● CL-SB-12C-02
8.5
8.5
1
3
1.5
CO.2
0.6
2.5
2.5
CO.2
1
φ 0.8
8.5
4
5
6
2
3
1
Travel
c
Production date code1
8.5
Travel
c
5
2
1
2
c
5
3.5
3.5
3.5
2
c
5
1.5
1.5
3.5
0.25
3.5
3.3
1.5
0.25
2
0.6
2.5
2.5
0.6
2.5
0.25
3.3
2
5
6
1.5
0.4min
2.5
0.6
2.5
0.4min
2.5
0.6
2.5
0.4min
0.4min
2.5 1.5 2.5
0.4min
2.5
2.5
2.5
2.5
4
1
0.4min
4
c
5
6
2
3
c
Terminal No.①
3
c
Schematic
1.5
2
0.6
2.5
1.5
3.3
2.5
0.6
2.5
3.3
2.5
0.6
2.5
3.3
8.5
0.25
0.25
4
c
5
4
4
2
2
2
c
5
3
6
1.5
4
8.5
2
Travel
6
3
c
c
5
6
1
2
3
2
4
3.5
1
Travel
1.5
2
c
c
Schematic
3
3.5 c
Schematic
5
2
1 2
1.5
c
Schematic
8.5
6
c
Schematic
Travel
0.25
1
Schematic
Travel
2
c
2.5
1.5
6
Production date
code
1 2 3
Travel
Terminal No.①
5
c
Schematic
4 5 6
1.5
Travel
Terminal No.①
c
2
1.5
6
3
c
4
2
8.5
1.5
5
2
Schematic
● CL-SB-22C-01
8.5
● CL-SB-22C-02
Travel
Schematic
Travel
2 0.6
2.5 2.5
c
1
3
c
0.25
3.3
8.5
6
1
3.5
3
3
6
3
Terminal No.①
1.5
8.5
6
3
3.5
2
2.5
0.25
3.5 3
2.5
0.4min
1 2code
3
Production date
c
3
25
1.5
5
2
c
4
8.5
6
Schematic
Travel
Terminal No.①
Production
2 date code
3.5 c
1.5
c
1
c
Schematic
4
0.4min
c
Schematic
8.5
Schematic
4
1
3
0.25
Terminal No.①
c
Terminal No.①
1.5
Terminal No.①
1
8.5
2.5
1.5
1.5
2.5
4
5
0.6
2.5
2.5
0.4min
Schematic
2
2
2.5
2.5
4
Travel
3.5
1.5
0.25
0.6
2.5
3.5
CO.2 0.4min
2 3.5
2
2.5
2
3
0.6
2.5
6.8
8.5
2
Terminal No.①
1.5
1.5
1.5
3
Schematic
3.5
2.5
3.5
2
0.25
1.5date code
Production
3.5
Schematic
2
3.5
1.5
1.5
2
c
3.5
2 date code
Production
Travel
2 0.6
2.5
2.5
1.5
3.5
6
2.5
0.25
1.5
2.5
1.5
φ 0.8
Travel
2
2
3
5
1
Schematic
Schematic
1.5
3.5
3.5
2
c
2
CO.2 0.4min
6.8
3.5
2.5
φ 0.8
8.5
● CL-SB-22B-01
● CL-SB-22B-02
c
Schematic
4
2
CO.2 0.4min
1
1
0.6
2.5
8.5
6
0.25
3.3
c code
Production date
32
5
1.5
3
2 3.5
c
0.6
8.5Travel
2
3.5 3
c
2
3.5
6
3
Travel
2.5
3.5
2.5
1
2 Schematic
3.5
1 date
2 3 code
Production
3.5
2
3.5
2.5
0.25
3.3
c
0.25
4
2 3.5
3.5
2.5
8.5
0.6
Production1date
2 code
3
c
Production date
code
0.6
2.5 2.5
Travel
6.8
2
0.8
5
2
Schematic
Travel
2 0.6
Terminal No.①
1.5 2.5 2.5
.5
2.5
0.25
3.3
● CL-SB-12C-11
● CL-SB-12C-12
3
0.25
3.5
3.5
c
Travel
3.5
4
Travel
Terminal No.①
Terminal No.①
φ 0.8
Terminal No.①
φ 0.8
c
Terminal No.①
2.5
1.5
0.6
8.5
1.5
1.5
1
1.5
Terminal No.①
Terminal No.①
Schematic
2.5
CO.2
φ 0.8
Travel
8.5
2
