CL-SB-22B-01
CL-SB-22B-01
    NIDEC(尼得科)
    SMD-6P,8.5x3.5mm
    滑动开关 SMD-6P,8.5x3.5mm 双刀双掷 1万次 立贴
CL-SB-22B-01 数据手册
CL-SB SLIDE SWITCHES CL-SB内部構造図.eps RoHS compliant INTERNAL STRUCTURE 2 3 1 6 4 5 Part name Material Flammability ① Cover Stainless steel (SUS 304) — ■ FEATURES ② Slider Polyamido UL94V-0 ● Wide variety (circuit composition, operating direction, terminal shape: J-hook, Gull wing, Through hole pins) ● Standardization of the silver contacts as well as gold contacts ● Stroke is 2mm ● Using heat-resistant resin to support reflow soldering mounting ● Adopted Twin-contacts mechanism ③ Housing Polyphenylenesulphide UL94V-0 ④ Moving contact Copper alloy, gold or silver plate — ⑤ Fixed contact Copper alloy, gold or silver plate — ⑥ Terminal pin Copper alloy, gold or silver plate — ■ PART NUMBER DESIGNATION CL - SB - 2 3 B - 0 2 T Series name No. of poles 1:1 pole 2:2 poles Form of packaging T : Taping Blank : Bulk in plastic bag Contact material No. of positions 1:Silver   2:Gold 2:2 positions 3:3 positions Setting position  Shape of terminal A:J-hook B:Gull wing C:Through hole pins ※ Please refer to the LIST OF PART NUMBERS when placing orders. 0:Top setting 1:Side setting CL-SB SLIDE SWITCHES ■LIST OF PART NUMBERS Setting position No. of poles No. of positions 2 1 3 Top setting 2 2 3 2 1 3 Side setting 2 2 3 Contact material Silver Gold CL-SB-12A-01T CL-SB-12A-02T CL-SB-12A-01 CL-SB-12A-02 CL-SB-12B-01T CL-SB-12B-02T CL-SB-12B-01 CL-SB-12B-02 CL-SB-12C-01 CL-SB-12C-02 CL-SB-13A-01T CL-SB-13A-02T CL-SB-13A-01 CL-SB-13A-02 CL-SB-13B-01T CL-SB-13B-02T CL-SB-13B-01 CL-SB-13B-02 CL-SB-13C-01 CL-SB-13C-02 CL-SB-22A-01T CL-SB-22A-02T CL-SB-22A-01 CL-SB-22A-02 CL-SB-22B-01T CL-SB-22B-02T CL-SB-22B-01 CL-SB-22B-02 CL-SB-22C-01 CL-SB-22C-02 CL-SB-23A-01T CL-SB-23A-02T CL-SB-23A-01 CL-SB-23A-02 CL-SB-23B-01T CL-SB-23B-02T CL-SB-23B-01 CL-SB-23B-02 CL-SB-23C-01 CL-SB-23C-02 CL-SB-12A-11T CL-SB-12A-12T CL-SB-12A-11 CL-SB-12A-12 CL-SB-12B-11T CL-SB-12B-12T CL-SB-12B-11 CL-SB-12B-12 CL-SB-12C-11 CL-SB-12C-12 CL-SB-13A-11T CL-SB-13A-12T CL-SB-13A-11 CL-SB-13A-12 CL-SB-13B-11T CL-SB-13B-12T CL-SB-13B-11 CL-SB-13B-12 CL-SB-13C-11 CL-SB-13C-12 CL-SB-22A-11T CL-SB-22A-12T CL-SB-22A-11 CL-SB-22A-12 CL-SB-22B-11T CL-SB-22B-12T CL-SB-22B-11 CL-SB-22B-12 CL-SB-22C-11 CL-SB-22C-12 CL-SB-23A-11T CL-SB-23A-12T CL-SB-23A-11 CL-SB-23A-12 CL-SB-23B-11T CL-SB-23B-12T CL-SB-23B-11 CL-SB-23B-12 CL-SB-23C-11 CL-SB-23C-12 ※Verify the above part numbers when placing orders. Taping version can be supplied only in reel unit. Shape of terminal A(J-hook) B(Gull wing) C(Through hole pins) A(J-hook) B(Gull wing) C(Through hole pins) A(J-hook) B(Gull wing) C(Through hole pins) A(J-hook) B(Gull wing) C(Through hole pins) A(J-hook) B(Gull