3.5
0.8
1.5
8.5
● CL-SB-22A-01
● CL-SB-22A-02
1.5
3.5
CO.2
φ 0.8
8.5
Terminal No.①
φ 0.8
2
3.5
6.8
0.25
3.5
0.25
2.5
1.5
1.5
1.5
3.5
0.8
0.6
2.5
1.5
0.8
3.5
2
2
1.5
0.25
2.5
2
2.5
0.6
2.5
1.5
3
1.5
3.5
0.8
3.5
0.8
2
c
0.6
CO.2
2.5 2.5
Travel
φ 0.8
26.8
2.5
φ 0.8
2.5
Schematic
8.5
1
6.8
Terminal No.①
2.5
c
2Schematic
3.5
Production
date code
2
2.5
Terminal No.①
2 code
3
Production 1date
Travel
Travel
φ 0.8
2
c
3 2
20.8 3.5
● CL-SB-12B-11
● CL-SB-12B-12
3
2
1.5
2.5
2
c
Travel
8.5
1.5
Terminal No.①
0.4min
2.5
1.5
1.5
2.5
1
Schematic
2
1.5
2
0.4min
Schematic
φ 0.8
2.5
2.5
2 3
Production 1date
c code
Terminal No.①
0.4min
2.5
φ 0.8
6.8
8.5
1.5
0.25
0.4min
8.5
8.5
● CL-SB-12A-11
● CL-SB-12A-12
8.5
0.4min
2.51.5 2.5
φ 0.8
6.8
Terminal No.①
φ 0.8
0.4min
Schematic
Travel
2
2 3.5
2
3.5
CO.2
φ 0.8
0.6
2.5
2.5
1.5
1.5
6.8
Terminal No.①
φ 0.8
3
c
5
6
2
3
c
Schematic
2.5
2.5
1.5
CO.2
φ 0.8
0.25
Terminal No.①
φ 0.8
0.6
2.5
CO.2
φ 0.8
Travel
0.6
Terminal No.①
2.5 2 2.5
φ 0.8 1.5
6.8
.25
3.5
0.8
6.8
1.5
1.5
0.8
2 3.5
0.6
2.5
2.5
CO.2
φ 0.8
1.5
3.5
Terminal No.①
φ 0.8
Schematic
1.5
1.5
2
c
2 3 code
Production1 date
Travel
0.8
0.8
2 3.5
Travel
0.6
Terminal No.①
2.5 2 2.5
φ 0.8 1.5
6.8
0.25
Production date1.5
code
1.5
3
2
0.25
1.5
2
c
Schematic
Travel
1
1
Schematic
2
8.5
3.5 3
1.5
3
3
3.5
1.5
1 2 3
Production
date
code
c
2
c
Travel
Schematic
Travel
2
8.5
0.25
3.5
20.8 3.5 3.5 2
Schematic
2
8.5
1 2date
3 code
Production
c
c
1.5
1
Schematic
8.5
Production
date code
1 2 3
Travel
28.5
3
3.5
3.5
3.5
8.5
2
c
Schematic
0.25
2
c
0.25
1
Schematic
2 date code
3.5
Production
3.5
1
5
6
2
3
c
8.5
1
Schematic
CL-SB
5
6
2
3
c
1
2
2
1.5
1.5
1.5
c
1.5
Terminal No.①
1.5
0.6
2.5
2.5
0.4min
0.4min
2.5
■ OUTLINE DIMESIONS
c
4
1
5
6
2
3
c
● CL-SB-22C-11
● CL-SB-22C-12
8.5
1
1.5
3
Terminal No.①
0.6
2.5
2.5
12
1 2
2
1.5
Travel
2
3.5
2
1.5
Travel
c
1 2
2
Schematic
c
1 2
3.5
3.5
3
2
0.25
0.4min
2.5
c
2
3.5
1 2
1.5
2
3
Terminal No.①
c
c
7 8
φ 0.8
2
2
5
12
C0.2
0.4min
1 2
c
2.5
2.5
c
2
c
1 2
3 4
c
1.5
3
2
2
2
0.6
2
Terminal No.①
2
2
2
2
12
c
3 4
3.5
3.3
0.6
3.3
5 6
c
c
7 8
3 4
Schematic
12
7 8
Schematic
2
Terminal No.①
2
1 2
Schematic
5 6
0.4min
2
1.5
7 8
Travel
1.5
0.4min
2.5
1 2
3 4
3 4
Production
2 date code
3.5
3.5
2.5
2
1.5
3.5
5 6
12
2
3 4
0.25
3
0.6
0.4min
2.5
5
3.5
1.5
2.5
2
C0.2
2
1.5
3.5
0.8
3.5
φ 0.8
3 4
Schematic
5 6
φ 0.8
2
7 8
ProductionSchematic
date code
2
1.5
c
1 2
Travel
2
c
2
2
1.5
5
5 6
12
0.8
2.5
C0.2
2
3
Terminal No.①
c
1 2
Schematic
Travel
3.5
12
φ 0.8
2
φ 0.8
0.25
3.3
Travel
2
1.5
Travel
5 6
c
7 8
Travel
3.5
2
1.5
2
1.5
0.6
3.5
0.6
3
C0.2
2
Production date
code
Schematic
3.5
Production2date code
2
3.5
φ 0.8
2
5
0.25
2.5
φ 0.8
2
2
3.5
1.5
0.6
2
0.25
1.5
2
2
2
3 4
0.25
3.5
0.25
3.3
0.6
Terminal No.①
2
2
Travel
1.5
2
● CL-SB-13C-11
12
● CL-SB-13C-12
3 4
0.25
2
2
12
1.5
2
3
2
Schematic
2
1.5
3.5
2
Travel
Travel
0.8
0.6
Terminal No.①
2
2
0.8
c
1 2
Travel
2
2.5
Schematic
3 4
Schematic
Production date
code
φ 0.8
2
1 2
0.4min
2.5
12
12
2
2
5
● CL-SB-13B-11
12
● CL-SB-13B-12
3 4
2.5
C0.2
0.4min
φ 0.8
1.5
1.5
● CL-SB-13A-11
12
● CL-SB-13A-12
2
5
0.6
φ 0.8
2
3
2
2
1.5
2.5
Terminal No.①
1.5
C0.2
0.4min
φ 0.8
2
1.5
3
3.5
C0.2
2
5
0.6
φ 0.8
2
3
2
0.25
Terminal No.①
0.8
1.5
φ 0.8
2
0.25
C0.2
2
5
0.6
φ 0.8
2
3
2
φ 0.8
2
0.25
0.8 3.5
2
0.8
Terminal No.①
0.6
φ 0.8
2
3
1.5
3 4
2
2
1.5
c
ProductionSchematic
date code
2
1.5
2
1.5
1.5
0.8 3.5
2
2
1 2
12
Travel
2
2
2
3 4
Schematic
3 4
Production date
code
Schematic
Travel
1.5
c
c
1 2
3 4
3.5
2
1.5
Travel
c
12
3.5
Schematic
Production date
code
0.25
3.3
● CL-SB-13C-01
● CL-SB-13C-02
Schematic
3 4
3.5
2
c
1 2
2
c
2.5
0.25
2.5
1 2
3.5
3.5
2.5
3 4
12
3.5
0.4min
0.4min
2.5
● CL-SB-13B-01
● CL-SB-13B-02
Schematic
2
2
12
Travel
3.5
2
3.5
1.5
2.5
1.5
c
6
3
2.5
0.25
1.5
3.5
2.5
0.6
Terminal No.①
0.6
2.5
5
2
Schematic
3.5
3.5
3.5
2
1 2
3.5
c
c
4
1
1.5
2
12
3.5
3
Travel
2
1.5
● CL-SB-13A-01
● CL-SB-13A-02
Terminal No.①
2
8.5
Travel
Travel
Terminal No.①
6
2
Terminal No.①
5
Schematic
2.5
c
4
Schematic
1.5
0.25
3.3
2.5
8.5
0.6
2.5
2.5
● CL-SB-22B-11
● CL-SB-22B-12
● CL-SB-22A-11
● CL-SB-22A-12
Terminal No.①
Terminal No.①
2.5
1.5
0.6
2.5
2.5
3
3.5
0.25
3.5
Terminal No.①
0.25
3.5
2
2
2
1.5
6
3
Travel
2
SLIDE SWITCHES
5
2
Schematic
Travel
c
4
8.5
Schematic
Travel
1.5
c
4
3.5
c
4
3.5
8.5
1 2
2
c
3 4
Schematic
1.5
0.25
12
12
12
1 2
3 4
Schematic
2
2
2
3.5
2
2
1.5
1.5
3
3.5
3
3.5
3.5
7 8
c
3 4
Schematic
5 6
c
7 8
1 2
c
3 4
Schematic
2
2
c
1.5
1.5
Travel
2
3.5
1.5
2
0.25
2
1.5
3.5
3
1.5
Terminal No.①
2.5
0.25
2.5
2
c
0.4min
2
2
0.6
2
0.25
3.3
3 4