wing) C(Through hole pins) A(J-hook) B(Gull wing) C(Through hole pins) A(J-hook) B(Gull wing) C(Through hole pins) A(J-hook) B(Gull wing) C(Through hole pins) Form of packaging Pieces in package Taping 500pcs. / reel Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Taping 500pcs. / reel Plastic bag 50pcs. / pack Plastic bag 50pcs. / pack CL-SB SLIDE SWITCHES ■ STANDARD SPECIFICATIONS Operating temperature range ■ ELECTRICAL CHARACTERISTICS Contact rating Non-switching Switching Minimum − 40 ~ 85 °C Storage temperature range Sealing Non- Washable 0.21 g (CL-SB-12*-0*) 0.22 g (CL-SB-22*-0*) 0.26 g (CL-SB-13*-0*) 0.28 g (CL-SB-23*-0*) Net weight DC50 V 200 mA DC12 V 200 mA DC20 mV 1 μ A (Gold contacts) DC5 V 10 mA (Silver contacts)      0.21 g (CL-SB-12*-1*) 0.23 g (CL-SB-22*-1*) 0.27 g (CL-SB-13*-1*) 0.29 g (CL-SB-23*-1*) Contact timing Non-shorting  70m Ω maximum (Gold contacts)  50m Ω maximum (Silver contacts) Contact resistance ■ MECHANICAL CHARACTERISTICS 100 M Ω minimum (DC500 V) Insulation resistance No. of positions 2, 3 Stroke Operation force Stop strength Solderability ■ ENVIRONMENTAL CHARACTERISTICS   A → B / C → B      ※ 2 3 Contacts 1.5 ± 1.0 N {0.153 ± 0.102kgf} (CL-SB-*3*-**)   B → A / B → C 2.5 ± 1.5 N {0.255 ± 0.153kgf} 20 N {2.04 kgf} 15 s 245 ± 3 °C, 2 ~ 3 s (Please refer to the profile below) Soldering heat Substrate bending Pull-off strength Load life 10000 cycles, DC12 ± 0.5V, 200 ± 10mA Humidity 40 °C, Relative humidity 90 ~ 95 %, 240 h, No load 85 °C, 96 h, No load Manual soldering:350 ± 10 °C, 3 ~ 4 s Low temperature exposure − 40 °C, 96 h, No load Width 90 mm, bend 3 mm, 5 s, 1 time ※1 A B 5 N {0.51 kgf} 10s Thermal shock ※ 2 ※2 − 40 (0.5 h) ~ 85 °C ( 0.5 h ), 5 cycles 〈Reflow profile for soldering heat evaluation〉 (℃) 250 Peak : 250 200 150 100 50 +5 0 ℃ Over 230 ℃ A B C Temperature A B C 490 m/s2, 11 ms 6 directions for 3 times each High temperature exposure { } : Reference only A B Shock Flow : 260 ± 3 °C, 5 ~ 6 s 5 N {0.51 kgf} 10 s Shear (Amplitude) 1.5 mmor (Acceleration) 98 m/s2, 10-500-10 Hz, 3 directions for 2 h each Vibration Reflow:255 °C (Peak temperature) ※2 AC500 V, 60 s Dielectric strength 2 mm 2 Contacts   A ⇔ B        ※ 1 (CL-SB-*2*-**)  1.5 ± 1.0 N {0.153 ± 0.102kgf} ※ 1 ※1 1.5 mA 1 kHz 20 mV maximum 180 ℃ 150 ℃ Pre Heating Zone 90 ± 30 s 30 ± 10 s Heating time Reflow : two times maximum Soldering Zone 4_5-6p 4_5-6p 4_5-6p CL-SB SLIDE SWITCHES ■ OUTLINE DIMESIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● CL-SB-12B-01 ● CL-SB-12B-02 ● CL-SB-12A-01 ● CL-SB-12A-02 8.5 ● CL-SB-12C-01 ● CL-SB-12C-02 8.5 8.5 1 3 1.5 CO.2 0.6 2.5 2.5 CO.2 1 φ 0.8 8.5 4 5 6 2 3 1 Travel c Production date code1 8.5 Travel c 5 2 1 2 c 5 3.5 3.5 3.5 2 c 5 1.5 1.5 3.5 0.25 3.5 3.3 1.5 0.25 2 0.6 2.5 2.5 0.6 2.5 0.25 3.3 2 5 6 1.5 Production date code 0.4min 2.5 0.6 2.5 0.4min 2.5 0.6 2.5 0.4min 0.4min 2.5 1.5 2.5 0.4min 2.5 2.5 2.5 2.5 4 1 0.4min 4 c 5 6 2 3 c Terminal No.