c
0.4min
2
2
0.6
2
c
3 4
3.5
2.5
5 6
1 2
0.4min
3.3
c
c
0.25
7 8
3 4
Schematic
12
7 8
3.5
2.5
2
Terminal No.①
● CL-SB-23C-11
12
● CL-SB-23C-12
7 8
2
0.4min
2
2
3
1 2
c
2.5
5 6
0.6
2
1.5
3.5
1.5
5 6
2.5
Schematic
2
2
0.25
3.3
5 6
Travel
Terminal No.①
Production
date code
2
3.5
Terminal No.①
0.25
3.3
0.6
2
12
5 6
2
c
c
7 8
3 4
Schematic
Travel
2
0.6
2
2
2
1.5
Travel
2
1.5
Production
date
2
3.5 code
2
3.5
2
3.5
2 2 2
Terminal No.①
2
2
0.6
3.3
3.5
0.25
3
3.5
3.5
1.5
0.4min
2.5
2.5
0.4min
2
3.5
2
3.5
3.5
2
Travel
0.6
2
0.6
2
1.5
0.25
2.5
1.5
2
0.4min
Travel
2
2
2
Production date codeSchematic
3.5
2
1.5
3.5
3.5
Terminal No.①
1.5
2.5
2
2
3 4
0.25
2
3 4
1.5
1 2
2
2
0.6
2
3
c
c
12
1.5
Travel
2
2
2
7 8
2
2.5
3.5
1 2
7 8
c
0.25
3 4
5 6
3 4
3.5
2
c
c
1.5
● CL-SB-23B-11
12
● CL-SB-23B-12
7 8
Schematic c
2
0.6
2
3.5
1 2
c
Schematic
2
0.6
2
2
1 2
0.25
3.5
2
0.25
3.5
3.5
5 6
2
2
1.5
Travel
Terminal No.①
2
Terminal No.①
2
12
2
2.5
3.5
3.5
0.8
0.25
2
0.25
3.5
Terminal No.①
SLIDE SWITCHES
1.5
12
5 6
2
1.5
Travel
1.5
2
Terminal No.①
Production dateSchematic
code
2
2
7 8
Schematic
Travel
2
1.5
2
c
1 2
1.5
2
5 6
3.5
3.5
c
● CL-SB-23A-11
12
● CL-SB-23A-12
2
Terminal No.①
0.4min
2.5
Production
date code
2
3.5
● CL-SB-23C-01
● CL-SB-23C-02
12
1.5
2
2
2.5
3 4
0.6
2
0.4min
2
5
0.4min
2.5
1 2
7 8
0.6
Terminal No.①
2
12
code
2
C0.2
φ 0.8
3 4
1 2
2
1.5
Travel
2
2
2.5
0.25
3.5
c
1.5
2
0.6
3
Terminal No.①
7 8
5 6
Travel
2
c
Schematic c
12
2
0.4min
2
5
2
3.5
1.5
5 6
1 2
Terminal No.①
2
2
● CL-SB-23B-01
● CL-SB-23B-02
12
2
C0.2
φ 0.8
φ 0.8
2
1.5
5
● CL-SB-23A-01
● CL-SB-23A-02
2
3
Terminal No.①
0.25
C0.2
φ 0.8
2
2
3
2
φ 0.8
2
1.5
2.5
0.6
1.5
2
0.6
1.5
φ 0.8
2
2
2.5
5
3.5
3.5
Terminal No.①
C0.2
φ 0.8
2
2
3
0.8
3.5
0.6
2
2.5
0.8
1.5
1.5
3.5
1.5
2
2
2
1.5
Travel
2
Production
2 date
3.5code
1.5
Travel
3.5
0.8
2
0.25
1.5
1.5
Travel
2
CL-SB
Travel
Travel
2
3 4
Schematic
2
2
c
1 2
3 4
2.5
Schematic
φ 0.8
2
c
Schematic
Travel
3 4
12
1 2
3 4
2.5
c
c
Schematic
1.5
1 2
2
1 2
3 4
12
12
Terminal No.①
c
Schematic
2.5
c
1.5
1 2
2.5
2.5
0.4min
2 2 2
Terminal No.①
2
0.6
3.3
0.25
CL-SB
SLIDE SWITCHES
■RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS
(Unit: mm)
● CL-SB-12A-□□
● CL-SB-12B-□□
● CL-SB-22A-□□
6.8
6 – 1.2
6.8
1.2
3
5.8
4.4
2 – φ 0.9 holes
2.5
2.5
2.5
2.5
● CL-SB-22B-□□
● CL-SB-13A-□□
● CL-SB-13B-□□
6 – 1.2
3
5
1.2
4
4.4
5.8
3
2.5
2
5
4 – 1.2
3
3
4 – 1.2
2 – φ 0.9 holes
2.5
2.5
5.8
1.2
2 –φ 0.9 holes
4.4
3 – 1.2
3 – 1.2
2 – φ 0.9 holes
2
2
4
2
2.5
● CL-SB-23A-□□
● CL-SB-23B-□□
● CL-SB-12C-□□
3 – φ 0.8 holes
8 – 1.2
2
4
2
3.3
3
2
5.8
4.4
1.2
8 – 1.2
2
4
2.5
2.5
■SIZE OF P.C.B. PROCESSING
● CL-SB-22C-□□
(Unit: mm)
● CL-SB-13C-□□
● CL-SB-23C-□□
6 – φ 0.8 holes
8 – φ 0.8 holes
3.3
3.3
3.3
4 – φ 0.8 holes
2
2
2.5
2.5
4
2
4
2
CL-SB
SLIDE SWITCHES
■ PACKAGING SPECIFICATIONS
● The smallest unit of bulk pack in plastic bag is 10 pcs.
per pack.Orders will be accepted for unit of minimum 10
pcs., i.e., 10, 20, 30 pcs., etc.
● Boxing of bulk in a plastic bag is performed with 50 pcs.
per box.
● Taping version is packaged in 500 pcs. per reel.
Orders will be accepted for units of 500 pcs., i.e., 500,
1000, 1500, pcs., etc.
● Taping version is boxed with one reel (500 pcs.).
Maximum number of consecutive missing pieces=2
Leader length and reel dimension are shown in the
diagrams below:
● Embossed tape dimensions
● Reel dimensions
(Unit: mm)
(Conforms to JIS C 0806-3)
(In accordance with EIAJ ET-7200A)
25.4±1
Empty
Empty
Filled
2±0.5
φ 13±0.2
40 mm min.
φ 330±2
Head
20 pitches min.
Leader
400 mm min.
Direction of feed
φ 80±1
End
φ 21±0.8
Part No. label
29.4±1
〈Tape dimensions〉
11.5±0.1
1.75±0.1
(CL-SB-22B-02T)
(CL-SB-22B-02T)
Installation
Installation
example
example
24
1.75±0.1
1.75±0.1
2 ± 0.12 ± 0.1
0 . 5 ± 0.1
0 . 5 ± 0.1
0 . 5 ± 0.1
0 . 5 ± 0.1
7.3 7.3
Direction
Direction
of feed
of feed
F
1.75±0.1
12 ± 0.1
12 ± 0.1
4 ± 0.14 ± 0.1
Terminal
Terminal
No.1 No.1
7.3 7.3
E CL-SB-12A/12B-1□T
CL-SB-12A/12B-1□T
φ 1.5 +0.1
φ0 1.5 +0.1
2 ± 0.12 ± 0.1
4 ± 0.14 ± 0.1
Direction
Direction
of feed
of feed
E
(CL-SB-12B-02T)
(CL-SB-12B-02T)
Installation
Installation
example
example
φ 1.5 +0.1
φ0 1.5 +0.1
F CL-SB-22A/22B-1□T
CL-SB-22A/22B-1□T
12 ± 0.1
12 ± 0.1
φ 1.5 +0.1
φ0 1.5 +0.1
4 ± 0.14 ± 0.1
2 ± 0.12 ± 0.1
1.75±0.1
12 ± 0.1
12 ± 0.1
0 . 5 ± 0 . 15 ± 0 . 1
1.75±0.1
11.5±0.1
Terminal
Terminal
No.1 No.1
B
CL-SB-22A/22B-0□T
CL-SB-22A/22B-0□T
24
2 ± 0.12 ± 0.1
4 ± 0.14 ± 0.1
1.75±0.1
12 ± 0.1
12 ± 0.1
φ 1.5 +0.1
φ0 1.5 +0.1
B
(Conforms to JIS C 0806)
1.75±0.1
A
CL-SB-12A/12B-0□T
CL-SB-12A/12B-0□T