① 3 c Schematic 1.5 Production date code 2 0.6 2.5 1.5 3.3 2.5 0.6 2.5 3.3 2.5 0.6 2.5 3.3 8.5 0.25 0.25 4 c 5 4 4 2 2 2 c 5 3 6 1.5 4 8.5 2 Travel 6 3 c c 5 6 1 2 3 2 4 3.5 Production date code 1 Travel 1.5 2 c c Schematic 3 3.5 c Schematic Production date code 5 2 Production date code Production date code 1 2 1.5 c Schematic 8.5 6 c Schematic Travel 0.25 1 Schematic Travel 2 c 2.5 1.5 6 Production date code 1 2 3 Travel Terminal No.① 5 c Schematic 4 5 6 1.5 Travel Terminal No.① c Production date code 2 1.5 6 3 c 4 2 8.5 1.5 5 2 Schematic ● CL-SB-22C-01 8.5 ● CL-SB-22C-02 Travel Schematic Travel 2 0.6 2.5 2.5 c 1 3 c 0.25 3.3 8.5 6 1 3.5 3 3 6 3 Terminal No.① 1.5 8.5 6 3 3.5 2 2.5 0.25 3.5 3 2.5 0.4min 1 2code 3 Production date c 3 25 1.5 5 2 c 4 8.5 6 Schematic Travel Terminal No.① Production date code Production 2 date code 3.5 c 1.5 c 1 c Schematic 4 0.4min c Schematic 8.5 Schematic 4 1 3 0.25 Terminal No.① c Terminal No.① Production date code 1.5 Terminal No.① 1 8.5 2.5 1.5 1.5 2.5 4 5 0.6 2.5 2.5 0.4min Schematic 2 2 2.5 2.5 4 Travel 3.5 1.5 0.25 0.6 2.5 3.5 CO.2 0.4min 2 3.5 2 2.5 2 3 0.6 2.5 6.8 8.5 2 Terminal No.① 1.5 1.5 1.5 3 Schematic 3.5 2.5 3.5 2 0.25 1.5date code Production 3.5 Schematic 2 3.5 1.5 1.5 2 c 3.5 2 date code Production Travel 2 0.6 2.5 2.5 1.5 3.5 6 2.5 0.25 1.5 2.5 1.5 φ 0.8 Travel 2 2 3 5 1 Schematic Schematic 1.5 3.5 3.5 2 c 2 CO.2 0.4min 6.8 3.5 2.5 φ 0.8 8.5 ● CL-SB-22B-01 ● CL-SB-22B-02 c Schematic 4 2 CO.2 0.4min 1 Production date code 1 0.6 2.5 Production date code 8.5 6 0.25 3.3 c code Production date 32 5 1.5 3 2 3.5 c 0.6 8.5Travel 2 3.5 3 c 2 3.5 6 3 Travel 2.5 3.5 2.5 1 2 Schematic 3.5 1 date 2 3 code Production 3.5 2 3.5 2.5 0.25 3.3 c 0.25 4 2 3.5 3.5 2.5 8.5 0.6 Production1date 2 code 3 c Production date code 0.6 2.5 2.5 Travel 6.8 2 0.8 5 2 Schematic Travel 2 0.6 Terminal No.① 1.5 2.5 2.5 .5 2.5 0.25 3.3 ● CL-SB-12C-11 ● CL-SB-12C-12 3 0.25 3.5 3.5 c Travel 3.5 4 Travel Terminal No.① Terminal No.① φ 0.8 Terminal No.① φ 0.8 c Terminal No.① 2.5 1.5 0.6 8.5 1.5 1.5 1 1.5 Terminal No.① Terminal No.① Schematic 2.5 CO.2 φ 0.8 Travel 8.5 2 3.5 0.8 1.5 8.5 ● CL-SB-22A-01 ● CL-SB-22A-02 1.5 3.5 CO.2 φ 0.8 8.5 Terminal No.① φ 0.8 2 3.5 6.8 0.25 3.5 0.25 2.5 1.5 1.5 1.5 3.5 0.8 0.6 2.5 1.5 0.8 3.5 2 2 1.5 0.25 2.5 2 2.5 0.6 2.5 1.5 3 1.5 3.5 0.8 3.5 0.8 2 c Production date code 0.6 CO.2 2.5 2.5 Travel φ 0.8 26.8 2.5 φ 0.8 2.5 Schematic 8.5 1 6.8 Terminal No.① 2.5 c 2Schematic 3.5 Production date code 2 2.5 Terminal No.① 2 code 3 Production 1date Travel Travel φ 0.8 2 c 3 2 20.8 3.5 ● CL-SB-12B-11 ● CL-SB-12B-12 3 2 1.5 2.5 2 c Production date code Travel 8.5 1.5 Terminal No.① 0.4min 2.5 1.5 1.5 2.5 1 Schematic 2 1.5 2 0.4min Schematic φ 0.8 2.5 2.5 2 3 Production 1date c code Terminal No.① 0.4min 2.5 φ 0.8 6.8 8.5 1.5 0.25 0.4min 8.5 8.5 ● CL-SB-12A-11 ● CL-SB-12A-12 8.5 0.4min 2.51.5 2.5 φ 0.8 6.8 Terminal No.① φ 0.8 0.4min Schematic Travel 2 2 3.5 2 3.5 CO.2 φ 0.8 0.6 2.5 2.5 1.5 1.5 6.8 Terminal No.① φ 0.8 3 c 5 6 2 3 c Schematic 2.5 2.5 1.5 CO.2 φ 0.8 0.25 Terminal No.① φ 0.8 0.6 2.5 CO.2 φ 0.8 Travel 0.6 Terminal No.① 2.5 2 2.5 φ 0.8 1.5 6.8 .25 3.5 0.8 6.8 1.5 1.5 0.8 2 3.5 0.6 2.5 2.5 CO.2 φ 0.8 1.5 Production date code 3.5 Terminal No.① φ 0.8 Schematic 1.5 1.5 2 c 2 3 code Production1 date Travel 0.8 0.8 2 3.5 Travel 0.6 Terminal No.① 2.5 2 2.5 φ 0.8 1.5 6.8 0.25 Production date1.5 code 1.5 3 2 0.25 1.5 2 c Production date code Schematic Travel 1 1 Schematic 2 8.5 3.5 3 1.5 3 3 3.5 1.5 1 2 3 Production date code c 2 c Production date code Travel Schematic Travel 2 8.5 0.25 3.5 20.8 3.5 3.5 2 Schematic 2 8.5 1 2date 3 code Production c c 1.5 1 Schematic 8.5 Production date code 1 2 3 Travel 28.5 3 3.5 3.5 3.5 8.5 2 c Schematic 0.25 2 c 0.25 1 Schematic 2 date code 3.5 Production 3.5 1 5 6 2 3 c 8.5 1 Schematic CL-SB 5 6 2 3 c Production date code 1 2 2 1.5 1.5 1.5 c 1.5 Terminal No.① 1.5 0.6 2.5 2.5 0.4min 0.4min 2.5 ■ OUTLINE DIMESIONS c 4 1 5 6 2 3 c ● CL-SB-22C-11 ● CL-SB-22C-12 8.5 1 1.5 3 Terminal No.① 0.6 2.5 2.5 12 1 2 2 1.5 Travel 2 3.5 Production date code 2 1.5 Travel c 1 2 2 Schematic c 1 2 3.5 3.5 3 2 0.25 0.4min 2.5 c 2 3.5 1 2 1.5 2 3 Terminal No.① c c 7 8 φ 0.8 2 2 5 12 C0.2 0.4min 1 2 c 2.5 2.5 c 2 c 1 2 3 4 c 1.5 3 2 2 2 0.6 2 Terminal No.① 2 2 2 2 12 c 3 4 3.5 3.3 0.6 3.3 5 6 c c 7 8 3 4 Schematic 12 7 8 Schematic 2 Terminal No.① 2 1 2 Schematic 5 6 0.4min 2 1.5 7 8 Production date code Travel 1.5 0.4min 2.5 1 2 3 4 3 4 Production 2 date code 3.5 3.5 2.5 2 1.5 3.5 5 6 12 2 3 4 0.25 3 0.6 0.4min 2.5 5 3.5 1.5 2.5 2 C0.2 2 1.5 3.5 0.8 3.5 φ 0.8 3 4 Schematic 5 6 φ 0.8 2 7 8 ProductionSchematic date code 2 1.5 c 1 2 Travel 2 c 2 2 1.5 5 5 6 12 0.8 2.5 C0.2 2 3 Terminal No.① c 1 2 Schematic Travel 3.5 12 φ 0.8 2 φ 0.8 0.25 3.3 Travel 2 1.5 Travel 5 6 c 7 8 Production date code Travel 3.5 2 1.5 2 1.5 0.6 3.5 0.6 3 C0.2 2 Production date code Schematic 3.5 Production2date code 2 3.5 φ 0.8 2 5 0.25 2.5 φ 0.8 2 2 3.5 1.5 0.6 2 0.25 1.5 2 2 2 3 4 0.25 3.5 0.25 3.3 0.6 Terminal No.① 2 2 Travel 1.5 2 ● CL-SB-13C-11 12 ● CL-SB-13C-12 3 4 0.25 2 2 12 1.5 Production date code 2 3 2 Schematic 2 1.5 3.5 2 Travel Travel 0.8 0.6 Terminal No.① Production date code 2 2 0.8 c 1 2 Travel 2 2.5 Schematic 3 4 Schematic Production date code φ 0.8 2 1 2 0.4min 2.5 12 12 2 2 5 ● CL-SB-13B-11 12 ● CL-SB-13B-12 3 4 2.5 C0.2 0.4min φ 0.8 1.5 1.5 ● CL-SB-13A-11 12 ● CL-SB-13A-12 2 5 0.6 φ 0.8 2 3 2 2 1.5 2.5 Terminal No.