24 11.5±0.1
A
● CL-SB-22A/22B-0 □ T
24 11.5±0.1
● CL-SB-12A/12B-0 □ T
0 . 5 ± 0.1
0 . 5 ± 0.1
CL-SB
SLIDE SWITCHES
〈Tape dimensions〉
● CL-SB-23A/23B-0 □ T
24
11.5±0.1
7.3
7.3
7.3
DirectionDirection
of feed of feed
7.3
Direction
Directionof
offeed
feed
(CL-SB-13B-02T)
(CL-SB-13B-02T)
Installation
example
Installation
example
5.3
TerminalTerminal
No.1 No.1
± 0.1
2 ±20.1
± 0.1
4 ±40.1
Terminal
Terminal
No.1
No.1
1.75±±0.1
0.1
1.75
Direction
Directionof
offeed
feed
5.3
± 0.1
0 . 05 .±50.1
(CL-SB-22B-12T)
(CL-SB-22B-12T)
Installation
Installation
exampleexample
(CL-SB-23B-02T)
(CL-SB-23B-02T)
Installation
example
Installation
example
5.3
5.3
5.3
DirectionDirection
of feed of feed
5.3
7.37.3
Direction
feed
Direction
of of
feed
CL-SB-23A/23B-1□T
H H CL-SB-23A/23B-1□T
± 0.1
4 ±40.1
± 0.1
2 ±20.1
Terminal
Terminal
No.1
No.1
± 0.1
0 . 05 .±50.1
(CL-SB-23B-12T)
(CL-SB-23B-12T)
Installation
example
Installation
example
24
24
(CL-SB-13B-12T)
(CL-SB-13B-12T)
Installation
example
Installation
example
± 0.1
1212
± 0.1
+0.1
+0.1
φ 1.5
φ 1.5
0 0
1.75 ±0.1
1.75 ±0.1
± 0.1
0 . 05 .±50.1
24
24
Direction
feed
Direction
of of
feed
24
24
± 0.1
1212
± 0.1
+0.1
+0.1
φ 1.5
φ 1.5
0 0
0 . 5 ±(CL-SB-23B-12T)
0.10 . 5 ± 0.1
(CL-SB-23B-12T)
Installation
Installationexample
example
11.5 ±0.1
11.5 ±0.1
Terminal
Terminal
No.1
No.1
2 ± 0.1 2 ± 0.1
00..55±±0.1
0.1
● CL-SB-23A/23B-1 □ T
1.75± 0.1
1.75± 0.1
± 0.1
2 ±20.1
No.1
7.37.3
CL-SB-13A/13B-1□T
G G CL-SB-13A/13B-1□T
1212±
± 0.10.1
± 0.1
4±40.1
12 ± 0.1 12 ± 0.1
+0.1
Terminal
Terminal
φ 1.5 +0.1
0 φ 1.5 0 4 ± 0.1 4 ± 0.1
No.1
5.3
5.3
● CL-SB-13A/13B-1 □ T
+0.1+0.1
φ 1.5
φ 1.5
0 0
7.3
24
± 0.1
0 . 05 .±50.1
(CL-SB-12B-12T)
(CL-SB-12B-12T)
Installation
Installation
exampleexample
1.75±0.1
CL-SB-23A/23B-0□T
D DCL-SB-23A/23B-0□T
(CL-SB-13B-12T)
(CL-SB-13B-12T)
0 . 5 ± 0.10 . 5 ± 0.1
Installation
Installationexample
example
DirectionDirection
of feed of feed
Direction
feed
Direction
of of
feed
22±±0.1
0.1
1.75 ± 0.1
1.75 ± 0.1
11.5±0.1
1.75±0.1
11.5±±0.1
0.1
11.5
11.5±0.1
+0.1
+0.1
00
24
24
11.5 ± 0.1
11.5 ± 0.1
Terminal
Terminal
No.1
No.1
24
11.5±0.1
± 0.1
2 ±20.1
± 0.1
4 ±40.1
TerminalTerminal
No.1 No.1
24
24
± 0.1
1212
± 0.1
+0.1
φ 1.5
φ 1.5
0 0
12
12±±0.1
0.1
2 ± 0.1 2 ± 0.1
No.1
No.1
7.3