① 1.5 C0.2 0.4min φ 0.8 2 1.5 3 3.5 C0.2 2 5 0.6 φ 0.8 2 3 2 0.25 Terminal No.① 0.8 1.5 φ 0.8 2 0.25 C0.2 2 5 0.6 φ 0.8 2 3 2 φ 0.8 2 0.25 0.8 3.5 2 0.8 Terminal No.① 0.6 φ 0.8 2 3 1.5 3 4 Production date code 2 2 1.5 c ProductionSchematic date code 2 1.5 2 1.5 1.5 0.8 3.5 2 2 1 2 12 Travel 2 2 Production date code 2 3 4 Schematic 3 4 Production date code Schematic Travel 1.5 c c 1 2 3 4 3.5 2 1.5 Travel c 12 3.5 Schematic Production date code 0.25 3.3 ● CL-SB-13C-01 ● CL-SB-13C-02 Schematic 3 4 3.5 2 c 1 2 2 c 2.5 0.25 2.5 1 2 3.5 3.5 2.5 3 4 12 3.5 0.4min 0.4min 2.5 ● CL-SB-13B-01 ● CL-SB-13B-02 Schematic 2 2 12 Travel 3.5 2 3.5 1.5 2.5 1.5 c 6 3 Production date code 2.5 0.25 1.5 3.5 2.5 0.6 Terminal No.① 0.6 2.5 5 2 Schematic 3.5 3.5 3.5 2 1 2 3.5 c c 4 1 1.5 2 12 3.5 3 Travel 2 1.5 ● CL-SB-13A-01 ● CL-SB-13A-02 Terminal No.① 2 8.5 Travel Travel Terminal No.① 6 Production date code 2 Terminal No.① 5 Schematic Production date code 2.5 c 4 Schematic 1.5 0.25 3.3 2.5 8.5 0.6 2.5 2.5 Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● CL-SB-22B-11 ● CL-SB-22B-12 ● CL-SB-22A-11 ● CL-SB-22A-12 Terminal No.① Terminal No.① 2.5 1.5 0.6 2.5 2.5 3 3.5 0.25 3.5 Terminal No.① 0.25 3.5 2 2 2 1.5 6 3 Production date code Travel 2 SLIDE SWITCHES 5 2 Schematic Production date code Travel c 4 8.5 Schematic Travel 1.5 c 4 3.5 c 4 3.5 8.5 1 2 2 c 3 4 Schematic 1.5 Production date code 0.25 12 12 12 1 2 3 4 Schematic 2 2 2 3.5 2 2 1.5 1.5 3 3.5 3 3.5 3.5 7 8 c 3 4 Schematic 5 6 c 7 8 Production date code 1 2 c 3 4 Schematic 2 2 c 1.5 1.5 Travel 2 Production date code 3.5 1.5 2 0.25 2 1.5 3.5 3 1.5 Terminal No.① 2.5 0.25 2.5 2 c 0.4min 2 2 0.6 2 0.25 3.3 3 4 c 0.4min 2 2 0.6 2 c 3 4 3.5 2.5 5 6 1 2 0.4min 3.3 c c 0.25 7 8 3 4 Schematic 12 7 8 3.5 2.5 2 Terminal No.① ● CL-SB-23C-11 12 ● CL-SB-23C-12 7 8 2 0.4min 2 2 3 1 2 c 2.5 5 6 0.6 2 1.5 3.5 1.5 5 6 2.5 Schematic 2 2 0.25 3.3 5 6 Travel Terminal No.① Production date code 2 3.5 Terminal No.① 0.25 3.3 0.6 2 12 5 6 Production date code1 2 c c 7 8 3 4 Schematic Travel 2 0.6 2 2 2 1.5 Travel 2 1.5 Production date 2 3.5 code 2 3.5 2 3.5 2 2 2 Terminal No.① 2 2 0.6 3.3 3.5 0.25 3 3.5 3.5 1.5 0.4min 2.5 2.5 0.4min 2 3.5 2 3.5 3.5 2 Travel 0.6 2 0.6 2 1.5 0.25 2.5 1.5 2 0.4min Travel 2 2 2 Production date codeSchematic 3.5 2 1.5 3.5 3.5 Terminal No.① 1.5 2.5 2 2 3 4 0.25 2 3 4 1.5 1 2 2 2 0.6 2 3 c c Production date code 12 Production date code 1.5 Travel 2 2 2 7 8 2 2.5 3.5 1 2 7 8 c 0.25 3 4 5 6 3 4 3.5 2 c c 1.5 ● CL-SB-23B-11 12 ● CL-SB-23B-12 7 8 Schematic c 2 0.6 2 3.5 1 2 c Schematic 2 0.6 2 2 1 2 0.25 3.5 2 0.25 3.5 3.5 5 6 Production date code 2 2 1.5 Travel Terminal No.① 2 Terminal No.① 2 12 2 2.5 3.5 3.5 0.8 0.25 2 0.25 3.5 Terminal No.① SLIDE SWITCHES 1.5 12 5 6 2 1.5 Travel 1.5 2 Terminal No.① Production dateSchematic code 2 2 7 8 Schematic Travel 2 1.5 2 c 1 2 1.5 2 5 6 3.5 3.5 c Production date code ● CL-SB-23A-11 12 ● CL-SB-23A-12 2 Terminal No.① 0.4min 2.5 Production date code 2 3.5 ● CL-SB-23C-01 ● CL-SB-23C-02 12 1.5 2 2 2.5 3 4 0.6 2 0.4min 2 5 0.4min 2.5 1 2 7 8 0.6 Terminal No.① 2 12 Production dateSchematic code 2 C0.2 φ 0.8 3 4 1 2 2 1.5 Travel 2 2 2.5 0.25 3.5 c 1.5 2 0.6 3 Terminal No.① 7 8 5 6 Travel 2 c Schematic c 12 2 0.4min 2 5 2 3.5 1.5 5 6 1 2 Terminal No.① 2 2 ● CL-SB-23B-01 ● CL-SB-23B-02 12 2 C0.2 φ 0.8 φ 0.8 2 1.5 5 ● CL-SB-23A-01 ● CL-SB-23A-02 2 3 Terminal No.① 0.25 C0.2 φ 0.8 2 2 3 2 φ 0.8 2 1.5 2.5 0.6 1.5 2 0.6 1.5 φ 0.8 2 2 2.5 5 3.5 3.5 Terminal No.① C0.2 φ 0.8 2 2 3 0.8 3.5 0.6 2 2.5 0.8 1.5 1.5 3.5 1.5 2 2 2 1.5 Travel 2 Production 2 date 3.5code 1.5 Travel 3.5 0.8 2 0.25 Production date code 1.5 1.5 Travel 2 CL-SB Travel Travel 2 3 4 Schematic Production date code Production date code 2 2 c 1 2 3 4 2.5 Schematic Production date code φ 0.8 2 c Schematic Travel 3 4 12 1 2 3 4 2.5 c c Schematic 1.5 1 2 2 1 2 3 4 12 12 Terminal No.① c Schematic 2.5 c 1.5 1 2 2.5 2.5 0.4min 2 2 2 Terminal No.① 2 0.6 3.3 0.25 CL-SB SLIDE SWITCHES ■RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS (Unit: mm) ● CL-SB-12A-□□ ● CL-SB-12B-□□ ● CL-SB-22A-□□ 6.8 6 – 1.2 6.8 1.2 3 5.8 4.4 2 – φ 0.9 holes 2.5 2.5 2.5 2.5 ● CL-SB-22B-□□ ● CL-SB-13A-□□ ● CL-SB-13B-□□ 6 – 1.2 3 5 1.2 4 4.4 5.8 3 2.5 2 5 4 – 1.2 3 3 4 – 1.2 2 – φ 0.9 holes 2.5 2.5 5.8 1.2 2 –φ 0.9 holes 4.4 3 – 1.2 3 – 1.2 2 – φ 0.9 holes 2 2 4 2 2.5 ● CL-SB-23A-□□ ● CL-SB-23B-□□ ● CL-SB-12C-□□ 3 – φ 0.8 holes 8 – 1.2 2 4 2 3.3 3 2 5.8 4.4 1.2 8 – 1.2 2 4 2.5 2.5 ■SIZE OF P.C.B. PROCESSING ● CL-SB-22C-□□ (Unit: mm) ● CL-SB-13C-□□ ● CL-SB-23C-□□ 6 – φ 0.8 holes 8 – φ 0.8 holes 3.3 3.3 3.3 4 – φ 0.8 holes 2 2 2.5 2.5 4 2 4 2 CL-SB SLIDE SWITCHES ■ PACKAGING SPECIFICATIONS ● The smallest unit of bulk pack in plastic bag is 10 pcs. per pack.Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs., etc. ● Boxing of bulk in a plastic bag is performed with 50 pcs. per box. ● Taping version is packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500, pcs., etc. ● Taping version is boxed with one reel (500 pcs.). Maximum number of consecutive missing pieces=2 Leader length and reel dimension are shown in the diagrams below: ● Embossed tape dimensions ● Reel dimensions (Unit: mm) (Conforms to JIS C 0806-3) (In accordance with EIAJ ET-7200A) 25.4±1 Empty Empty Filled 2±0.5 φ 13±0.2 40 mm min. φ 330±2 Head 20 pitches min. Leader 400 mm min. Direction of feed φ 80±1 End φ 21±0.8 Part No. label 29.4±1 Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) 〈Tape dimensions〉 11.5±0.1 1.75±0.1 (CL-SB-22B-02T) (CL-SB-22B-02T) Installation Installation example example 24 1.75±0.1 1.75±0.1 2 ± 0.12 ± 0.1 0 . 