11.5 ± 0.1
11.5 ± 0.1
12 ± 0.1 12 ± 0.1
7.3
7.3
DirectionDirection
of feed of feed
F CL-SB-22A/22B-1□T
F CL-SB-22A/22B-1□T
φφ1.5
44±±0.1
1.5
0.1
00..55±±0.1
0.1
1.75±0.1
CL-SB-13A/13B-0□T
C C CL-SB-13A/13B-0□T
1.75 ± 0.1
1.75 ± 0.1
11.5±±0.1
0.1
1.75±0.1
11.5
22±±0.1
0.1
24
44±±0.1
0.1
+0.1
Terminal
Terminal
φ 1.5 +0.1
4 ± 0.1
0 φ 1.5 0 4 ± 0.1
+0.1
1.75±±0.1
0.1
1.75
12± 0.1
12± 0.1
E CL-SB-12A/12B-1□T
CL-SB-12A/12B-1□T
(CL-SB-22B-02T)
(CL-SB-22B-02T)
Installation
Installation
exampleexample
HH CL-SB-23A/23B-1□T
CL-SB-23A/23B-1□T □ T
● CL-SB-22A/22B-1
24
24
E
(CL-SB-23B-02T)
0 . 5 ± 0.10 .(CL-SB-23B-02T)
5 ± 0.1
Installation
Installationexample
example
Direction
Directionof
offeed
feed
G
G CL-SB-13A/13B-1□T
CL-SB-13A/13B-1□T □ T
● CL-SB-12A/12B-1
+0.1
+0.1
φφ1.5
1.5 00
TerminalTerminal
No.1 No.1
11.5±0.1
Direction
Directionof
offeed
feed
(CL-SB-12B-02T)
(CL-SB-12B-02T)
Installation
Installation
exampleexample
2 ± 0.1 2 ± 0.1
No.1
No.1
24
24
11.5±0.1
TerminalTerminal
No.1 No.1
Terminal
φ 1.5 +0.1
φ 1.5 +0.1
0 Terminal
0 4 ± 0.1 4 ± 0.1
00..55±±0.1
0.1
24
12 ± 0.1 12 ± 0.1
(CL-SB-13B-02T)
0 . 5 ±(CL-SB-13B-02T)
0 . 10 . 5 ± 0 . 1
Installation
Installationexample
example
24
24
2 ± 0.1 2 ± 0.1
22±±0.1
0.1
44±±0.1
0.1
11.5±0.1
11.5±0.1
11.5±0.1
1.75±0.1
12 ± 0.1 12 ± 0.1
Terminal
Terminal
+0.1
φ 1.5 +0.1
± 0.1
0 φ 1.5 0 4 ± 0.1 4
No.1
No.1
12
12±±0.1
0.1
B CL-SB-22A/22B-0□T
CL-SB-22A/22B-0□T
B
+0.1
+0.1
φφ1.5
1.5 00
00..55±±0.1
0.1
11.5 ± 0.1
24
11.5± 0.1
22±±0.1
0.1
44±±0.1
0.1
1.75±0.1
12±±0.1
0.1
A 12
CL-SB-12A/12B-0□T
CL-SB-12A/12B-0□T
DD CL-SB-23A/23B-0□T
CL-SB-23A/23B-0□T
1.75±0.1
1.75±0.1
1.75±0.1
1.75±0.1
A
+0.1
+0.1
φφ1.5
1.5 00
1.75±0.1
CC CL-SB-13A/13B-0□T
CL-SB-13A/13B-0□T
11.5±0.1
11.5±0.1
11.5±0.1 24
1.75±0.1
24
● CL-SB-13A/13B-0 □ T
5.35.3
Direction
feed
Direction
of of
feed
5.35.3
很抱歉,暂时无法提供与“CL-SB-12C-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.929331+1.15260
- 10+7.6862310+0.99214
- 20+7.2660320+0.93790
- 50+6.7495350+0.87123
- 100+6.40811100+0.82716
- 200+6.10171200+0.78761
- 250+6.01417250+0.77631
- 500+5.76030500+0.74354
- 1000+5.550191000+0.71642
- 2500+5.313832500+0.68591
- 国内价格
- 50+7.56357
- 100+7.21783
- 250+6.94291
- 500+6.70235
- 国内价格
- 1+3.51000
- 10+3.43440
- 30+3.39120
- 100+3.18600