5 ± 0.1 0 . 5 ± 0.1 0 . 5 ± 0.1 0 . 5 ± 0.1 7.3 7.3 Direction Direction of feed of feed F 1.75±0.1 12 ± 0.1 12 ± 0.1 4 ± 0.14 ± 0.1 Terminal Terminal No.1 No.1 7.3 7.3 E CL-SB-12A/12B-1□T CL-SB-12A/12B-1□T φ 1.5 +0.1 φ0 1.5 +0.1 0 2 ± 0.12 ± 0.1 4 ± 0.14 ± 0.1 ± Direction Direction of feed of feed E (CL-SB-12B-02T) (CL-SB-12B-02T) Installation Installation example example φ 1.5 +0.1 φ0 1.5 +0.1 0 F CL-SB-22A/22B-1□T CL-SB-22A/22B-1□T 12 ± 0.1 12 ± 0.1 φ 1.5 +0.1 φ0 1.5 +0.1 0 4 ± 0.14 ± 0.1 2 ± 0.12 ± 0.1 1.75±0.1 ± 12 ± 0.1 12 ± 0.1 0 . 5 ± 0 . 15 ± 0 . 1 1.75±0.1 11.5±0.1 Terminal Terminal No.1 No.1 B CL-SB-22A/22B-0□T CL-SB-22A/22B-0□T 24 2 ± 0.12 ± 0.1 4 ± 0.14 ± 0.1 1.75±0.1 12 ± 0.1 12 ± 0.1 φ 1.5 +0.1 φ0 1.5 +0.1 0 B (Conforms to JIS C 0806) 1.75±0.1 A CL-SB-12A/12B-0□T CL-SB-12A/12B-0□T 24 11.5±0.1 A ● CL-SB-22A/22B-0 □ T 24 11.5±0.1 ● CL-SB-12A/12B-0 □ T 0 . 5 ± 0.1 0 . 5 ± 0.1 CL-SB SLIDE SWITCHES Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) 〈Tape dimensions〉 ● CL-SB-23A/23B-0 □ T 24 11.5±0.1 ± ± 7.3 7.3 7.3 DirectionDirection of feed of feed 7.3 Direction Directionof offeed feed (CL-SB-13B-02T) (CL-SB-13B-02T) Installation example Installation example 5.3 TerminalTerminal No.1 No.1 ± 0.1 2 ±20.1 ± 0.1 4 ±40.1 Terminal Terminal No.1 No.1 1.75±±0.1 0.1 1.75 Direction Directionof offeed feed 5.3 ± 0.1 0 . 05 .±50.1 (CL-SB-22B-12T) (CL-SB-22B-12T) Installation Installation exampleexample (CL-SB-23B-02T) (CL-SB-23B-02T) Installation example Installation example 5.3 5.3 5.3 DirectionDirection of feed of feed 5.3 7.37.3 Direction feed Direction of of feed CL-SB-23A/23B-1□T H H CL-SB-23A/23B-1□T ± 0.1 4 ±40.1 ± 0.1 2 ±20.1 Terminal Terminal No.1 No.1 ± 0.1 0 . 05 .±50.1 (CL-SB-23B-12T) (CL-SB-23B-12T) Installation example Installation example 24 24 (CL-SB-13B-12T) (CL-SB-13B-12T) Installation example Installation example ± 0.1 1212 ± 0.1 +0.1 +0.1 φ 1.5 φ 1.5 0 0 1.75 ±0.1 1.75 ±0.1 ± 0.1 0 . 05 .±50.1 24 24 Direction feed Direction of of feed 24 24 ± 0.1 1212 ± 0.1 +0.1 +0.1 φ 1.5 φ 1.5 0 0 0 . 5 ±(CL-SB-23B-12T) 0.10 . 5 ± 0.1 (CL-SB-23B-12T) Installation Installationexample example (Conforms to JIS C 0806) 11.5 ±0.1 11.5 ±0.1 Terminal Terminal No.1 No.1 2 ± 0.1 2 ± 0.1 00..55±±0.1 0.1 ● CL-SB-23A/23B-1 □ T 1.75± 0.1 1.75± 0.1 ± 0.1 2 ±20.1 No.1 7.37.3 CL-SB-13A/13B-1□T G G CL-SB-13A/13B-1□T 1212± ± 0.10.1 ± 0.1 4±40.1 12 ± 0.1 12 ± 0.1 +0.1 Terminal Terminal φ 1.5 +0.1 0 φ 1.5 0 4 ± 0.1 4 ± 0.1 No.1 5.3 5.3 ● CL-SB-13A/13B-1 □ T +0.1+0.1 φ 1.5 φ 1.5 0 0 7.3 24 ± 0.1 0 . 05 .±50.1 (CL-SB-12B-12T) (CL-SB-12B-12T) Installation Installation exampleexample 1.75±0.1 CL-SB-23A/23B-0□T D DCL-SB-23A/23B-0□T (CL-SB-13B-12T) (CL-SB-13B-12T) 0 . 5 ± 0.10 . 5 ± 0.1 Installation Installationexample example DirectionDirection of feed of feed Direction feed Direction of of feed 22±±0.1 0.1 1.75 ± 0.1 1.75 ± 0.1 11.5±0.1 1.75±0.1 11.5±±0.1 0.1 11.5 11.5±0.1 +0.1 +0.1 00 24 24 11.5 ± 0.1 11.5 ± 0.1 Terminal Terminal No.1 No.1 24 11.5±0.1 ± 0.1 2 ±20.1 ± 0.1 4 ±40.1 TerminalTerminal No.1 No.1 24 24 ± 0.1 1212 ± 0.1 +0.1 φ 1.5 φ 1.5 0 0 12 12±±0.1 0.1 2 ± 0.1 2 ± 0.1 No.1 No.1 7.3 11.5 ± 0.1 11.5 ± 0.1 12 ± 0.1 12 ± 0.1 7.3 7.3 DirectionDirection of feed of feed F CL-SB-22A/22B-1□T F CL-SB-22A/22B-1□T (Conforms to JIS C 0806) φφ1.5 44±±0.1 1.5 0.1 00..55±±0.1 0.1 1.75±0.1 CL-SB-13A/13B-0□T C C CL-SB-13A/13B-0□T 1.75 ± 0.1 1.75 ± 0.1 11.5±±0.1 0.1 1.75±0.1 11.5 22±±0.1 0.1 24 44±±0.1 0.1 +0.1 Terminal Terminal φ 1.5 +0.1 4 ± 0.1 0 φ 1.5 0 4 ± 0.1 +0.1 1.75±±0.1 0.1 1.75 12± 0.1 12± 0.1 E CL-SB-12A/12B-1□T CL-SB-12A/12B-1□T (CL-SB-22B-02T) (CL-SB-22B-02T) Installation Installation exampleexample HH CL-SB-23A/23B-1□T CL-SB-23A/23B-1□T □ T ● CL-SB-22A/22B-1 24 24 E (CL-SB-23B-02T) 0 . 5 ± 0.10 .(CL-SB-23B-02T) 5 ± 0.1 Installation Installationexample example Direction Directionof offeed feed G G CL-SB-13A/13B-1□T CL-SB-13A/13B-1□T □ T ● CL-SB-12A/12B-1 +0.1 +0.1 φφ1.5 1.5 00 TerminalTerminal No.1 No.1 11.5±0.1 Direction Directionof offeed feed (CL-SB-12B-02T) (CL-SB-12B-02T) Installation Installation exampleexample 2 ± 0.1 2 ± 0.1 No.1 No.1 24 24 11.5±0.1 TerminalTerminal No.1 No.1 Terminal φ 1.5 +0.1 φ 1.5 +0.1 0 Terminal 0 4 ± 0.1 4 ± 0.1 00..55±±0.1 0.1 24 12 ± 0.1 12 ± 0.1 (CL-SB-13B-02T) 0 . 5 ±(CL-SB-13B-02T) 0 . 10 . 5 ± 0 . 1 Installation Installationexample example 24 24 2 ± 0.1 2 ± 0.1 22±±0.1 0.1 44±±0.1 0.1 11.5±0.1 11.5±0.1 11.5±0.1 1.75±0.1 12 ± 0.1 12 ± 0.1 Terminal Terminal +0.1 φ 1.5 +0.1 ± 0.1 0 φ 1.5 0 4 ± 0.1 4 No.1 No.1 12 12±±0.1 0.1 B CL-SB-22A/22B-0□T CL-SB-22A/22B-0□T B +0.1 +0.1 φφ1.5 1.5 00 00..55±±0.1 0.1 11.5 ± 0.1 24 11.5± 0.1 22±±0.1 0.1 44±±0.1 0.1 1.75±0.1 12±±0.1 0.1 A 12 CL-SB-12A/12B-0□T CL-SB-12A/12B-0□T DD CL-SB-23A/23B-0□T CL-SB-23A/23B-0□T 1.75±0.1 1.75±0.1 1.75±0.1 1.75±0.1 A +0.1 +0.1 φφ1.5 1.5 00 (Conforms to JIS C 0806) 1.75±0.1 CC CL-SB-13A/13B-0□T CL-SB-13A/13B-0□T 11.5±0.1 11.5±0.1 11.5±0.1 24 1.75±0.1 24 ● CL-SB-13A/13B-0 □ T 5.35.3 Direction feed Direction of of feed 5.35.3
CL-SB-22B-01 价格&库存
很抱歉,暂时无法提供与“CL-SB-22B-01”相匹配的价格&库存,您可以联系我们找货
CL-SB-22B-01
  • 100+8.95463100+1.15852
CL-SB-22B-01
    • 1+4.05000
    • 10+3.96360
    • 50+3.89880
    库存:48
    CL-SB-22B-01
    • 1+8.035451+1.03960
    • 25+7.3367225+0.94920
    • 50+6.8126750+0.88140
    • 100+5.76457100+0.74580
    库存:477
